Home » Modeling » UML2 » how to find out the type of element in a package
Re: how to find out the type of element in a package [message #476922 is a reply to message #476921] |
Mon, 11 February 2008 02:42 |
Rafael Chaves Messages: 362 Registered: July 2009 |
Zengyu,
Like with any ECore based metamodel, you can retrieve the metaclass of
the model element (or EObject) invoking the eClass() operation.
You can then compare the result with the metaclass literal obtained via
<metamodel>Package.Literals.<metaclass constant>. For example,
UMLPackage.Literals.CLASS, UMLPackage.Literals.INTERFACE,
UMLPackage.Literals.COMPONENT etc.
HTH,
Rafael
Zengyu Lu wrote:
> Supposed a UML2 package has been loaded. I want to traverse this package
> and find out the type of each element like class, interface, or
> component programmatically. How could I do it?
> Thanks for any solutions.
> Zengyu
Re: how to find out the type of element in a package [message #476923 is a reply to message #476922] |
Mon, 11 February 2008 06:40 |
Originally posted by: antti.evesti.vtt.fi
I have made it as follows in my code.
EList<Element> el = package.getOwnedElements();
for(Object o : el) {
if(o instanceof StateMachine) {
stateMachine((StateMachine) o);
} else if (o instanceof Activity){
activity((Activity) o);
} else if(o instanceof Collaboration) {
sequenceDiagram((Collaboration) o);
} else if(o instanceof Component) {
componentDiagram((Component) o);
} else {
//System.out.println("Unknown diagram type");
I don't know is this the best way, but it looks working.
BR,
Antti
"Rafael Chaves" <rafael@no.spam.abstratt.com> wrote in message
news:foocm6$517$1@build.eclipse.org...
> Zengyu,
> HTH,
> Rafael
> Zengyu Lu wrote:
>> Hi,
>> Zengyu
Re: how to find out the type of element in a package [message #476933 is a reply to message #476923] |
Wed, 13 February 2008 19:49 |
kevin Messages: 22 Registered: July 2009 |
Antti,
Actually I had a solution that is very similar like yours. Just use
if(obj instanceof internal.ClassImpl) and other implementations to find
out the type of each element in package. Well, it works. But I do not
think it is a good idea to access internal things directly. Neither does
Eclipse. :)
But thanks anyway!
Zengyu
> } else {
> BR,
> Antti
>> Zengyu,
>> HTH,
>> Rafael
>> Zengyu Lu wrote:
>>> Hi,
>>> Zengyu
Re: how to find out the type of element in a package [message #626000 is a reply to message #476921] |
Zengyu,
HTH,
Rafael
Zengyu Lu wrote:
> Zengyu
Re: how to find out the type of element in a package [message #626022 is a reply to message #476922] |
} else {
BR,
Antti
> Zengyu,
> HTH,
> Rafael
> Zengyu Lu wrote:
>> Hi,
>> Zengyu
Re: how to find out the type of element in a package [message #626032 is a reply to message #476923] |
Antti,
Eclipse. :)
But thanks anyway!
Zengyu
> } else {
> BR,
> Antti
>> Zengyu,
>> HTH,
>> Rafael
>> Zengyu Lu wrote:
>>> Hi,
>>> Zengyu
Current Time: Fri Apr 26 00:29:27 GMT 2024
Powered by FUDForum. Page generated in 0.03425 seconds
