Home » Modeling » UML2 » SequenceNode serialization problem?
Re: SequenceNode serialization problem? [message #476750 is a reply to message #476746] |
Wed, 12 December 2007 19:29 |
Krzysztof Kaczmarski Messages: 88 Registered: July 2009 |
Member |
--------------060808030708010305080301
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
Hi James,
here is sample code and model. I suppose that reverse reference
(inStructuredNode) is not managed by MDT automatically.
In my opinion this code should not return null.
KK
James Bruck wrote:
> Hi Krzysztof,
> Would it be possible to provide a sample model and a snippet of code that
> demonstrates this issue. I would find it really hard to imagine that the
> serialization is getting corrupted or derived collections are not being
> properly created.
> Cheers,
> - James.
> "Krzysztof Kaczmarski" <krzysztof_kaczmarski@o2.pl> wrote in message
> news:fjom1a$bh5$1@build.eclipse.org...
>> Hi All,
>> I have encountered strange problem with SequenceNodes. I nest them and to
>> be able to navigate to parent node I use setInStructuredNode() reference
>> to point one level up. Then I serialize the model. When I read the model
>> again and try to use this parent node reference by
>> getInStructuredNode() I get null.
>> I checked the uml file after serialization. There is no information about
>> this reference in appropriate SequenceNode. Is this correct?
>> Thanks for any ideas,
>> Krzysztof
Content-Type: text/x-java;
name="SimpleTest.java"
Content-Disposition: inline;
filename="SimpleTest.java"
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.common.util.WrappedException;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.uml2.uml.Activity;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.SequenceNode;
import org.eclipse.uml2.uml.UMLFactory;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
public class SimpleTest
public static boolean DEBUG = true;
protected static final ResourceSet RESOURCE_SET = new ResourceSetImpl();
protected static void registerResourceFactories() {
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(
UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
protected static org.eclipse.uml2.uml.Package load(URI uri) {
org.eclipse.uml2.uml.Package package_ = null;
try {
Resource resource = RESOURCE_SET.getResource(uri, true);
package_ = (org.eclipse.uml2.uml.Package) EcoreUtil
.getObjectByType(resource.getContents(),
UMLPackage.Literals.PACKAGE);
} catch (WrappedException we) {
err(we.getMessage());
System.exit(1);
return package_;
protected static void err(String error) {
System.err.println(error);
registerResourceFactories();
Model model = UMLFactory.eINSTANCE.createModel();
model.setName("MyModel");
model = (Model) load( URI.createFileURI("sequenceNodeTest.uml"));
org.eclipse.uml2.uml.Class claz = (Class) model.getPackagedElement( "MyClass" );
System.out.println( claz );
Activity a = (Activity) claz.getOwnedBehavior( "MyActivity" );
System.out.println( a );
SequenceNode s1 = (SequenceNode) a.getNode( "nodeLevel1" );
System.out.println( s1 );
SequenceNode s2 = (SequenceNode) s1.getNode( "nodeLevel2" );
System.out.println( s2 );
System.out.println( "Level 2 -> Level 1 (inStructuredNode) = " + s2.getInStructuredNode() );
Content-Type: text/xml;
name="sequenceNodeTest.uml"
filename="sequenceNodeTest.uml"
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_M8T8cFowEdyn5PgBtndvJg" name="MyModel">
<packagedElement xmi:type="uml:Class" xmi:id="_M8VxoFowEdyn5PgBtndvJg" name="MyClass">
<ownedBehavior xmi:type="uml:Activity" xmi:id="_M8VxoVowEdyn5PgBtndvJg" name="MyActivity">
<node xmi:type="uml:SequenceNode" xmi:id="_M8WYsFowEdyn5PgBtndvJg" name="nodeLevel1">
<executableNode xmi:type="uml:SequenceNode" xmi:id="_WQs5sajkEdy8gcY1EQreGw" name="nodeLevel2"/>
</node>
</ownedBehavior>
</packagedElement>
</uml:Model>
--------------060808030708010305080301--
Re: SequenceNode serialization problem? [message #476761 is a reply to message #476746] |
Sat, 15 December 2007 09:12 |
Member |
--------------090005080607090304090207
Hi James,
Maybe the previous example was not the best to observe what I am
trying to say.
Here is a better one. It contains four sections:
1. model creation
2. model save
3. model load
4. model check
If you comment out model loading you will see that created model
passes check because setInStructuredNode works properly. Saving
section serializes the model. Then when you uncomment loading and
comment out creation and saving you will see that this model after
loading does not contain inStructuredNode reference which was there
before saving.
