Home » Modeling » UML2 » Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477022 is a reply to message #477021] |
Tue, 04 March 2008 10:36 |
Jinhui Messages: 42 Registered: July 2009 |
Member |
Hi Kenn,
Thanks for the advice.
Well, it seemed that the URI
"pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml" has to be resolved
manually, otherwise it could not be resolved by EMF. (I always got the
"MalformedURLException")
So I solved the problem like this:
* I extract the "UMLPrimitiveTypes.library.uml" from the JAR file, and
save it in my current project dir.
* and then register the the pathmap-URI with with the physical one(the one
in my project dir), and now I was able to load the primitive type lib and
get the primitive types.
Jinhui
The code looks like this:
ResourceSet RESOURCE_SET = new
RESOURCE_SET.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
RESOURCE_SET.getResourceFactoryRegistry().getExtensionToFact oryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
Map uriMap = RESOURCE_SET.getURIConverter().getURIMap();
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "uml",
new UMLResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*",
new XMIResourceFactoryImpl());
URIConverter.URI_MAP.put(URI.createURI("pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml"),
URI.createFileURI(System.getProperty("user.dir") +
"/Model_Libs/UMLPrimitiveTypes.library.uml"));
Resource resource =
RESOURCE_SET.getResource(URI.createURI(UMLResource.UML_PRIMI TIVE_TYPES_LIBRARY_URI),
true);
Kenn Hussey wrote:
> Jinhui,
> Its sounds like a resource factory has not been registered to hande the URI
> you are trying load. The FAQ entry that I pointed you to shows how to do
> this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477023 is a reply to message #477022] |
Tue, 04 March 2008 15:53 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Jinhui,
What string did you try using for the base JAR URL? I've done this many
times in the past (as per the FAQ) and never had a problem...
Kenn
"Jinhui" <zhuj@in.tum.de> wrote in message
news:0026a798a8951e2cfe35598bcf00db2e$1@www.eclipse.org...
> Hi Kenn,
> So I solved the problem like this: * I extract the
> "UMLPrimitiveTypes.library.uml" from the JAR file, and save it in my
> Jinhui
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*", new
> Resource resource =
> true);
> Kenn Hussey wrote:
>> Jinhui,
>> URI you are trying load. The FAQ entry that I pointed you to shows how to
>> do this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626126 is a reply to message #477021] |
Member |
Hi Kenn,
Jinhui
Resource resource =
true);
Kenn Hussey wrote:
> Jinhui,
> this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626127 is a reply to message #477022] |
Jinhui,
Kenn
> Hi Kenn,
> Jinhui
> Resource resource =
> true);
> Kenn Hussey wrote:
>> Jinhui,
>> do this:
Current Time: Fri Apr 26 23:27:58 GMT 2024
Powered by FUDForum. Page generated in 0.03916 seconds
