Home » Modeling » UML2 » static profiles - not working ;)
static profiles - not working ;) [message #476864] |
Tue, 22 January 2008 14:26 |
Stefan Kuhn Messages: 355 Registered: July 2009 |
--------------080903030902080901060108
hi all,
I've followed this tutorial:
----------- Create your Profile -------------
1. Create your uml profile as you would normally ( For example, create a
stereotype called MyExtendedClass that extends uml:Class ). (see the getting
started article for details ). (Call it My.profile.uml for example)
2. ** don't do the "define" step ***
3. On your profile, apply the <<ePackage>> stereotype from the existing
Ecore profile.
4. Set the nsURI to something ... say http://www.myOrg/MyProfile
------- Generate code ---------
1. Create an EMF project as you would from any other .uml model to generate
code from but specify your profile as the source ( My.profile.uml )
2. Select the "Process All" options when loading your My.profile.uml.
3. Generate code as you would normally from the resulting .genmodel.
------- Using your profile ------
Up to this point, things were pretty easy. Here comes the tricky part...
1. Move your previously generated code for your profile to your development
environment.
2. Create a new plugin in your development environment ( say a JUnit plugin
to get started with ).
3. In your JUnit plugin test, add the line:
UMLPlugin.getEPackageNsURIToProfileLocationMap().put(http://www.myOrg.com/My
Profile, URI.createURI( ... path to My.profile.uml#_XXX")); where XXX is the
id of the profile in your model.
4. Create a resource set and load your My.profile.uml.
5. Next, Load your profile using..
Profile myProfile = UMLUtil.getProfile(MyProfilePackage.eINSTANCE,
from the already generated MyProfilePackage from the "Generate Code"
step.
6. Next, obtain your stereotype with..
Stereotype myStereotype =
myProfile.getOwnedStereotype("MyExtendedClass");
7. This is the interesting part ... Apply your stereotype as follows:
MyExtendedClass myExtendedClass =
(MyExtendedClass)myClass.applyStereotype(myStereotype);
Notice how you do not get a stereotype application but rather a type of
"MyExtendedClass".
8. Now you have full access to setting variagbles to MyExtendedClass etc.
--- how cool is that ;) ----
and couldn't get it running. The reason is that
package_.applyProfile(myProfile); calls ProfileOperations: EPackage
getDefinition(Profile profile). This calls getTaggedValue(package_,
"Ecore" ... which -since I skipped the the define step (2)- is always
not there (null).
I've attached my test code and the .profile.uml.
For online-viewing, see http://rafb.net/p/9BbS1L94.html
The result of the code is:
Content of ProfileResi
org.eclipse.uml2.uml.internal.impl.ProfileImpl@1f195fc (name: My,
visibility: <unset>) (visibility: public)
org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@1afd9cc (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@3e926 (name: EPackage)
(instanceClassName: null) (abstract: false, interface: false)) (mixed:
[], anyAttribute: [base_Package=_EVrQ0MicEdyuvNC82dJYdg,
packageName=myProf, nsURI=http://www.my.org/Profile])
myProfile: org.eclipse.uml2.uml.internal.impl.ProfileImpl@1f195fc (name:
My, visibility: <unset>) (visibility: public)
Profile could not be applied
java.lang.IllegalArgumentException:
at
org.eclipse.uml2.uml.internal.operations.PackageOperations.a pplyProfile(PackageOperations.java:524)
at
org.eclipse.uml2.uml.internal.impl.PackageImpl.applyProfile( PackageImpl.java:1051)
at test.StaticProfile.testProfile(StaticProfile.java:102)
Stereotypes
at test.StaticProfile.main(StaticProfile.java:32
What am I doing wrong?
-stefan
Content-Type: text/xml;
name="GUI_OiO.profile.uml"
Content-Disposition: inline;
filename="GUI_OiO.profile.uml"
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:Ecore="http://www.eclipse.org/uml2/schemas/Ecore/4" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xsi:schemaLocation="http://www.eclipse.org/uml2/schemas/Ecore/4 pathmap://UML_PROFILES/Ecore.profile.uml#_B7dOIMEREduRdatXod jBjA">
<uml:Profile xmi:id="_12_5_1_15200e0_1191951371278_589868_232" name="GuiProfile" metamodelReference="_0metamodelReferenceGUI_OiO">
<packageImport xmi:id="_0metamodelReferenceGUI_OiO">
<importedPackage xmi:type="uml:Model" href="pathmap://UML_METAMODELS/UML.metamodel.uml#_0"/>
</packageImport>
<packageImport xmi:id="_0primitiveTypesGUI_OiO">
<importedPackage xmi:type="uml:Model" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packageImport xmi:id="_0javaPrimitiveTypesGUI_OiO">
<importedPackage xmi:type="uml:Model" href="pathmap://UML_LIBRARIES/JavaPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191951444711_532617_254" name="UIControl" isAbstract="true">
<ownedAttribute xmi:id="_12_5_1_15200e0_1191951461747_586671_257" name="base_Class" visibility="private" association="_12_5_1_15200e0_1191951461742_136617_256">
<type xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</ownedAttribute>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191951497116_308118_278" name="name" visibility="public">
<type xmi:type="uml:PrimitiveType" href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191951511530_812133_281" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191951511530_782080_280" name="" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191951461742_136617_256" name="" memberEnd="_12_5_1_15200e0_1191951461749_945624_258 _12_5_1_15200e0_1191951461747_586671_257">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191951461749_945624_258" name="extension_" visibility="private" type="_12_5_1_15200e0_1191951444711_532617_254" aggregation="composite" association="_12_5_1_15200e0_1191951461742_136617_256">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191951461750_90795_260" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191951461749_924987_259" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Enumeration" xmi:id="_12_5_1_15200e0_1191951577864_290094_283" name="UIContainerType">
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951609693_223765_302" name="COMPOSITE"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951633949_930543_304" name="SECTION"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951641341_712694_306" name="DIALOG"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951647549_41585_308" name="WIZARD"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951654389_673842_310" name="VIEW"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951660149_296674_312" name="TABFOLDER"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951669877_167411_314" name="GROUP"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191951677165_910462_316" name="SCREEN"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191951690312_464217_319" name="UIContainer">
<generalization xmi:id="_12_5_1_15200e0_1191951750360_472032_346" isSubstitutable="false" general="_12_5_1_15200e0_1191951444711_532617_254"/>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191951692820_263208_322" name="base_Class" visibility="private" association="_12_5_1_15200e0_1191951692820_933016_321">
</ownedAttribute>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191951718334_382224_343" name="type" visibility="public" type="_12_5_1_15200e0_1191951577864_290094_283">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191952749590_789899_785" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191952749590_588235_784" name="" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191951692820_933016_321" name="" memberEnd="_12_5_1_15200e0_1191951692820_263208_322 _12_5_1_15200e0_1191951692821_296714_323">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191951692821_296714_323" name="extension_" visibility="private" type="_12_5_1_15200e0_1191951690312_464217_319" aggregation="composite" association="_12_5_1_15200e0_1191951692820_933016_321">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191951692821_920088_325" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191951692821_171918_324" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191951761873_224879_371" name="UIDataControl" isAbstract="true">
<generalization xmi:id="_12_5_1_15200e0_1191951789855_785392_447" isSubstitutable="false" general="_12_5_1_15200e0_1191951444711_532617_254"/>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191951767428_923400_374" name="base_Class" visibility="private" association="_12_5_1_15200e0_1191951767428_598809_373">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191951767428_598809_373" name="" memberEnd="_12_5_1_15200e0_1191951767428_923400_374 _12_5_1_15200e0_1191951767428_297656_375">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191951767428_297656_375" name="extension_" visibility="private" type="_12_5_1_15200e0_1191951761873_224879_371" aggregation="composite" association="_12_5_1_15200e0_1191951767428_598809_373">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191951767429_574722_377" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191951767429_117114_376" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191952240606_445519_606" name="children UIContainer->UIControl">
<ownedAttribute xmi:id="_12_5_1_15200e0_1191952252681_709833_609" name="base_Association" visibility="private" association="_12_5_1_15200e0_1191952252680_904621_608">
<type xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Association"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191952252680_904621_608" name="" memberEnd="_12_5_1_15200e0_1191952252681_480707_610 _12_5_1_15200e0_1191952252681_709833_609">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191952252681_480707_610" name="extension_" visibility="private" type="_12_5_1_15200e0_1191952240606_445519_606" aggregation="composite" association="_12_5_1_15200e0_1191952252680_904621_608">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191952252681_30153_612" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191952252681_804516_611" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Enumeration" xmi:id="_12_5_1_15200e0_1191952434982_520771_645" name="UIComplexDataControlType">
<ownedLiteral xmi:id="_12_5_1_15200e0_1191952449406_918649_664" name="TABLE"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191952466006_58192_666" name="TREE"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191952472486_54160_668" name="LIST"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191952480478_349858_670" name="FORM"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191952487294_895150_672" name="EDITOR"/>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191952552688_338708_675" name="dataControlChildren UIComplexDataControl->UIDataControl">
<ownedAttribute xmi:id="_12_5_1_15200e0_1191952555379_166950_678" name="base_Association" visibility="private" association="_12_5_1_15200e0_1191952555379_305362_677">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191952555379_305362_677" name="" memberEnd="_12_5_1_15200e0_1191952555380_36450_679 _12_5_1_15200e0_1191952555379_166950_678">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191952555380_36450_679" name="extension_" visibility="private" type="_12_5_1_15200e0_1191952552688_338708_675" aggregation="composite" association="_12_5_1_15200e0_1191952555379_305362_677">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191952555380_894856_681" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191952555380_129948_680" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191952642401_691287_756" name="UIComplexDataControl">
<generalization xmi:id="_12_5_1_15200e0_1191952806356_666989_789" isSubstitutable="false" general="_12_5_1_15200e0_1191951761873_224879_371"/>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191952645284_114215_759" name="base_Class" visibility="private" association="_12_5_1_15200e0_1191952645284_484596_758">
</ownedAttribute>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191952721352_812895_780" name="type" visibility="public" type="_12_5_1_15200e0_1191952434982_520771_645">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191952793559_45663_787" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191952793558_859189_786" name="" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191952645284_484596_758" name="" memberEnd="_12_5_1_15200e0_1191952645284_114215_759 _12_5_1_15200e0_1191952645284_100915_760">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191952645284_100915_760" name="extension_" visibility="private" type="_12_5_1_15200e0_1191952642401_691287_756" aggregation="composite" association="_12_5_1_15200e0_1191952645284_484596_758">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191952645284_649162_762" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191952645284_136129_761" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191953026669_238956_938" name="complexDataControl UIDataControl->UIComplexDataControl">
