Home » Modeling » UML2 » cmof to emf
Re: cmof to emf [message #476777 is a reply to message #476776] |
Mon, 17 December 2007 18:36 |
Dave Carlson Messages: 402 Registered: July 2009 |
Also, having just generated the model Java code, all class names start with
lower case, e.g. "concept", as defined in the cmof model. Maybe class names
should be mapped to upper-camel-case in the cmof to ecore mapping?
"Dave Carlson" <dcarlson@xmlmodeling.com> wrote in message
news:fk6f48$kf5$1@build.eclipse.org...
>I am using the latest uml2 I-build to open the SBVR cmof model and generate
>and EMF ecore model from it. All seems to work well in my initial testing,
>but the cmof class attribute mapping to emf could use some improvement.
> In the SBVR metamodel, the attribute names use all lower-case with words
> separated by spaces. For example, in the "concept" class, there are
> attributes "more general concept" and "necessary characteristic". In the
> ecore mapping the spaces are removed, yielding attribute names like
> "moregeneralconcept". It would be much better to convert to camel case
> while removing spaces. Any reason not to do this?
> Dave Carlson
Re: cmof to emf [message #476780 is a reply to message #476777] |
Mon, 17 December 2007 19:34 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Dave,
The current algorithm for processing class names is consistent with what EMF
does, i.e. the bare minimum to ensure that the result is a valid Java
identifier. Unfortunately, we can't make changes to the default behavior,
because this same conversion mechanism is used for profile definition and
such changes might have an adverse effect on clients that expect the
existing behavior. These suggestions are useful though; perhaps you could
open an enhacement request in Bugzilla, and we could consider adding a new
option or two to support simple formatting rules to names during the
conversion process...
Kenn
news:fk6fir$n1s$1@build.eclipse.org...
> with lower case, e.g. "concept", as defined in the cmof model. Maybe
> class names should be mapped to upper-camel-case in the cmof to ecore
> mapping?
>>generate and EMF ecore model from it. All seems to work well in my
>>initial testing, but the cmof class attribute mapping to emf could use
>>some improvement.
>> Thanks,
>> Dave Carlson
Re: cmof to emf [message #625750 is a reply to message #476776] |
> Dave Carlson
Re: cmof to emf [message #625753 is a reply to message #476777] |
Dave,
Kenn
> mapping?
>>some improvement.
>> Thanks,
>> Dave Carlson
Current Time: Fri Apr 26 21:33:46 GMT 2024
Powered by FUDForum. Page generated in 0.03966 seconds
