CacheAdapter prevents garbage collection [message #476954] |
Wed, 20 February 2008 02:16 |
Rafael Chaves Messages: 362 Registered: July 2009 |
Hi all,
In my application, the singleton instance of CacheAdapter keeps holding
onto models even after I unload all resources in a resource set. With
the standard maximum heap size, loading and unloading a model several
times quickly leads to an OutOfMemoryError.
Just for kicks, I imported the org.eclipse.uml2.common plug-in and added
a static flush method to CacheAdapter that just replaces the current
CacheAdapter.INSTANCE with a new, empty one. The problem goes away.
Memory consumption remains constant.
There must be something that my application does that triggers this
problem. I spent some considerably time trying to come up with a simple
test case that would show the problem outside of the scope of my
application, but I haven't managed to do that yet. So instead of opening
a bug report, I decided to ask for help here. So, if CacheAdapter keeps
holding onto model elements, what may I be doing wrong? Any clues?
Rafael
Re: CacheAdapter prevents garbage collection [message #476956 is a reply to message #476954] |
Wed, 20 February 2008 16:14 |
Found some interesting info on the following thread, which was started
by myself almost two years ago... :)
http://dev.eclipse.org/newslists/news.eclipse.tools.uml2/msg 04014.html
Turns out I was unknowingly discarding an object that referenced a
resource set without unloading. Explicitly Unloading before
dereferencing fixed the issue.
Rafael
Rafael Chaves wrote:
> Hi all,
> Rafael
Re: CacheAdapter prevents garbage collection [message #626055 is a reply to message #476954] |
Rafael
> Hi all,
> Rafael
FUDForum. Page generated in 0.02975 seconds