<ownedAttribute xmi:id="_12_5_1_15200e0_1191953028759_239041_941" name="base_Association" visibility="private" association="_12_5_1_15200e0_1191953028759_918634_940">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191953028759_918634_940" name="" memberEnd="_12_5_1_15200e0_1191953028759_804402_942 _12_5_1_15200e0_1191953028759_239041_941">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191953028759_804402_942" name="extension_" visibility="private" type="_12_5_1_15200e0_1191953026669_238956_938" aggregation="composite" association="_12_5_1_15200e0_1191953028759_918634_940">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191953028759_852543_944" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191953028759_777965_943" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_12_5_1_15200e0_1191953113254_841091_964" name="UIPrimitiveDataControl">
<generalization xmi:id="_12_5_1_15200e0_1191953338087_458822_1019" isSubstitutable="false" general="_12_5_1_15200e0_1191951761873_224879_371"/>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191953116891_548625_967" name="base_Class" visibility="private" association="_12_5_1_15200e0_1191953116891_964982_966">
</ownedAttribute>
<ownedAttribute xmi:id="_12_5_1_15200e0_1191953185029_1046_1014" name="type" visibility="public" type="_12_5_1_15200e0_1191953126646_606954_989">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191953279608_844377_1017" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191953279608_801287_1016" name="" value="1"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_12_5_1_15200e0_1191953116891_964982_966" name="" memberEnd="_12_5_1_15200e0_1191953116892_385941_968 _12_5_1_15200e0_1191953116891_548625_967">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_12_5_1_15200e0_1191953116892_385941_968" name="extension_" visibility="private" type="_12_5_1_15200e0_1191953113254_841091_964" aggregation="composite" association="_12_5_1_15200e0_1191953116891_964982_966">
<upperValue xmi:type="uml:LiteralUnlimitedNatural" xmi:id="_12_5_1_15200e0_1191953116892_279445_970" name="" value="1"/>
<lowerValue xmi:type="uml:LiteralInteger" xmi:id="_12_5_1_15200e0_1191953116892_356906_969" name=""/>
</ownedEnd>
</packagedElement>
<packagedElement xmi:type="uml:Enumeration" xmi:id="_12_5_1_15200e0_1191953126646_606954_989" name="UIPrimitiveDataControlType">
<ownedLiteral xmi:id="_12_5_1_15200e0_1191953148501_880223_1008" name="BUTTON"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191953162205_626311_1010" name="TEXT"/>
<ownedLiteral xmi:id="_12_5_1_15200e0_1191953167709_704400_1012" name="LABEL"/>
</packagedElement>
<profileApplication xmi:id="_P9oBoMhrEdyBsvVY6aeXSQ">
<eAnnotations xmi:id="_P-C4YMhrEdyBsvVY6aeXSQ" source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage" href=" pathmap://UML_PROFILES/Ecore.profile.uml#_B7dOIMEREduRdatXod jBjA"/>
</eAnnotations>
<appliedProfile href="pathmap://UML_PROFILES/Ecore.profile.uml#_0"/>
</profileApplication>
</uml:Profile>
<Ecore:EPackage xmi:id="_bRkbEMhrEdyBsvVY6aeXSQ" base_Package="_12_5_1_15200e0_1191951371278_589868_232" packageName="guiProfile" nsPrefix="guiProfileNS" nsURI="http://www.oio.de/mdsd/tools/guiModel/guiProfile" basePackage="de.oio.mdsd.tools.guiModel" prefix="GUI_OIO"/>
</xmi:XMI>
Content-Type: text/x-java;
name="StaticProfile.java"
filename="StaticProfile.java"
package test;
import java.io.IOException;
import java.util.Map;
import myProf.MyClass;
import myProf.MyProfPackage;
import org.eclipse.emf.common.EMFPlugin;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EPackage.Registry;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.Package;
import org.eclipse.uml2.uml.Profile;
import org.eclipse.uml2.uml.Stereotype;
import org.eclipse.uml2.uml.UMLFactory;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.UMLPlugin;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.eclipse.uml2.uml.util.UMLUtil;
public class StaticProfile {
public static void main(String[] args){
try {
testProfile();
} catch (Exception e) {
e.printStackTrace();
private final static String workspace = "/home/qn/Coden/workspace-oAW/umlStatic/model/My.profile.uml ";
// private final static String runtime = " /home/qn/Coden/runtime-New_configuration/umlStatic/model/My. profile.uml ";
private final static String testModel = " /home/qn/Coden/runtime-New_configuration/umlStatic.test/src/ test/model.uml ";
private final static String umlJarLoc = " jar:file://home/qn/Coden/eclipse-oAW/plugins/org.eclipse.uml 2.uml.resources_2.1.0.v200706251652.jar!/";
private final static String path2profile = workspace;
// private final static String profileEPackageName = "myProf";
private final static String profileNS = MyProfPackage.eNS_URI; //"http://www.my.org/Profile";
private final static String suffix = "#_EVrQ0MicEdyuvNC82dJYdg";
private static void testProfile() {
System.out.println(">>>>>>>>>>>>>");
System.out.println();
// UMLPlugin.getEPackageNsURIToProfileLocationMap().put(profile EPackageName, URI.createURI(path2profile+suffix));
// UMLPlugin.getEPackageNsURIToProfileLocationMap().put(profile EPackageName, URI.createURI(path2profile));
UMLPlugin.getEPackageNsURIToProfileLocationMap().put(profile NS, URI.createURI(path2profile+suffix));
// UMLPlugin.getEPackageNsURIToProfileLocationMap().put(profile NS, URI.createURI(path2profile));
// Map<String, URI> nsURI2ProfileMap = UMLPlugin.getEPackageNsURIToProfileLocationMap();
// uml init
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI(umlJarLoc);
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
Map<String,Object> p2fMap = resourceSet.getResourceFactoryRegistry().getProtocolToFactor yMap();
// uml init ()
// Resource testResi = resourceSet.getResource(URI.createURI(path2profile+suffix), true);
// System.out.println("Content of TestResi");
// for(EObject obj : testResi.getContents()){
// System.out.println(obj);
Resource resi = resourceSet.createResource(URI.createFileURI(testModel));
Resource profileResi = resourceSet.getResource(URI.createFileURI(path2profile), true);
System.out.println("Content of ProfileResi");
for(EObject obj : profileResi.getContents()){
// uml bsp data
Package package_ = UMLFactory.eINSTANCE.createPackage();
resi.getContents().add(package_);
package_.setName("MeinPacket");
Class clazz = UMLFactory.eINSTANCE.createClass();
clazz.setPackage(package_);
clazz.setName("MeineKlasse2");
// uml bsp data()
Profile myProfile = UMLUtil.getProfile(MyProfPackage.eINSTANCE,package_);
if(myProfile==null){
System.out.println("myProfile==null");
} else{
System.out.println("myProfile: "+myProfile);
try{
System.out.println("Profile could not be applied");
System.out.println("\nStereotypes");
for(Stereotype stereo : clazz.getApplicableStereotypes()){
System.out.println(stereo);
// save
try {
resi.save(null);
} catch (IOException e) {
--------------080903030902080901060108--
Re: static profiles - not working ;) [message #476865 is a reply to message #476864] |
Tue, 22 January 2008 14:57 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Stefan,
In steps 3 and 4, you should have applied the <<ePackage>> stereotype to the
profile and set the value of the 'nsURI' tag:
Ecore profile.
This is the tag whose value is being obtained during look-up of the
profile's definition. If this look-up is failing, something else must be
going wrong... have you tried debugging the code?
Kenn
"SKuhn" <kuhn@oio.de> wrote in message
news:fn4umc$q8s$1@build.eclipse.org...
> hi all,
> getting
> Ecore profile.
> generate
> development
> environment.
> plugin
> the
> step.
> of
> "MyExtendedClass".
> not there (null).
> at
> at
> Stereotypes
> -stefan
> </packageImport>
> </packageImport>
> </packageImport>
> isAbstract="true">
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="COMPOSITE"/>
> name="SECTION"/>
> name="DIALOG"/>
> name="WIZARD"/>
> name="VIEW"/>
> name="TABFOLDER"/>
> name="GROUP"/>
> name="SCREEN"/>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> isAbstract="true">
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="TABLE"/>
> name="TREE"/>
> name="LIST"/>
> name="FORM"/>
> name="EDITOR"/>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="BUTTON"/>
> name="TEXT"/>
> name="LABEL"/>
> </packagedElement>
> </eAnnotations>
> </uml:Profile>
> </xmi:XMI>
> package test;
> try {
> testProfile();
> // uml init
> // uml init ()
> // uml bsp data
> // uml bsp data()
> } else{
> try{
> // save
> try {
> resi.save(null);
Re: static profiles - not working ;) [message #476867 is a reply to message #476865] |
Tue, 22 January 2008 15:06 |
oh right, I haven't seen it in the UML Editor, and when I looked in the
..uml late at night didn't see it, but the annotation is there:
</eAnnotations>
I've tried debugging the code, but as I said, the eAnnotation was not
resolved. I'll try it again, now that I now it is there :)
-stefan
Kenn Hussey wrote:
> Stefan,
> Ecore profile.
> Kenn
>> hi all,
>> getting
>> Ecore profile.
>> generate
>> development
>> environment.
>> plugin
>> the
>> step.
>> of
>> "MyExtendedClass".
>> not there (null).
>> at
>> at
>> Stereotypes
>> -stefan
>> <?xml version="1.0" encoding="UTF-8"?>
>> </packageImport>
>> </packageImport>
>> </packageImport>
>> isAbstract="true">
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="COMPOSITE"/>
>> name="SECTION"/>
>> name="DIALOG"/>
>> name="WIZARD"/>
>> name="VIEW"/>
>> name="TABFOLDER"/>
>> name="GROUP"/>
>> name="SCREEN"/>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> isAbstract="true">
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="TABLE"/>
>> name="TREE"/>
>> name="LIST"/>
>> name="FORM"/>
>> name="EDITOR"/>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="BUTTON"/>
>> name="TEXT"/>
>> name="LABEL"/>
>> </packagedElement>
>> </eAnnotations>
>> </uml:Profile>
>> </xmi:XMI>
>> package test;
>> try {
>> testProfile();
>> // uml init
>> // uml init ()
>> // uml bsp data
>> // uml bsp data()
>> } else{
>> try{
>> // save
>> try {
>> resi.save(null);
Re: static profiles - not working ;) [message #476868 is a reply to message #476867] |
Tue, 22 January 2008 17:06 |
well, with a closer look in PackageOperations, ApplyProfile I found
following:
EPackage profileDefinition = profile.getDefinition();
if (profileDefinition == null) {
throw new IllegalArgumentException(String.valueOf(profile));
if (package_.getProfileApplication(profile) == null) {
package_.createProfileApplication().setAppliedProfile(profil e);
profile.getDefinition(); return null, and the eAnnotation which I found
in .profile.uml is used -later on- for getProfile Application.
So, because my Profile is not defined, I don't have an annotation for it
-help!
-stefan
> </eAnnotations>
> -stefan
> Kenn Hussey wrote:
>> Stefan,
>> to the profile and set the value of the 'nsURI' tag:
>> existing Ecore profile.
>> be going wrong... have you tried debugging the code?
>> Kenn
>>> hi all,
>>> getting
>>> Ecore profile.
>>> generate
>>> part...
>>> development
>>> environment.
>>> plugin
>>> is the
>>> step.
>>> type of
>>> "MyExtendedClass".
>>> etc.
>>> not there (null).
>>> at
>>> at
>>> Stereotypes
>>> -stefan
>>> </packageImport>
>>> </packageImport>
>>> </packageImport>
>>> isAbstract="true">
>>> <ownedAttribute
>>> </ownedAttribute>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="COMPOSITE"/>
>>> name="SECTION"/>
>>> name="DIALOG"/>
>>> name="WIZARD"/>
>>> name="VIEW"/>
>>> name="TABFOLDER"/>
>>> name="GROUP"/>
>>> name="SCREEN"/>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="TABLE"/>
>>> name="TREE"/>
>>> name="LIST"/>
>>> name="FORM"/>
>>> name="EDITOR"/>
>>> </packagedElement>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="BUTTON"/>
>>> name="TEXT"/>
>>> name="LABEL"/>
>>> </packagedElement>
>>> </eAnnotations>
>>> <appliedProfile
>>> </uml:Profile>
>>> </xmi:XMI>
>>> package test;
>>> try {
>>> testProfile();
>>> // uml init
>>> // uml init ()
>>> Resource resi =
>>> // uml bsp data
>>> // uml bsp data()
>>> Profile myProfile =
>>> } else{
>>> try{
>>> // save
>>> try {
>>> resi.save(null);
Re: static profiles - not working ;) [message #476869 is a reply to message #476868] |
Tue, 22 January 2008 17:34 |
btw, I get the same error if I launch the test in the normal workspace
> following:
> -help!
