Re: Migrating from rational rose model to UML2 [message #476940 is a reply to message #476939] |
Sat, 16 February 2008 08:45 |
Jacques LESCOT Messages: 247 Registered: July 2009 |
Using Topcased (and activating the experimental feature), there is an
import wizard that let you import UML models and the graphical
representation of the diagrams developed with RSM/Rational Rose :
Select "Import... > Model > Import models into Topcased", then in the
dialog, you have to select the corresponding transformation, choose
"Rose/RSM to UML2DI Transformation" and then you need to reference the
input model (an *.emx file as I know), and then the output model (enter
just the name of the target file without extension). The "Input
Metamodel" is not required.
Note that you also need ATL component used for the transformation. I
advised you to download one of the last integration build which are
still compliant with Topcased 1.x and Eclipse Europa : transformations
are much more fast with these versions than before.
http://www.eclipse.org/modeling/m2m/downloads/index.php?proj ect=atl
Hope it helps,
Jacques
BG a écrit :
> Hello all,
> I would like to known how to migrate the rational rose model (i.e mdl)
> file to UML2 model.
> I have downloaded the required modeling plug-ins(topcased,mdt)...
> Let me know what is the best approach to do the migration
> Regards
> BG
Re: Migrating from rational rose model to UML2 [message #626039 is a reply to message #476939] |
Hope it helps,
Jacques
BG a écrit :
> Hello all,
> file to UML2 model.
> Regards
> BG
FUDForum. Page generated in 0.04070 seconds
