Re: xhtml markup in Comment body [message #476736 is a reply to message #476735] |
Tue, 11 December 2007 19:01 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------020506030108010103080309
Dave,
I think you could do it using demand created metadata and embed that
data as an instance of AnyType within the contents feature of an
EAnnotation.
Binding XML to Java
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
UMLResourceFactoryImpl already uses the extended metadata option so I
think it should just work.
Dave Carlson wrote:
> I need to find a way to include "rich text" in UML comment body using xhtml
> markup tags. Only a limited set of tags will be used most of the time
> (e.g., <p> <b> <i> <ul> and maybe <table>). Any suggestions on how to make
> this work using EMF resources?
> Is there a way to load and save UML resources, leaving the xhtml markup as
> DOM elements? Or is it necessary to create an EMF model for xhtml, so that
> UML comments will include a reference to a second xhtml model EObjects? Is
> this even allowed by the UML metamodel?
> I found this w3c work on creating XSD for xhtml. Has anyone attempted an
> EMF model from these schemas?
> Thanks for any advice,
> Dave Carlson
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Dave,<br>
<br>
EAnnotation.<br>
<blockquote><a target="_out"
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava">Binding
XML to Java</a><br>
</blockquote>
think it should just work.<br>
<br>
<br>
Dave Carlson wrote:
<blockquote cite="mid:fjmmev$jjt$1@build.eclipse.org" type="cite">
<pre wrap="">I need to find a way to include "rich text" in UML comment body using xhtml
Dave Carlson
</pre>
</blockquote>
<br>
</body>
</html>
--------------020506030108010103080309--
Ed Merks
Re: xhtml markup in Comment body [message #625709 is a reply to message #476735] |
Dave,
EAnnotation.
Binding XML to Java
> Dave Carlson
<html>
<head>
</head>
Dave,<br>
<br>
EAnnotation.<br>
XML to Java</a><br>
</blockquote>
<br>
<br>
Dave Carlson
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
FUDForum. Page generated in 0.02876 seconds