> -stefan
>> the .uml late at night didn't see it, but the annotation is there:
>> </eAnnotations>
>> <appliedProfile
>> -stefan
>> Kenn Hussey wrote:
>>> Stefan,
>>> Kenn
>>>> hi all,
>>>> create a
>>>> getting
>>>> Ecore profile.
>>>> generate
>>>> part...
>>>> development
>>>> environment.
>>>> plugin
>>>> XXX is the
>>>> step.
>>>> follows:
>>>> type of
>>>> "MyExtendedClass".
>>>> etc.
>>>> not there (null).
>>>> (name:
>>>> at
>>>> at
>>>> Stereotypes
>>>> -stefan
>>>> </packageImport>
>>>> </packageImport>
>>>> </packageImport>
>>>> isAbstract="true">
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="COMPOSITE"/>
>>>> name="SECTION"/>
>>>> name="DIALOG"/>
>>>> name="WIZARD"/>
>>>> name="VIEW"/>
>>>> name="TABFOLDER"/>
>>>> name="GROUP"/>
>>>> name="SCREEN"/>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="TABLE"/>
>>>> name="TREE"/>
>>>> name="LIST"/>
>>>> name="FORM"/>
>>>> name="EDITOR"/>
>>>> </packagedElement>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <ownedLiteral
>>>> <ownedLiteral
>>>> <ownedLiteral
>>>> </packagedElement>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Profile>
>>>> </xmi:XMI>
>>>> package test;
>>>> try {
>>>> testProfile();
>>>> // uml init
>>>> // uml init ()
>>>> Resource resi =
>>>> // uml bsp data
>>>> // uml bsp data()
>>>> Profile myProfile =
>>>> } else{
>>>> try{
>>>> // save
>>>> try {
>>>> resi.save(null);
Re: static profiles - not working ;) [message #476872 is a reply to message #476869] |
Tue, 22 January 2008 18:43 |
.... but the definition of a static profile is obtained by looking it up in
the registry... are you sure that the URI you've put in the registry is
being resolved properly?
Kenn
news:fn59n9$rja$1@build.eclipse.org...
>> following:
>> it -help!
>> -stefan
>>> </eAnnotations>
>>> <appliedProfile
>>> -stefan
>>> Kenn Hussey wrote:
>>>> Stefan,
>>>> Ecore profile.
>>>> Kenn
>>>>> hi all,
>>>>> a
>>>>> getting
>>>>> existing
>>>>> Ecore profile.
>>>>> generate
>>>>> part...
>>>>> development
>>>>> environment.
>>>>> plugin
>>>>> is the
>>>>> Profile myProfile =
>>>>> Code"
>>>>> step.
>>>>> follows:
>>>>> type of
>>>>> "MyExtendedClass".
>>>>> etc.
>>>>> not there (null).
>>>>> (name:
>>>>> at
>>>>> at
>>>>> Stereotypes
>>>>> -stefan
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="COMPOSITE"/>
>>>>> name="SECTION"/>
>>>>> name="DIALOG"/>
>>>>> name="WIZARD"/>
>>>>> name="VIEW"/>
>>>>> name="TABFOLDER"/>
>>>>> name="GROUP"/>
>>>>> name="SCREEN"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="TABLE"/>
>>>>> name="TREE"/>
>>>>> name="LIST"/>
>>>>> name="FORM"/>
>>>>> name="EDITOR"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> <generalization
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="BUTTON"/>
>>>>> name="TEXT"/>
>>>>> name="LABEL"/>
>>>>> </packagedElement>
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> </uml:Profile>
>>>>> </xmi:XMI>
>>>>> package test;
>>>>> try {
>>>>> testProfile();
>>>>> // uml init
>>>>> // uml init ()
>>>>> Resource resi =
>>>>> // uml bsp data
>>>>> // uml bsp data()
>>>>> Profile myProfile =
>>>>> } else{
>>>>> try{
>>>>> // save
>>>>> try {
>>>>> resi.save(null);
Re: static profiles - not working ;) [message #476873 is a reply to message #476872] |
Tue, 22 January 2008 18:48 |
I think otherwise UMLUtil.getProfile(MyProfPackage.eINSTANCE,package_)
would return null. Is this correct?
-stefan
> Kenn
>>> following:
>>> if (
..getProfileApplication(profile) == null) {
>>> it -help!
>>> -stefan
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> -stefan
>>>> Kenn Hussey wrote:
>>>>> Stefan,
>>>>> Ecore profile.
>>>>> Kenn
>>>>>> hi all,
>>>>>> a
>>>>>> getting
>>>>>> existing
>>>>>> Ecore profile.
>>>>>> generate
>>>>>> part...
>>>>>> development
>>>>>> environment.
>>>>>> plugin
>>>>>> is the
>>>>>> Profile myProfile =
>>>>>> Code"
>>>>>> step.
>>>>>> follows:
>>>>>> type of
>>>>>> "MyExtendedClass".
>>>>>> etc.
>>>>>> not there (null).
>>>>>> (name:
>>>>>> at
>>>>>> at
>>>>>> Stereotypes
>>>>>> -stefan
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> isAbstract="true">
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="COMPOSITE"/>
>>>>>> name="SECTION"/>
>>>>>> name="DIALOG"/>
>>>>>> name="WIZARD"/>
>>>>>> name="VIEW"/>
>>>>>> name="TABFOLDER"/>
>>>>>> name="GROUP"/>
>>>>>> name="SCREEN"/>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> isAbstract="true">
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="TABLE"/>
>>>>>> name="TREE"/>
>>>>>> name="LIST"/>
>>>>>> name="FORM"/>
>>>>>> name="EDITOR"/>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="BUTTON"/>
>>>>>> name="TEXT"/>
>>>>>> name="LABEL"/>
>>>>>> </packagedElement>
>>>>>> </eAnnotations>
>>>>>> <appliedProfile
>>>>>> </uml:Profile>
>>>>>> </xmi:XMI>
>>>>>> package test;
>>>>>> try {
>>>>>> testProfile();
>>>>>> // uml init
>>>>>> // uml init ()
>>>>>> Resource resi =
>>>>>> // uml bsp data
>>>>>> // uml bsp data()
>>>>>> Profile myProfile =
>>>>>> } else{
>>>>>> try{
>>>>>> // save
>>>>>> try {
>>>>>> resi.save(null);
Re: static profiles - not working ;) [message #476876 is a reply to message #476873] |
Wed, 23 January 2008 02:07 |
Yes, if the URL that you've registered against the generated Ecore package
for the profile can't be resolved, that method will return null...
Kenn
"SKuhn" <kuhn@oio.de> wrote in message news:fn5e25$lp$1@build.eclipse.org...
> -stefan
>> in the registry... are you sure that the URI you've put in the registry
>> is being resolved properly?
>> Kenn
>>>> following:
>>>> throw new
>>>> if (
>>>> it -help!
>>>> -stefan
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> -stefan
>>>>> Kenn Hussey wrote:
>>>>>> Stefan,
>>>>>> Kenn
>>>>>>> hi all,
>>>>>>> create a
>>>>>>> getting
>>>>>>> example)
>>>>>>> existing
>>>>>>> Ecore profile.
>>>>>>> generate
>>>>>>> My.profile.uml.
>>>>>>> part...
>>>>>>> development
>>>>>>> environment.
>>>>>>> plugin
>>>>>>> XXX is the
>>>>>>> Profile myProfile =
>>>>>>> Code"
>>>>>>> step.
>>>>>>> follows:
>>>>>>> type of
>>>>>>> "MyExtendedClass".
>>>>>>> etc.
>>>>>>> always
>>>>>>> not there (null).
>>>>>>> (mixed:
>>>>>>> (name:
>>>>>>> at
>>>>>>> at
>>>>>>> Stereotypes
>>>>>>> -stefan
>>>>>>> </packageImport>
>>>>>>> </packageImport>
>>>>>>> </packageImport>
>>>>>>> isAbstract="true">
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> name="COMPOSITE"/>
>>>>>>> name="SECTION"/>
>>>>>>> name="DIALOG"/>
>>>>>>> name="WIZARD"/>
>>>>>>> name="VIEW"/>
>>>>>>> name="TABFOLDER"/>
>>>>>>> name="GROUP"/>
>>>>>>> name="SCREEN"/>
>>>>>>> </packagedElement>
>>>>>>> name="UIContainer">
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> name="TABLE"/>
>>>>>>> name="TREE"/>
>>>>>>> name="LIST"/>
>>>>>>> name="FORM"/>
>>>>>>> name="EDITOR"/>
>>>>>>> </packagedElement>
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <ownedLiteral
>>>>>>> <ownedLiteral
>>>>>>> <ownedLiteral
>>>>>>> </packagedElement>
>>>>>>> </eAnnotations>
>>>>>>> <appliedProfile
>>>>>>> </uml:Profile>
>>>>>>> </xmi:XMI>
>>>>>>> package test;
>>>>>>> try {
>>>>>>> testProfile();
>>>>>>> // uml init
>>>>>>> // uml init ()
>>>>>>> Resource resi =
>>>>>>> // uml bsp data
>>>>>>> // uml bsp data()
>>>>>>> Profile myProfile =
>>>>>>> } else{
>>>>>>> try{
>>>>>>> // save
>>>>>>> try {
>>>>>>> resi.save(null);
Re: static profiles - not working ;) [message #476878 is a reply to message #476864] |
Wed, 23 January 2008 15:23 |
james bruck Messages: 1724 Registered: July 2009 |
I was just wondering if you managed to get this working after all?
Step 3 in the "Using your profile" section below can be replaced with using
the existing extension point to register your profile.
Apart from that, you should be able to use your profile as normal.
- James.
> hi all,
> getting
> Ecore profile.
> generate
> development
> environment.
> plugin
> the
> step.
> of
> "MyExtendedClass".
> not there (null).
> at
> at
> Stereotypes
> -stefan
> </packageImport>
> </packageImport>
> </packageImport>
> isAbstract="true">
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="COMPOSITE"/>
> name="SECTION"/>
> name="DIALOG"/>
> name="WIZARD"/>
> name="VIEW"/>
> name="TABFOLDER"/>
> name="GROUP"/>
> name="SCREEN"/>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> isAbstract="true">
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="TABLE"/>
> name="TREE"/>
> name="LIST"/>
> name="FORM"/>
> name="EDITOR"/>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="BUTTON"/>
> name="TEXT"/>
> name="LABEL"/>
> </packagedElement>
> </eAnnotations>
> </uml:Profile>
> </xmi:XMI>
> package test;
> try {
> testProfile();
> // uml init
> // uml init ()
> // uml bsp data
> // uml bsp data()
> } else{
> try{
> // save
> try {
> resi.save(null);
Re: static profiles - not working ;) [message #476879 is a reply to message #476878] |
Wed, 23 January 2008 23:58 |
no I wasn't. I decided to take a CPU expensive way and wait until it is
supported. The best thing I could do is "apply" the stereotypes, but the
tree-uml2 editor of eclipse didn't really recognized them as
stereotypes. They were plain EMF instances attached to the uml model.
