Home » Modeling » UML2 » Understanding property redefinition
Re: Understanding property redefinition [message #477448 is a reply to message #477428] |
Mon, 26 May 2008 15:03 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Felix,
I think you have a point.
The descriptive paragraph in the spec seems to be correct. The redefinining
property must conform to the redefined property.
I believe that the "redefinee" *should* be the property being redefined, but
it looks like whoever wrote the OCL took redefinee to mean the opposite.
If you take "redefinee" to mean the opposite of the property being redefined
then it works out :).
The UML2 implementation uses the terminology in the spec. to be consistent
(..ly confusing ).
You may want to raise an issue with OMG on that point.
-James.
"Felix Dorner" <felix_do@web.de> wrote in message
news:g16i4m$ir8$1@build.eclipse.org...
> I always have language problems with active and passive, so in the context
> of property redefinition, is the "redefinee" the property that's being
> redefined, or is it the redefining property?
> I assume that the "redefinee" is the property that is being redefined. But
> then something is wrong in the spec. (p. 125):
> "A redefining property is consistent with a redefined property if the type
> of the redefining property conforms to the type of the redefined property"
> But the OCL definition does it exactly the other way round.
> Property::isConsistentWith(redefinee : RedefinableElement) : Boolean
> let prop : Property = redefinee.oclAsType(Property) in
> (prop.type.conformsTo(self.type) and [...]
> Is my english just too bad, or is there just another inconsistency between
> text and OCL, and if this is the case, who's right, Text or OCL?
> Thanks for the english lessons...
> Felix
Re: Understanding property redefinition [message #477449 is a reply to message #477448] |
Mon, 26 May 2008 16:04 |
Felix Dorner Messages: 676 Registered: July 2009 |
James Bruck wrote:
> Hi Felix,
Hi James, thanks for your reply. My usual "bridge" to distinguish is "employer
and employee", those map quite well to their German translations, and this time
they didn't fail me neither. When do I ever learn that I am more clever than
this spec.., I wouldn't ask anymore then. ;-)
Anyway, I am now thinking that it should actually be that each classifier
mutually conforms to the other, iow, they must be the same, otherwise:
Given a Class
A
a:A
and a specialized Class
B extends A
a:B
This is the case when the type of the redefining property conforms to the
redefined property type.
Now suppose in an Operation, I expect an instance of A but I get an instance of B.
I assume an A so I could set the 'a' property to an A => bang! I can't because
for a B 'a' must be a B (or a subtype) which A isn't.
If you change the interpretation, you get the same problems when you try read
the attribute:
A
b:B
B extends A
b:A
You think you look at an A, but actually look at a B. Try to read the attribute
into a variable of type B
var aB : B = instance.b => bang!
What do you think?
Felix
Re: Understanding property redefinition [message #477463 is a reply to message #477449] |
Mon, 02 June 2008 15:01 |
Hi Felix,
Sorry about the late reply.
Consider a concrete example from the UML metamodel:
Class::superClass:Class is the redefining property that redefines
Classifier::general:Classifier ( Classifier::general is the redefined
property ).
In this case, the type of Class::superClass *Class* must conform to the type
of Classifier::general *Classifier*.
I think the constriant is correctly written indicating the type of the
redefining property should be consistent with the type of the redefined
property (the redefinee).
I'm not sure I fully understand the objection in your example.
- James.
news:g1en1a$pu1$1@build.eclipse.org...
> James Bruck wrote:
>> Hi Felix,
> "employer and employee", those map quite well to their German
> translations, and this time they didn't fail me neither. When do I ever
> learn that I am more clever than this spec.., I wouldn't ask anymore then.
> Given a Class
> A
> a:A
> B extends A
> a:B
> instance of B.
> because for a B 'a' must be a B (or a subtype) which A isn't.
> read the attribute:
> A
> b:B
> B extends A
> b:A
> attribute into a variable of type B
> What do you think?
> Felix
Re: Understanding property redefinition [message #626630 is a reply to message #477428] |
Hi Felix,
(..ly confusing ).
-James.
> Felix
Re: Understanding property redefinition [message #626631 is a reply to message #477448] |
James Bruck wrote:
> Hi Felix,
Given a Class
A
a:A
B extends A
a:B
the attribute:
A
b:B
B extends A
b:A
What do you think?
Felix
Re: Understanding property redefinition [message #626645 is a reply to message #477449] |
Hi Felix,
property ).
- James.
> James Bruck wrote:
>> Hi Felix,
> Given a Class
> A
> a:A
> B extends A
> a:B
> instance of B.
> read the attribute:
> A
> b:B
> B extends A
> b:A
> What do you think?
> Felix
Current Time: Wed Sep 25 00:53:02 GMT 2024
Powered by FUDForum. Page generated in 0.04200 seconds