Is it normal behavior?
If it is normal how can I navigate from nested StructuredNode to
surrounding node?
Krzysztof
James Bruck wrote:
> Hi Krzysztof,
> properly created.
> Cheers,
> - James.
>> Hi All,
>> Krzysztof
import java.io.IOException;
import java.util.Iterator;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.uml2.uml.Element;
import org.eclipse.uml2.uml.util.UMLUtil;
protected static void save(org.eclipse.uml2.uml.Package package_, URI uri) {
Resource resource = RESOURCE_SET.createResource(uri);
EList contents = resource.getContents();
contents.add(package_);
for (Iterator allContents = UMLUtil.getAllContents(package_, true,
false); allContents.hasNext();) {
EObject eObject = (EObject) allContents.next();
if (eObject instanceof Element) {
contents
.addAll(((Element) eObject).getStereotypeApplications());
try {
resource.save(null);
} catch (IOException ioe) {
err(ioe.getMessage());
try {
System.exit(1);
return package_;
Activity a;
SequenceNode s1, s2;
// creating model
org.eclipse.uml2.uml.Class clazz = model.createOwnedClass("MyClass", false);
a= (Activity) clazz.createOwnedBehavior( "MyActivity", UMLPackage.Literals.ACTIVITY );
s1 = (SequenceNode) a.createNode( "nodeLevel1", UMLPackage.Literals.SEQUENCE_NODE);
s1.setInActivity( a );
s2 = (SequenceNode) s1.createNode( "nodeLevel2", UMLPackage.Literals.SEQUENCE_NODE);
s2.setInStructuredNode( s1 );
// saving
save(model, URI.createFileURI("sequenceNodeTest.uml") );
// loading model
//model = (Model) load( URI.createFileURI("sequenceNodeTest.uml"));
// checking
System.out.println( "Level 1 -> Activity (inActivity) = " + s1.getInActivity() );
--------------090005080607090304090207--
Re: SequenceNode serialization problem? [message #476819 is a reply to message #476761] |
Thu, 03 January 2008 15:16 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Krzysztof,
Sorry about the delayed response ... I just got back from vacation. It
looks like your question was answered from your posting of 12/19?
- James.
news:fk05pm$1hp$1@build.eclipse.org...
> Hi James,
> trying to say.
> 1. model creation
> 2. model save
> 3. model load
> 4. model check
> before saving.
> surrounding node?
> Regards,
> Krzysztof
> James Bruck wrote:
>> Hi Krzysztof,
>> properly created.
>> Cheers,
>> - James.
>>> Hi All,
>>> to
>>> about
>>> Krzysztof
> contents
> try {
> try {
> System.exit(1);
> return package_;
> public static void main(String[] args) {
> Activity a;
> // creating model
> false);
> // saving
> // loading model
> // checking
> "MyClass" );
Re: SequenceNode serialization problem? [message #625723 is a reply to message #476746] |
Member |
Hi James,
KK
James Bruck wrote:
> Hi Krzysztof,
> properly created.
> Cheers,
> - James.
>> Hi All,
>> Krzysztof
try {
System.exit(1);
return package_;
</node>
</ownedBehavior>
</packagedElement>
</uml:Model>
Re: SequenceNode serialization problem? [message #625733 is a reply to message #476746] |
Member |
Hi James,
trying to say.
1. model creation
2. model save
3. model load
4. model check
before saving.
surrounding node?
Krzysztof
James Bruck wrote:
> Hi Krzysztof,
> properly created.
> Cheers,
> - James.
>> Hi All,
>> Krzysztof
contents
try {
try {
System.exit(1);
return package_;
Activity a;
// creating model
// saving
// loading model
// checking
Re: SequenceNode serialization problem? [message #625795 is a reply to message #476761] |
Hi Krzysztof,
- James.
> Hi James,
> trying to say.
> 1. model creation
> 2. model save
> 3. model load
> 4. model check
> before saving.
> surrounding node?
> Regards,
> Krzysztof
> James Bruck wrote:
>> Hi Krzysztof,
>> properly created.
>> Cheers,
>> - James.
>>> Hi All,
>>> to
>>> about
>>> Krzysztof
> contents
> try {
> try {
> System.exit(1);
> return package_;
> Activity a;
> // creating model
> false);
> // saving
> // loading model
> // checking
> "MyClass" );
Current Time: Thu Sep 19 13:36:56 GMT 2024
Powered by FUDForum. Page generated in 0.04926 seconds