Things like the reflection property sheet and the <<StereotypeName>> in
front of the class didn't work.
-stefan
James Bruck wrote:
> - James.
>> hi all,
>> getting
>> Ecore profile.
>> generate
>> development
>> environment.
>> plugin
>> the
>> step.
>> of
>> "MyExtendedClass".
>> not there (null).
>> at
>> at
>> Stereotypes
>> -stefan
>> </packageImport>
>> </packageImport>
>> </packageImport>
>> isAbstract="true">
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="COMPOSITE"/>
>> name="SECTION"/>
>> name="DIALOG"/>
>> name="WIZARD"/>
>> name="VIEW"/>
>> name="TABFOLDER"/>
>> name="GROUP"/>
>> name="SCREEN"/>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> isAbstract="true">
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="TABLE"/>
>> name="TREE"/>
>> name="LIST"/>
>> name="FORM"/>
>> name="EDITOR"/>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="BUTTON"/>
>> name="TEXT"/>
>> name="LABEL"/>
>> </packagedElement>
>> </eAnnotations>
>> </uml:Profile>
>> </xmi:XMI>
>> package test;
>> try {
>> testProfile();
>> // uml init
>> // uml init ()
>> // uml bsp data
>> // uml bsp data()
>> } else{
>> try{
>> // save
>> try {
>> resi.save(null);
Re: static profiles - not working ;) [message #476883 is a reply to message #476879] |
Mon, 28 January 2008 15:54 |
Hi Stefan,
I just tried it out and it is working for me. I think that something is not
quite setup properly in your configuration.
The UML2 editor does recognize them with the <<StereotypeName>> and the
properties sheet does show the additional meta-attributes.
I will send out a more detailed document explaining the end-to-end process
( with screen captures etc. ).
- James.
news:fn8khv$655$1@build.eclipse.org...
> tree-uml2 editor of eclipse didn't really recognized them as stereotypes.
> They were plain EMF instances attached to the uml model. Things like the
> reflection property sheet and the <<StereotypeName>> in front of the class
> didn't work.
> -stefan
> James Bruck wrote:
>> Hi,
>> using the existing extension point to register your profile.
>> - James.
>>> hi all,
>>> getting
>>> Ecore profile.
>>> generate
>>> part...
>>> development
>>> environment.
>>> plugin
>>> the
>>> step.
>>> of
>>> "MyExtendedClass".
>>> etc.
>>> not there (null).
>>> at
>>> at
>>> Stereotypes
>>> -stefan
>>> </packageImport>
>>> </packageImport>
>>> </packageImport>
>>> isAbstract="true">
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="COMPOSITE"/>
>>> name="SECTION"/>
>>> name="DIALOG"/>
>>> name="WIZARD"/>
>>> name="VIEW"/>
>>> name="TABFOLDER"/>
>>> name="GROUP"/>
>>> name="SCREEN"/>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> isAbstract="true">
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="TABLE"/>
>>> name="TREE"/>
>>> name="LIST"/>
>>> name="FORM"/>
>>> name="EDITOR"/>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="BUTTON"/>
>>> name="TEXT"/>
>>> name="LABEL"/>
>>> </packagedElement>
>>> </eAnnotations>
>>> <appliedProfile
>>> </uml:Profile>
>>> </xmi:XMI>
>>> package test;
>>> try {
>>> testProfile();
>>> // uml init
>>> // uml init ()
>>> Resource resi =
>>> // uml bsp data
>>> // uml bsp data()
>>> Profile myProfile =
>>> } else{
>>> try{
>>> // save
>>> try {
>>> resi.save(null);
Re: static profiles - not working ;) [message #476885 is a reply to message #476883] |
Mon, 28 January 2008 23:27 |
Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=205480 for a rough
word document explaining how to use static profiles.
( A cleaned up version to follow shortly ).
Let me know if this gets you further.
-James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fnkts5$3jr$1@build.eclipse.org...
> Hi Stefan,
> not quite setup properly in your configuration.
> Cheers,
> - James.
>> class didn't work.
>> -stefan
>> James Bruck wrote:
>>> Hi,
>>> - James.
>>>> hi all,
>>>> a
>>>> getting
>>>> Ecore profile.
>>>> generate
>>>> part...
>>>> development
>>>> environment.
>>>> plugin
>>>> is the
>>>> step.
>>>> follows:
>>>> type of
>>>> "MyExtendedClass".
>>>> etc.
>>>> not there (null).
>>>> (name:
>>>> at
>>>> at
>>>> Stereotypes
>>>> -stefan
>>>> </packageImport>
>>>> </packageImport>
>>>> </packageImport>
>>>> isAbstract="true">
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="COMPOSITE"/>
>>>> name="SECTION"/>
>>>> name="DIALOG"/>
>>>> name="WIZARD"/>
>>>> name="VIEW"/>
>>>> name="TABFOLDER"/>
>>>> name="GROUP"/>
>>>> name="SCREEN"/>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> isAbstract="true">
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="TABLE"/>
>>>> name="TREE"/>
>>>> name="LIST"/>
>>>> name="FORM"/>
>>>> name="EDITOR"/>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="BUTTON"/>
>>>> name="TEXT"/>
>>>> name="LABEL"/>
>>>> </packagedElement>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Profile>
>>>> </xmi:XMI>
>>>> package test;
>>>> try {
>>>> testProfile();
>>>> // uml init
>>>> // uml init ()
>>>> Resource resi =
>>>> // uml bsp data
>>>> // uml bsp data()
>>>> Profile myProfile =
>>>> } else{
>>>> try{
>>>> // save
>>>> try {
>>>> resi.save(null);
Re: static profiles - not working ;) [message #476888 is a reply to message #476885] |
Tue, 29 January 2008 07:20 |
thanks, I'll try it today. Can I use this profile standalone (like a
normal profile for other uml-tools), too?
-stefan
> Cheers,
> -James.
>> Hi Stefan,
>> Cheers,
>> - James.
>>> class didn't work.
>>> -stefan
>>> James Bruck wrote:
>>>> Hi,
>>>> - James.
>>>>> hi all,
>>>>> a
>>>>> getting
>>>>> Ecore profile.
>>>>> generate
>>>>> part...
>>>>> development
>>>>> environment.
>>>>> plugin
>>>>> is the
>>>>> step.
>>>>> follows:
>>>>> type of
>>>>> "MyExtendedClass".
>>>>> etc.
>>>>> not there (null).
>>>>> (name:
>>>>> at
>>>>> at
>>>>> Stereotypes
>>>>> -stefan
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="COMPOSITE"/>
>>>>> name="SECTION"/>
>>>>> name="DIALOG"/>
>>>>> name="WIZARD"/>
>>>>> name="VIEW"/>
>>>>> name="TABFOLDER"/>
>>>>> name="GROUP"/>
>>>>> name="SCREEN"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="TABLE"/>
>>>>> name="TREE"/>
>>>>> name="LIST"/>
>>>>> name="FORM"/>
>>>>> name="EDITOR"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="BUTTON"/>
>>>>> name="TEXT"/>
>>>>> name="LABEL"/>
>>>>> </packagedElement>
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> </uml:Profile>
>>>>> </xmi:XMI>
>>>>> package test;
>>>>> try {
>>>>> testProfile();
>>>>> // uml init
>>>>> // uml init ()
>>>>> Resource resi =
>>>>> // uml bsp data
>>>>> // uml bsp data()
>>>>> Profile myProfile =
>>>>> } else{
>>>>> try{
>>>>> // save
>>>>> try {
>>>>> resi.save(null);
Re: static profiles - not working ;) [message #476892 is a reply to message #476888] |
Tue, 29 January 2008 14:24 |
Yes you can use your static profile as you would any other profile (the key
thing to remember is to register your profile correctly).
- James
news:fnmkc2$tl7$2@build.eclipse.org...
> -stefan
>> rough word document explaining how to use static profiles.
>> Cheers,
>> -James.
>>> Hi Stefan,
>>> process ( with screen captures etc. ).
>>> Cheers,
>>> - James.
>>>> the tree-uml2 editor of eclipse didn't really recognized them as
>>>> -stefan
>>>> James Bruck wrote:
>>>>> Hi,
>>>>> - James.
>>>>>> hi all,
>>>>>> create a
>>>>>> getting
>>>>>> existing
>>>>>> Ecore profile.
>>>>>> generate
>>>>>> part...
>>>>>> development
>>>>>> environment.
>>>>>> plugin
>>>>>> is the
>>>>>> Profile myProfile =
>>>>>> Code"
>>>>>> step.
>>>>>> follows:
>>>>>> type of
>>>>>> "MyExtendedClass".
>>>>>> etc.
>>>>>> not there (null).
>>>>>> (mixed:
>>>>>> (name:
>>>>>> at
>>>>>> at
>>>>>> Stereotypes
>>>>>> -stefan
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> isAbstract="true">
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="COMPOSITE"/>
>>>>>> name="SECTION"/>
>>>>>> name="DIALOG"/>
>>>>>> name="WIZARD"/>
>>>>>> name="VIEW"/>
>>>>>> name="TABFOLDER"/>
>>>>>> name="GROUP"/>
>>>>>> name="SCREEN"/>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="TABLE"/>
>>>>>> name="TREE"/>
>>>>>> name="LIST"/>
>>>>>> name="FORM"/>
>>>>>> name="EDITOR"/>
>>>>>> </packagedElement>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> value="1"/>
>>>>>> value="1"/>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="BUTTON"/>
>>>>>> name="TEXT"/>
>>>>>> name="LABEL"/>
>>>>>> </packagedElement>
>>>>>> </eAnnotations>
>>>>>> <appliedProfile
>>>>>> </uml:Profile>
>>>>>> </xmi:XMI>
>>>>>> package test;
>>>>>> try {
>>>>>> testProfile();
>>>>>> // uml init
>>>>>> // uml init ()
>>>>>> Resource resi =
>>>>>> // uml bsp data
>>>>>> // uml bsp data()
>>>>>> Profile myProfile =
>>>>>> } else{
>>>>>> try{
>>>>>> // save
>>>>>> try {
>>>>>> resi.save(null);
Re: static profiles - not working ;) [message #625918 is a reply to message #476864] |
Stefan,
Ecore profile.
Kenn
> hi all,
> getting
> Ecore profile.
> generate
> development
> environment.
> plugin
> the
> step.
> of
> "MyExtendedClass".
> not there (null).
> at
> at
> Stereotypes
> -stefan
> </packageImport>
> </packageImport>
> </packageImport>
> isAbstract="true">
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="COMPOSITE"/>
> name="SECTION"/>
> name="DIALOG"/>
> name="WIZARD"/>
> name="VIEW"/>
> name="TABFOLDER"/>
> name="GROUP"/>
> name="SCREEN"/>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> isAbstract="true">
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="TABLE"/>
> name="TREE"/>
> name="LIST"/>
> name="FORM"/>
> name="EDITOR"/>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="BUTTON"/>
> name="TEXT"/>
> name="LABEL"/>
> </packagedElement>
> </eAnnotations>
> </uml:Profile>
> </xmi:XMI>
> package test;
> try {
> testProfile();
> // uml init
> // uml init ()
> // uml bsp data
> // uml bsp data()
> } else{
> try{
> // save
> try {
> resi.save(null);
Re: static profiles - not working ;) [message #625920 is a reply to message #476865] |
</eAnnotations>
-stefan
Kenn Hussey wrote:
> Stefan,
> Ecore profile.
> Kenn
>> hi all,
>> getting
>> Ecore profile.
>> generate
>> development
>> environment.
>> plugin
>> the
>> step.
>> of
>> "MyExtendedClass".
>> not there (null).
>> at
>> at
>> Stereotypes
>> -stefan
>> </packageImport>
>> </packageImport>
>> </packageImport>
>> isAbstract="true">
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="COMPOSITE"/>
>> name="SECTION"/>
>> name="DIALOG"/>
>> name="WIZARD"/>
>> name="VIEW"/>
>> name="TABFOLDER"/>
>> name="GROUP"/>
>> name="SCREEN"/>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> isAbstract="true">
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="TABLE"/>
>> name="TREE"/>
>> name="LIST"/>
>> name="FORM"/>
>> name="EDITOR"/>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="BUTTON"/>
>> name="TEXT"/>
>> name="LABEL"/>
>> </packagedElement>
>> </eAnnotations>
>> </uml:Profile>
>> </xmi:XMI>
>> package test;
>> try {
>> testProfile();
>> // uml init
>> // uml init ()
>> // uml bsp data
>> // uml bsp data()
>> } else{
>> try{
>> // save
>> try {
>> resi.save(null);
Re: static profiles - not working ;) [message #625922 is a reply to message #476867] |
following:
-help!
-stefan
> </eAnnotations>
> -stefan
> Kenn Hussey wrote:
>> Stefan,
>> Kenn
>>> hi all,
>>> getting
>>> Ecore profile.
>>> generate
>>> part...
>>> development
>>> environment.
>>> plugin
>>> is the
>>> step.
>>> type of
>>> "MyExtendedClass".
>>> etc.
>>> not there (null).
>>> at
>>> at
>>> Stereotypes
>>> -stefan
>>> </packageImport>
>>> </packageImport>
>>> </packageImport>
>>> isAbstract="true">
>>> <ownedAttribute
>>> </ownedAttribute>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="COMPOSITE"/>
>>> name="SECTION"/>
>>> name="DIALOG"/>
>>> name="WIZARD"/>
>>> name="VIEW"/>
>>> name="TABFOLDER"/>
>>> name="GROUP"/>
>>> name="SCREEN"/>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="TABLE"/>
>>> name="TREE"/>
>>> name="LIST"/>
>>> name="FORM"/>
>>> name="EDITOR"/>
>>> </packagedElement>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> <generalization
>>> <ownedAttribute
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="BUTTON"/>
>>> name="TEXT"/>
>>> name="LABEL"/>
>>> </packagedElement>
>>> </eAnnotations>
>>> <appliedProfile
>>> </uml:Profile>
>>> </xmi:XMI>
>>> package test;
>>> try {
>>> testProfile();
>>> // uml init
>>> // uml init ()
>>> Resource resi =
>>> // uml bsp data
>>> // uml bsp data()
>>> Profile myProfile =
>>> } else{
>>> try{
>>> // save
>>> try {
>>> resi.save(null);
Re: static profiles - not working ;) [message #625923 is a reply to message #476868] |
> following:
> -help!
> -stefan
>> </eAnnotations>
>> <appliedProfile
>> -stefan
>> Kenn Hussey wrote:
>>> Stefan,
>>> Kenn
>>>> hi all,
>>>> create a
>>>> getting
>>>> Ecore profile.
>>>> generate
>>>> part...
>>>> development
>>>> environment.
>>>> plugin
>>>> XXX is the
>>>> step.
>>>> follows:
>>>> type of
>>>> "MyExtendedClass".
>>>> etc.
>>>> not there (null).
>>>> (name:
>>>> at
>>>> at
>>>> Stereotypes
>>>> -stefan
>>>> </packageImport>
>>>> </packageImport>
>>>> </packageImport>
>>>> isAbstract="true">
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="COMPOSITE"/>
>>>> name="SECTION"/>
>>>> name="DIALOG"/>
>>>> name="WIZARD"/>
>>>> name="VIEW"/>
>>>> name="TABFOLDER"/>
>>>> name="GROUP"/>
>>>> name="SCREEN"/>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="TABLE"/>
>>>> name="TREE"/>
>>>> name="LIST"/>
>>>> name="FORM"/>
>>>> name="EDITOR"/>
>>>> </packagedElement>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <generalization
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> <ownedAttribute
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> <ownedLiteral
>>>> <ownedLiteral
>>>> <ownedLiteral
>>>> </packagedElement>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Profile>
>>>> </xmi:XMI>
>>>> package test;
>>>> try {
>>>> testProfile();
>>>> // uml init
>>>> // uml init ()
>>>> Resource resi =
>>>> // uml bsp data
>>>> // uml bsp data()
>>>> Profile myProfile =
>>>> } else{
>>>> try{
>>>> // save
>>>> try {
>>>> resi.save(null);
Re: static profiles - not working ;) [message #625926 is a reply to message #476869] |
Kenn
>> following:
>> it -help!
>> -stefan
>>> </eAnnotations>
>>> <appliedProfile
>>> -stefan
>>> Kenn Hussey wrote:
>>>> Stefan,
>>>> Ecore profile.
>>>> Kenn
>>>>> hi all,
>>>>> a
>>>>> getting
>>>>> existing
>>>>> Ecore profile.
>>>>> generate
>>>>> part...
>>>>> development
>>>>> environment.
>>>>> plugin
>>>>> is the
>>>>> Profile myProfile =
>>>>> Code"
>>>>> step.
>>>>> follows:
>>>>> type of
>>>>> "MyExtendedClass".
>>>>> etc.
>>>>> not there (null).
>>>>> (name:
>>>>> at
>>>>> at
>>>>> Stereotypes
>>>>> -stefan
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="COMPOSITE"/>
>>>>> name="SECTION"/>
>>>>> name="DIALOG"/>
>>>>> name="WIZARD"/>
>>>>> name="VIEW"/>
>>>>> name="TABFOLDER"/>
>>>>> name="GROUP"/>
>>>>> name="SCREEN"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="TABLE"/>
>>>>> name="TREE"/>
>>>>> name="LIST"/>
>>>>> name="FORM"/>
>>>>> name="EDITOR"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> <generalization
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="BUTTON"/>
>>>>> name="TEXT"/>
>>>>> name="LABEL"/>
>>>>> </packagedElement>
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> </uml:Profile>
>>>>> </xmi:XMI>
>>>>> package test;
>>>>> try {
>>>>> testProfile();
>>>>> // uml init
>>>>> // uml init ()
>>>>> Resource resi =
>>>>> // uml bsp data
>>>>> // uml bsp data()
>>>>> Profile myProfile =
>>>>> } else{
>>>>> try{
>>>>> // save
>>>>> try {
>>>>> resi.save(null);
Re: static profiles - not working ;) [message #625927 is a reply to message #476872] |
-stefan
> Kenn
>>> following:
>>> if (
>>> it -help!
>>> -stefan
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> -stefan
>>>> Kenn Hussey wrote:
>>>>> Stefan,
>>>>> Ecore profile.
>>>>> Kenn
>>>>>> hi all,
>>>>>> a
>>>>>> getting
>>>>>> existing
>>>>>> Ecore profile.
>>>>>> generate
>>>>>> part...
>>>>>> development
>>>>>> environment.
>>>>>> plugin
>>>>>> is the
>>>>>> Profile myProfile =
>>>>>> Code"
>>>>>> step.
>>>>>> follows:
>>>>>> type of
>>>>>> "MyExtendedClass".
>>>>>> etc.
>>>>>> not there (null).
>>>>>> (name:
>>>>>> at
>>>>>> at
>>>>>> Stereotypes
>>>>>> -stefan
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> isAbstract="true">
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="COMPOSITE"/>
>>>>>> name="SECTION"/>
>>>>>> name="DIALOG"/>
>>>>>> name="WIZARD"/>
>>>>>> name="VIEW"/>
>>>>>> name="TABFOLDER"/>
>>>>>> name="GROUP"/>
>>>>>> name="SCREEN"/>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> isAbstract="true">
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="TABLE"/>
>>>>>> name="TREE"/>
>>>>>> name="LIST"/>
>>>>>> name="FORM"/>
>>>>>> name="EDITOR"/>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> </ownedAttribute>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="BUTTON"/>
>>>>>> name="TEXT"/>
>>>>>> name="LABEL"/>
>>>>>> </packagedElement>
>>>>>> </eAnnotations>
>>>>>> <appliedProfile
>>>>>> </uml:Profile>
>>>>>> </xmi:XMI>
>>>>>> package test;
>>>>>> try {
>>>>>> testProfile();
>>>>>> // uml init
>>>>>> // uml init ()
>>>>>> Resource resi =
>>>>>> // uml bsp data
>>>>>> // uml bsp data()
>>>>>> Profile myProfile =
>>>>>> } else{
>>>>>> try{
>>>>>> // save
>>>>>> try {
>>>>>> resi.save(null);
Re: static profiles - not working ;) [message #625930 is a reply to message #476873] |
Kenn
> -stefan
>> Kenn
>>>> following:
>>>> throw new
>>>> if (
>>>> it -help!
>>>> -stefan
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> -stefan
>>>>> Kenn Hussey wrote:
>>>>>> Stefan,
>>>>>> Kenn
>>>>>>> hi all,
>>>>>>> create a
>>>>>>> getting
>>>>>>> example)
>>>>>>> existing
>>>>>>> Ecore profile.
>>>>>>> generate
>>>>>>> My.profile.uml.
>>>>>>> part...
>>>>>>> development
>>>>>>> environment.
>>>>>>> plugin
>>>>>>> XXX is the
>>>>>>> Profile myProfile =
>>>>>>> Code"
>>>>>>> step.
>>>>>>> follows:
>>>>>>> type of
>>>>>>> "MyExtendedClass".
>>>>>>> etc.
>>>>>>> always
>>>>>>> not there (null).
>>>>>>> (mixed:
>>>>>>> (name:
>>>>>>> at
>>>>>>> at
>>>>>>> Stereotypes
>>>>>>> -stefan
>>>>>>> </packageImport>
>>>>>>> </packageImport>
>>>>>>> </packageImport>
>>>>>>> isAbstract="true">
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> name="COMPOSITE"/>
>>>>>>> name="SECTION"/>
>>>>>>> name="DIALOG"/>
>>>>>>> name="WIZARD"/>
>>>>>>> name="VIEW"/>
>>>>>>> name="TABFOLDER"/>
>>>>>>> name="GROUP"/>
>>>>>>> name="SCREEN"/>
>>>>>>> </packagedElement>
>>>>>>> name="UIContainer">
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> name="TABLE"/>
>>>>>>> name="TREE"/>
>>>>>>> name="LIST"/>
>>>>>>> name="FORM"/>
>>>>>>> name="EDITOR"/>
>>>>>>> </packagedElement>
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <generalization
>>>>>>> <ownedAttribute
>>>>>>> </ownedAttribute>
>>>>>>> <ownedAttribute
>>>>>>> value="1"/>
>>>>>>> value="1"/>
>>>>>>> </ownedAttribute>
>>>>>>> </packagedElement>
>>>>>>> value="1"/>
>>>>>>> </ownedEnd>
>>>>>>> </packagedElement>
>>>>>>> <ownedLiteral
>>>>>>> <ownedLiteral
>>>>>>> <ownedLiteral
>>>>>>> </packagedElement>
>>>>>>> </eAnnotations>
>>>>>>> <appliedProfile
>>>>>>> </uml:Profile>
>>>>>>> </xmi:XMI>
>>>>>>> package test;
>>>>>>> try {
>>>>>>> testProfile();
>>>>>>> // uml init
>>>>>>> // uml init ()
>>>>>>> Resource resi =
>>>>>>> // uml bsp data
>>>>>>> // uml bsp data()
>>>>>>> Profile myProfile =
>>>>>>> } else{
>>>>>>> try{
>>>>>>> // save
>>>>>>> try {
>>>>>>> resi.save(null);
Re: static profiles - not working ;) [message #625932 is a reply to message #476864] |
- James.
> hi all,
> I've followed this tutorial:
> ----------- Create your Profile -------------
> 1. Create your uml profile as you would normally ( For example, create a
> stereotype called MyExtendedClass that extends uml:Class ). (see the
> getting
> started article for details ). (Call it My.profile.uml for example)
> 2. ** don't do the "define" step ***
> 3. On your profile, apply the <<ePackage>> stereotype from the existing
> Ecore profile.
> 4. Set the nsURI to something ... say http://www.myOrg/MyProfile
> ------- Generate code ---------
> 1. Create an EMF project as you would from any other .uml model to
> generate
> code from but specify your profile as the source ( My.profile.uml )
> 2. Select the "Process All" options when loading your My.profile.uml.
> 3. Generate code as you would normally from the resulting .genmodel.
> ------- Using your profile ------
> Up to this point, things were pretty easy. Here comes the tricky part...
> 1. Move your previously generated code for your profile to your
> development
> environment.
> 2. Create a new plugin in your development environment ( say a JUnit
> plugin
> to get started with ).
> 3. In your JUnit plugin test, add the line:
> UMLPlugin.getEPackageNsURIToProfileLocationMap().put(http://www.myOrg.com/My
> Profile, URI.createURI( ... path to My.profile.uml#_XXX")); where XXX is
> the
> id of the profile in your model.
> 4. Create a resource set and load your My.profile.uml.
> 5. Next, Load your profile using..
> Profile myProfile = UMLUtil.getProfile(MyProfilePackage.eINSTANCE,
> from the already generated MyProfilePackage from the "Generate Code"
> step.
> 6. Next, obtain your stereotype with..
> Stereotype myStereotype =
> myProfile.getOwnedStereotype("MyExtendedClass");
> 7. This is the interesting part ... Apply your stereotype as follows:
> MyExtendedClass myExtendedClass =
> (MyExtendedClass)myClass.applyStereotype(myStereotype);
> Notice how you do not get a stereotype application but rather a type
> of
> "MyExtendedClass".
> 8. Now you have full access to setting variagbles to MyExtendedClass etc.
> --- how cool is that ;) ----
> and couldn't get it running. The reason is that
> package_.applyProfile(myProfile); calls ProfileOperations: EPackage
> getDefinition(Profile profile). This calls getTaggedValue(package_,
> "Ecore" ... which -since I skipped the the define step (2)- is always
> not there (null).
> I've attached my test code and the .profile.uml.
> For online-viewing, see http://rafb.net/p/9BbS1L94.html
> The result of the code is:
> org.eclipse.uml2.uml.internal.impl.ProfileImpl@1f195fc (name: My,
> visibility: <unset>) (visibility: public)
> org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@1afd9cc (eClass:
> org.eclipse.emf.ecore.impl.EClassImpl@3e926 (name: EPackage)
> (instanceClassName: null) (abstract: false, interface: false)) (mixed:
> [], anyAttribute: [base_Package=_EVrQ0MicEdyuvNC82dJYdg,
> packageName=myProf, nsURI=http://www.my.org/Profile])
> myProfile: org.eclipse.uml2.uml.internal.impl.ProfileImpl@1f195fc (name:
> My, visibility: <unset>) (visibility: public)
> java.lang.IllegalArgumentException:
> at
> org.eclipse.uml2.uml.internal.operations.PackageOperations.a pplyProfile(PackageOperations.java:524)
> at
> org.eclipse.uml2.uml.internal.impl.PackageImpl.applyProfile( PackageImpl.java:1051)
> at test.StaticProfile.testProfile(StaticProfile.java:102)
> Stereotypes
> at test.StaticProfile.main(StaticProfile.java:32
> What am I doing wrong?
> -stefan
> <xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:Ecore="http://www.eclipse.org/uml2/schemas/Ecore/4"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
> xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML"
> xsi:schemaLocation="http://www.eclipse.org/uml2/schemas/Ecore/4
> pathmap://UML_PROFILES/Ecore.profile.uml#_B7dOIMEREduRdatXod jBjA">
> <uml:Profile xmi:id="_12_5_1_15200e0_1191951371278_589868_232"
> name="GuiProfile" metamodelReference="_0metamodelReferenceGUI_OiO">
> <packageImport xmi:id="_0metamodelReferenceGUI_OiO">
> <importedPackage xmi:type="uml:Model"
> href="pathmap://UML_METAMODELS/UML.metamodel.uml#_0"/>
> </packageImport>
> <packageImport xmi:id="_0primitiveTypesGUI_OiO">
> href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
> </packageImport>
> <packageImport xmi:id="_0javaPrimitiveTypesGUI_OiO">
> href="pathmap://UML_LIBRARIES/JavaPrimitiveTypes.library.uml#_0"/>
> </packageImport>
> xmi:id="_12_5_1_15200e0_1191951444711_532617_254" name="UIControl"
> isAbstract="true">
> <ownedAttribute xmi:id="_12_5_1_15200e0_1191951461747_586671_257"
> association="_12_5_1_15200e0_1191951461742_136617_256">
> href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
> </ownedAttribute>
> <ownedAttribute xmi:id="_12_5_1_15200e0_1191951497116_308118_278"
> name="name" visibility="public">
> <type xmi:type="uml:PrimitiveType"
> href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
> xmi:id="_12_5_1_15200e0_1191951511530_812133_281" name="" value="1"/>
> xmi:id="_12_5_1_15200e0_1191951511530_782080_280" name="" value="1"/>
> </ownedAttribute>
> </packagedElement>
> xmi:id="_12_5_1_15200e0_1191951461742_136617_256" name=""
> memberEnd="_12_5_1_15200e0_1191951461749_945624_258
> _12_5_1_15200e0_1191951461747_586671_257">
> xmi:id="_12_5_1_15200e0_1191951461749_945624_258" name="extension_"
> visibility="private" type="_12_5_1_15200e0_1191951444711_532617_254"
> xmi:id="_12_5_1_15200e0_1191951461750_90795_260" name="" value="1"/>
> xmi:id="_12_5_1_15200e0_1191951461749_924987_259" name=""/>
> </ownedEnd>
> </packagedElement>
> xmi:id="_12_5_1_15200e0_1191951577864_290094_283" name="UIContainerType">
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951609693_223765_302"
> name="COMPOSITE"/>
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951633949_930543_304"
> name="SECTION"/>
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951641341_712694_306"
> name="DIALOG"/>
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951647549_41585_308"
> name="WIZARD"/>
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951654389_673842_310"
> name="VIEW"/>
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951660149_296674_312"
> name="TABFOLDER"/>
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951669877_167411_314"
> name="GROUP"/>
> <ownedLiteral xmi:id="_12_5_1_15200e0_1191951677165_910462_316"
> name="SCREEN"/>
> </packagedElement>
> xmi:id="_12_5_1_15200e0_1191951690312_464217_319" name="UIContainer">
> <generalization xmi:id="_12_5_1_15200e0_1191951750360_472032_346"
> <ownedAttribute xmi:id="_12_5_1_15200e0_1191951692820_263208_322"
> </ownedAttribute>
> <ownedAttribute xmi:id="_12_5_1_15200e0_1191951718334_382224_343"
> type="_12_5_1_15200e0_1191951577864_290094_283">
> xmi:id="_12_5_1_15200e0_1191952749590_789899_785" name="" value="1"/>
> xmi:id="_12_5_1_15200e0_1191952749590_588235_784" name="" value="1"/>
> </ownedAttribute>
> </packagedElement>
> xmi:id="_12_5_1_15200e0_1191951692820_933016_321" name=""
> memberEnd="_12_5_1_15200e0_1191951692820_263208_322
> _12_5_1_15200e0_1191951692821_296714_323">
> xmi:id="_12_5_1_15200e0_1191951692821_296714_323" name="extension_"
> visibility="private" type="_12_5_1_15200e0_1191951690312_464217_319"
> association="_12_5_1_15200e0_1191951692820_933016_321">
> xmi:id="_12_5_1_15200e0_1191951692821_920088_325" name="" value="1"/>
> xmi:id="_12_5_1_15200e0_1191951692821_171918_324" name=""/>
> </ownedEnd>
> </packagedElement>
> xmi:id="_12_5_1_15200e0_1191951761873_224879_371" name="UIDataControl"
> isAbstract="true">
> <generalization xmi:id="_12_5_1_15200e0_1191951789855_785392_447"
> general="_12_5_1_15200e0_1191951444711_532617_254"/>
> <ownedAttribute xmi:id="_12_5_1_15200e0_1191951767428_923400_374"
> </ownedAttribute>
> </packagedElement>
> xmi:id="_12_5_1_15200e0_1191951767428_598809_373" name=""
> memberEnd="_12_5_1_15200e0_1191951767428_923400_374
> _12_5_1_15200e0_1191951767428_297656_375">
> xmi:id="_12_5_1_15200e0_1191951767428_297656_375" name="extension_"
> visibility="private" type="_12_5_1_15200e0_1191951761873_224879_371"
> association="_12_5_1_15200e0_1191951767428_598809_373">
> xmi:id="_12_5_1_15200e0_1191951767429_574722_377" name="" value="1"/>
> xmi:id="_12_5_1_15200e0_1191951767429_117114_376" name=""/>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="TABLE"/>
> name="TREE"/>
> name="LIST"/>
> name="FORM"/>
> name="EDITOR"/>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> <type xmi:type="uml:Class"
> href="pathmap://UML_METAMODELS/UML.metamodel.uml#Association"/>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> </ownedAttribute>
> </ownedAttribute>
> </packagedElement>
> </ownedEnd>
> </packagedElement>
> name="BUTTON"/>
> name="TEXT"/>
> name="LABEL"/>
> </packagedElement>
> </eAnnotations>
> </uml:Profile>
> </xmi:XMI>
> package test;
> try {
> testProfile();
> // uml init
> // uml init ()
> // uml bsp data
> // uml bsp data()
> } else{
> try{
> // save
> try {
> resi.save(null);
Re: static profiles - not working ;) [message #625933 is a reply to message #476878] |
Stefan Kuhn Messages: 355 Registered: July 2009 |
-stefan
James Bruck wrote:
> - James.
>> hi all,
>> getting
>> Ecore profile.
>> generate
>> development
>> environment.
>> plugin
>> the
>> step.
>> of
>> "MyExtendedClass".
>> not there (null).
>> at
>> at
>> Stereotypes
>> -stefan
>> </packageImport>
>> </packageImport>
>> </packageImport>
>> isAbstract="true">
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="COMPOSITE"/>
>> name="SECTION"/>
>> name="DIALOG"/>
>> name="WIZARD"/>
>> name="VIEW"/>
>> name="TABFOLDER"/>
>> name="GROUP"/>
>> name="SCREEN"/>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> isAbstract="true">
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191952240606_445519_606" name="children
>> UIContainer->UIControl">
>> <ownedAttribute xmi:id="_12_5_1_15200e0_1191952252681_709833_609"
>> association="_12_5_1_15200e0_1191952252680_904621_608">
>> </ownedAttribute>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191952252680_904621_608" name=""
>> memberEnd="_12_5_1_15200e0_1191952252681_480707_610
>> _12_5_1_15200e0_1191952252681_709833_609">
>> xmi:id="_12_5_1_15200e0_1191952252681_480707_610" name="extension_"
>> visibility="private" type="_12_5_1_15200e0_1191952240606_445519_606"
>> xmi:id="_12_5_1_15200e0_1191952252681_30153_612" name="" value="1"/>
>> xmi:id="_12_5_1_15200e0_1191952252681_804516_611" name=""/>
>> </ownedEnd>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191952434982_520771_645"
>> name="UIComplexDataControlType">
>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191952449406_918649_664"
>> name="TABLE"/>
>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191952466006_58192_666"
>> name="TREE"/>
>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191952472486_54160_668"
>> name="LIST"/>
>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191952480478_349858_670"
>> name="FORM"/>
>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191952487294_895150_672"
>> name="EDITOR"/>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191952552688_338708_675"
>> name="dataControlChildren UIComplexDataControl->UIDataControl">
>> <ownedAttribute xmi:id="_12_5_1_15200e0_1191952555379_166950_678"
>> association="_12_5_1_15200e0_1191952555379_305362_677">
>> </ownedAttribute>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191952555379_305362_677" name=""
>> memberEnd="_12_5_1_15200e0_1191952555380_36450_679
>> _12_5_1_15200e0_1191952555379_166950_678">
>> xmi:id="_12_5_1_15200e0_1191952555380_36450_679" name="extension_"
>> visibility="private" type="_12_5_1_15200e0_1191952552688_338708_675"
>> xmi:id="_12_5_1_15200e0_1191952555380_894856_681" name="" value="1"/>
>> xmi:id="_12_5_1_15200e0_1191952555380_129948_680" name=""/>
>> </ownedEnd>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191952642401_691287_756"
>> name="UIComplexDataControl">
>> <generalization xmi:id="_12_5_1_15200e0_1191952806356_666989_789"
>> <ownedAttribute xmi:id="_12_5_1_15200e0_1191952645284_114215_759"
>> </ownedAttribute>
>> <ownedAttribute xmi:id="_12_5_1_15200e0_1191952721352_812895_780"
>> type="_12_5_1_15200e0_1191952434982_520771_645">
>> xmi:id="_12_5_1_15200e0_1191952793559_45663_787" name="" value="1"/>
>> xmi:id="_12_5_1_15200e0_1191952793558_859189_786" name="" value="1"/>
>> </ownedAttribute>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191952645284_484596_758" name=""
>> memberEnd="_12_5_1_15200e0_1191952645284_114215_759
>> _12_5_1_15200e0_1191952645284_100915_760">
>> xmi:id="_12_5_1_15200e0_1191952645284_100915_760" name="extension_"
>> visibility="private" type="_12_5_1_15200e0_1191952642401_691287_756"
>> association="_12_5_1_15200e0_1191952645284_484596_758">
>> xmi:id="_12_5_1_15200e0_1191952645284_649162_762" name="" value="1"/>
>> xmi:id="_12_5_1_15200e0_1191952645284_136129_761" name=""/>
>> </ownedEnd>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191953026669_238956_938" name="complexDataControl
>> UIDataControl->UIComplexDataControl">
>> <ownedAttribute xmi:id="_12_5_1_15200e0_1191953028759_239041_941"
>> name="base_Association" visibility="private"
>> </ownedAttribute>
>> </packagedElement>
>> xmi:id="_12_5_1_15200e0_1191953028759_918634_940" name=""
>> memberEnd="_12_5_1_15200e0_1191953028759_804402_942
>> _12_5_1_15200e0_1191953028759_239041_941">
>> xmi:id="_12_5_1_15200e0_1191953028759_804402_942" name="extension_"
>> visibility="private" type="_12_5_1_15200e0_1191953026669_238956_938"
>> association="_12_5_1_15200e0_1191953028759_918634_940">
>> xmi:id="_12_5_1_15200e0_1191953028759_852543_944" name="" value="1"/>
>> </ownedEnd>
>> </packagedElement>
>> </ownedAttribute>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedEnd>
>> </packagedElement>
>> name="BUTTON"/>
>> name="TEXT"/>
>> name="LABEL"/>
>> </packagedElement>
>> </eAnnotations>
>> </uml:Profile>
>> </xmi:XMI>
>> package test;
>> try {
>> testProfile();
>> // uml init
>> // uml init ()
>> // uml bsp data
>> // uml bsp data()
>> } else{
>> try{
>> // save
>> try {
>> resi.save(null);
Re: static profiles - not working ;) [message #625939 is a reply to message #476879] |
Hi Stefan,
- James.
> didn't work.
> -stefan
> James Bruck wrote:
>> Hi,
>> - James.
>>> hi all,
>>> getting
>>> Ecore profile.
>>> generate
>>> part...
>>> development
>>> environment.
>>> plugin
>>> the
>>> step.
>>> of
>>> "MyExtendedClass".
>>> etc.
>>> not there (null).
>>> at
>>> at
>>> Stereotypes
>>> -stefan
>>> </packageImport>
>>> </packageImport>
>>> </packageImport>
>>> <packagedElement xmi:type="uml:Stereotype"
>>> isAbstract="true">
>>> name="base_Class" visibility="private"
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="COMPOSITE"/>
>>> name="SECTION"/>
>>> name="DIALOG"/>
>>> name="WIZARD"/>
>>> name="VIEW"/>
>>> name="TABFOLDER"/>
>>> name="GROUP"/>
>>> name="SCREEN"/>
>>> </packagedElement>
>>> isSubstitutable="false"
>>> </ownedAttribute>
>>> name="type" visibility="public"
>>> </ownedAttribute>
>>> </packagedElement>
>>> <packagedElement xmi:type="uml:Extension"
>>> <ownedEnd xmi:type="uml:ExtensionEnd"
>>> </ownedEnd>
>>> </packagedElement>
>>> isAbstract="true">
>>> </ownedAttribute>
>>> </packagedElement>
>>> aggregation="composite"
>>> </ownedEnd>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </packagedElement>
>>> <upperValue xmi:type="uml:LiteralUnlimitedNatural"
>>> </ownedEnd>
>>> </packagedElement>
>>> name="TABLE"/>
>>> name="TREE"/>
>>> name="LIST"/>
>>> name="FORM"/>
>>> name="EDITOR"/>
>>> </packagedElement>
>>> </ownedAttribute>
>>> </packagedElement>
>>> <lowerValue xmi:type="uml:LiteralInteger"
>>> </ownedEnd>
>>> </packagedElement>
>>> general="_12_5_1_15200e0_1191951761873_224879_371"/>
>>> </ownedAttribute>
>>> </ownedAttribute>
>>> </packagedElement>
>>> </ownedEnd>
>>> </packagedElement>
>>> name="complexDataControl UIDataControl->UIComplexDataControl">
>>> </ownedAttribute>
>>> </packagedElement>
>>> xmi:id="_12_5_1_15200e0_1191953028759_777965_943" name=""/>
>>> </ownedEnd>
>>> </packagedElement>
>>> xmi:id="_12_5_1_15200e0_1191953113254_841091_964"
>>> name="UIPrimitiveDataControl">
>>> <generalization xmi:id="_12_5_1_15200e0_1191953338087_458822_1019"
>>> <ownedAttribute xmi:id="_12_5_1_15200e0_1191953116891_548625_967"
>>> association="_12_5_1_15200e0_1191953116891_964982_966">
>>> </ownedAttribute>
>>> <ownedAttribute xmi:id="_12_5_1_15200e0_1191953185029_1046_1014"
>>> type="_12_5_1_15200e0_1191953126646_606954_989">
>>> xmi:id="_12_5_1_15200e0_1191953279608_844377_1017" name="" value="1"/>
>>> xmi:id="_12_5_1_15200e0_1191953279608_801287_1016" name="" value="1"/>
>>> </ownedAttribute>
>>> </packagedElement>
>>> xmi:id="_12_5_1_15200e0_1191953116891_964982_966" name=""
>>> memberEnd="_12_5_1_15200e0_1191953116892_385941_968
>>> _12_5_1_15200e0_1191953116891_548625_967">
>>> xmi:id="_12_5_1_15200e0_1191953116892_385941_968" name="extension_"
>>> visibility="private" type="_12_5_1_15200e0_1191953113254_841091_964"
>>> xmi:id="_12_5_1_15200e0_1191953116892_279445_970" name="" value="1"/>
>>> xmi:id="_12_5_1_15200e0_1191953116892_356906_969" name=""/>
>>> </ownedEnd>
>>> </packagedElement>
>>> <packagedElement xmi:type="uml:Enumeration"
>>> xmi:id="_12_5_1_15200e0_1191953126646_606954_989"
>>> name="UIPrimitiveDataControlType">
>>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191953148501_880223_1008"
>>> name="BUTTON"/>
>>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191953162205_626311_1010"
>>> name="TEXT"/>
>>> <ownedLiteral xmi:id="_12_5_1_15200e0_1191953167709_704400_1012"
>>> name="LABEL"/>
>>> </packagedElement>
>>> <profileApplication xmi:id="_P9oBoMhrEdyBsvVY6aeXSQ">
>>> <eAnnotations xmi:id="_P-C4YMhrEdyBsvVY6aeXSQ"
>>> source="http://www.eclipse.org/uml2/2.0.0/UML">
>>> <references xmi:type="ecore:EPackage"
>>> href=" pathmap://UML_PROFILES/Ecore.profile.uml#_B7dOIMEREduRdatXod jBjA"/>
>>> </eAnnotations>
>>> <appliedProfile
>>> href="pathmap://UML_PROFILES/Ecore.profile.uml#_0"/>
>>> </profileApplication>
>>> </uml:Profile>
>>> <Ecore:EPackage xmi:id="_bRkbEMhrEdyBsvVY6aeXSQ"
>>> base_Package="_12_5_1_15200e0_1191951371278_589868_232"
>>> packageName="guiProfile" nsPrefix="guiProfileNS"
>>> nsURI="http://www.oio.de/mdsd/tools/guiModel/guiProfile"
>>> basePackage="de.oio.mdsd.tools.guiModel" prefix="GUI_OIO"/>
>>> </xmi:XMI>
>>> package test;
>>> import java.io.IOException;
>>> import java.util.Map;
>>> import myProf.MyClass;
>>> import myProf.MyProfPackage;
>>> import org.eclipse.emf.common.EMFPlugin;
>>> import org.eclipse.emf.common.util.URI;
>>> import org.eclipse.emf.ecore.EObject;
>>> import org.eclipse.emf.ecore.EPackage.Registry;
>>> import org.eclipse.emf.ecore.resource.Resource;
>>> import org.eclipse.emf.ecore.resource.ResourceSet;
>>> import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
>>> import org.eclipse.emf.ecore.util.EcoreUtil;
>>> import org.eclipse.uml2.uml.Class;
>>> import org.eclipse.uml2.uml.Package;
>>> import org.eclipse.uml2.uml.Profile;
>>> import org.eclipse.uml2.uml.Stereotype;
>>> import org.eclipse.uml2.uml.UMLFactory;
>>> import org.eclipse.uml2.uml.UMLPackage;
>>> import org.eclipse.uml2.uml.UMLPlugin;
>>> import org.eclipse.uml2.uml.resource.UMLResource;
>>> import org.eclipse.uml2.uml.util.UMLUtil;
>>> public class StaticProfile {
>>> public static void main(String[] args){
>>> try {
>>> testProfile();
>>> } catch (Exception e) {
>>> e.printStackTrace();
>>> private final static String workspace =
>>> "/home/qn/Coden/workspace-oAW/umlStatic/model/My.profile.uml ";
>>> // private final static String runtime =
>>> " /home/qn/Coden/runtime-New_configuration/umlStatic/model/My. profile.uml ";
>>> private final static String testModel =
>>> " /home/qn/Coden/runtime-New_configuration/umlStatic.test/src/ test/model.uml ";
>>> private final static String umlJarLoc =
>>> " jar:file://home/qn/Coden/eclipse-oAW/plugins/org.eclipse.uml 2.uml.resources_2.1.0.v200706251652.jar!/";
>>> private final static String path2profile = workspace;
>>> // private final static String profileEPackageName = "myProf";
>>> private final static String profileNS = MyProfPackage.eNS_URI;
>>> //"http://www.my.org/Profile";
>>> private final static String suffix = "#_EVrQ0MicEdyuvNC82dJYdg";
>>> private static void testProfile() {
>>> System.out.println(">>>>>>>>>>>>>");
>>> System.out.println();
>>> UMLPlugin.getEPackageNsURIToProfileLocationMap().put(profile EPackageName,
>>> URI.createURI(path2profile+suffix));
>>> URI.createURI(path2profile));
>>> UMLPlugin.getEPackageNsURIToProfileLocationMap().put(profile NS,
>>> // UMLPlugin.getEPackageNsURIToProfileLocationMap().put(profile NS,
>>> // Map<String, URI> nsURI2ProfileMap =
>>> UMLPlugin.getEPackageNsURIToProfileLocationMap();
>>> // uml init
>>> ResourceSet resourceSet = new ResourceSetImpl();
>>> resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
>>> UMLPackage.eINSTANCE);
>>> resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
>>> UMLResource.Factory.INSTANCE);
>>> Map<URI, URI> uriMap = resourceSet.getURIConverter().getURIMap();
>>> URI uri = URI.createURI(umlJarLoc);
>>> uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP),
>>> uri.appendSegment("libraries").appendSegment(""));
>>> uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP),
>>> uri.appendSegment("metamodels").appendSegment(""));
>>> uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP),
>>> uri.appendSegment("profiles").appendSegment(""));
>>> Map<String,Object> p2fMap =
>>> resourceSet.getResourceFactoryRegistry().getProtocolToFactor yMap();
>>> // uml init ()
>>> // Resource testResi =
>>> resourceSet.getResource(URI.createURI(path2profile+suffix), true);
>>> // System.out.println("Content of TestResi");
>>> // for(EObject obj : testResi.getContents()){
>>> // System.out.println(obj);
>>> Resource resi =
>>> resourceSet.createResource(URI.createFileURI(testModel));
>>> Resource profileResi =
>>> resourceSet.getResource(URI.createFileURI(path2profile), true);
>>> System.out.println("Content of ProfileResi");
>>> for(EObject obj : profileResi.getContents()){
>>> // uml bsp data
>>> Package package_ = UMLFactory.eINSTANCE.createPackage();
>>> resi.getContents().add(package_);
>>> package_.setName("MeinPacket");
>>> Class clazz = UMLFactory.eINSTANCE.createClass();
>>> clazz.setPackage(package_);
>>> clazz.setName("MeineKlasse2");
>>> // uml bsp data()
>>> Profile myProfile =
>>> UMLUtil.getProfile(MyProfPackage.eINSTANCE,package_);
>>> if(myProfile==null){
>>> System.out.println("myProfile==null");
>>> } else{
>>> System.out.println("myProfile: "+myProfile);
>>> try{
>>> System.out.println("Profile could not be applied");
>>> System.out.println("\nStereotypes");
>>> for(Stereotype stereo : clazz.getApplicableStereotypes()){
>>> System.out.println(stereo);
>>> // save
>>> try {
>>> resi.save(null);
>>> } catch (IOException e) {
Re: static profiles - not working ;) [message #625941 is a reply to message #476883] |
-James.
> Hi Stefan,
> Cheers,
> - James.
>> class didn't work.
>> -stefan
>> James Bruck wrote:
>>> Hi,
>>> - James.
>>> news:fn4umc$q8s$1@build.eclipse.org...
>>>> hi all,
>>>> a
>>>> getting
>>>> Ecore profile.
>>>> generate
>>>> part...
>>>> development
>>>> environment.
>>>> plugin
>>>> is the
>>>> step.
>>>> follows:
>>>> type of
>>>> "MyExtendedClass".
>>>> etc.
>>>> not there (null).
>>>> (name:
>>>> at
>>>> at
>>>> Stereotypes
>>>> -stefan
>>>> </packageImport>
>>>> </packageImport>
>>>> </packageImport>
>>>> isAbstract="true">
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="COMPOSITE"/>
>>>> name="SECTION"/>
>>>> name="DIALOG"/>
>>>> name="WIZARD"/>
>>>> name="VIEW"/>
>>>> name="TABFOLDER"/>
>>>> name="GROUP"/>
>>>> name="SCREEN"/>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> isAbstract="true">
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="TABLE"/>
>>>> name="TREE"/>
>>>> name="LIST"/>
>>>> name="FORM"/>
>>>> name="EDITOR"/>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> </ownedAttribute>
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </ownedEnd>
>>>> </packagedElement>
>>>> name="BUTTON"/>
>>>> name="TEXT"/>
>>>> name="LABEL"/>
>>>> </packagedElement>
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> </uml:Profile>
>>>> </xmi:XMI>
>>>> package test;
>>>> try {
>>>> testProfile();
>>>> // uml init
>>>> // uml init ()
>>>> Resource resi =
>>>> // uml bsp data
>>>> // uml bsp data()
>>>> Profile myProfile =
>>>> } else{
>>>> try{
>>>> // save
>>>> try {
>>>> resi.save(null);
Re: static profiles - not working ;) [message #625944 is a reply to message #476885] |
-stefan
> Cheers,
> -James.
>> Hi Stefan,
>> Cheers,
>> - James.
>>> class didn't work.
>>> -stefan
>>> James Bruck wrote:
>>>> Hi,
>>>> - James.
>>>>> hi all,
>>>>> a
>>>>> getting
>>>>> Ecore profile.
>>>>> generate
>>>>> part...
>>>>> development
>>>>> environment.
>>>>> plugin
>>>>> is the
>>>>> step.
>>>>> follows:
>>>>> type of
>>>>> "MyExtendedClass".
>>>>> etc.
>>>>> not there (null).
>>>>> (name:
>>>>> at
>>>>> at
>>>>> Stereotypes
>>>>> -stefan
>>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> </packageImport>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="COMPOSITE"/>
>>>>> name="SECTION"/>
>>>>> name="DIALOG"/>
>>>>> name="WIZARD"/>
>>>>> name="VIEW"/>
>>>>> name="TABFOLDER"/>
>>>>> name="GROUP"/>
>>>>> name="SCREEN"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> isAbstract="true">
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="TABLE"/>
>>>>> name="TREE"/>
>>>>> name="LIST"/>
>>>>> name="FORM"/>
>>>>> name="EDITOR"/>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> </ownedAttribute>
>>>>> </ownedAttribute>
>>>>> </packagedElement>
>>>>> </ownedEnd>
>>>>> </packagedElement>
>>>>> name="BUTTON"/>
>>>>> name="TEXT"/>
>>>>> name="LABEL"/>
>>>>> </packagedElement>
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> </uml:Profile>
>>>>> </xmi:XMI>
>>>>> package test;
>>>>> try {
>>>>> testProfile();
>>>>> // uml init
>>>>> // uml init ()
>>>>> Resource resi =
>>>>> // uml bsp data
>>>>> // uml bsp data()
>>>>> Profile myProfile =
>>>>> } else{
>>>>> try{
>>>>> // save
>>>>> try {
>>>>> resi.save(null);
Re: static profiles - not working ;) [message #625948 is a reply to message #476888] |
- James
> -stefan
>> Cheers,
>> -James.
>>> Hi Stefan,
>>> Cheers,
>>> - James.
>>>> -stefan
>>>> James Bruck wrote:
>>>>> Hi,
>>>>> - James.
>>>>>> hi all,
>>>>>> create a
>>>>>> getting
>>>>>> existing
>>>>>> Ecore profile.
>>>>>> generate
>>>>>> part...
>>>>>> development
>>>>>> environment.
>>>>>> plugin
>>>>>> is the
>>>>>> Profile myProfile =
>>>>>> Code"
>>>>>> step.
>>>>>> follows:
>>>>>> type of
>>>>>> "MyExtendedClass".
>>>>>> etc.
>>>>>> not there (null).
>>>>>> (mixed:
>>>>>> (name:
>>>>>> at
>>>>>> at
>>>>>> Stereotypes
>>>>>> -stefan
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> </packageImport>
>>>>>> isAbstract="true">
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191951461747_586671_257" name="base_Class"
>>>>>> </ownedAttribute>
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191951497116_308118_278" name="name"
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="COMPOSITE"/>
>>>>>> name="SECTION"/>
>>>>>> name="DIALOG"/>
>>>>>> name="WIZARD"/>
>>>>>> name="VIEW"/>
>>>>>> name="TABFOLDER"/>
>>>>>> name="GROUP"/>
>>>>>> name="SCREEN"/>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191951692820_263208_322" name="base_Class"
>>>>>> </ownedAttribute>
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191951718334_382224_343" name="type"
>>>>>> visibility="public" type="_12_5_1_15200e0_1191951577864_290094_283">
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="UIDataControl" isAbstract="true">
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191951767428_923400_374" name="base_Class"
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="TABLE"/>
>>>>>> name="TREE"/>
>>>>>> name="LIST"/>
>>>>>> name="FORM"/>
>>>>>> name="EDITOR"/>
>>>>>> </packagedElement>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191952645284_114215_759" name="base_Class"
>>>>>> </ownedAttribute>
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191952721352_812895_780" name="type"
>>>>>> visibility="public" type="_12_5_1_15200e0_1191952434982_520771_645">
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <ownedAttribute
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> <generalization
>>>>>> <ownedAttribute
>>>>>> xmi:id="_12_5_1_15200e0_1191953116891_548625_967" name="base_Class"
>>>>>> </ownedAttribute>
>>>>>> value="1"/>
>>>>>> value="1"/>
>>>>>> </ownedAttribute>
>>>>>> </packagedElement>
>>>>>> </ownedEnd>
>>>>>> </packagedElement>
>>>>>> name="BUTTON"/>
>>>>>> name="TEXT"/>
>>>>>> name="LABEL"/>
>>>>>> </packagedElement>
>>>>>> </eAnnotations>
>>>>>> <appliedProfile
>>>>>> </uml:Profile>
>>>>>> </xmi:XMI>
>>>>>> package test;
>>>>>> try {
>>>>>> testProfile();
>>>>>> // uml init
>>>>>> // uml init ()
>>>>>> Resource resi =
>>>>>> // uml bsp data
>>>>>> // uml bsp data()
>>>>>> Profile myProfile =
>>>>>> } else{
>>>>>> try{
>>>>>> // save
>>>>>> try {
>>>>>> resi.save(null);
Current Time: Thu Sep 19 17:37:15 GMT 2024
Powered by FUDForum. Page generated in 0.09952 seconds
