Home » Modeling » UML2 Tools » getAllAppliedProfile
getAllAppliedProfile [message #476605] |
Wed, 22 July 2009 06:59 |
I want to get the profile applied to my model with the function
"getAllAppliedProfiles" I obtain the list here under but when I use the
function "getOwnedStereotypes()" on these profiles I obtain an empty
list.I work with papyrus and my code to load my model is also here under.
getAllAppliedProfiles :
[org.eclipse.uml2.uml.internal.impl.ProfileImpl@2f0d54 (eProxyURI:
pathmap://UML_PROFILES/Standard.profile.uml#_0),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@1961581 (eProxyURI:
resources/MARTE.profile.uml#_EIfnABJeEdy3Td9UhuLFPg),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@113beb5 (eProxyURI:
resources/MARTE.profile.uml#_5ZCOIAPMEdyuUt-4qHuVvQ),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@193f6e2 (eProxyURI:
resources/MARTE.profile.uml#_yNSZIAPMEdyuUt-4qHuVvQ),
org.eclipse.uml2.uml.internal.impl.ProfileImpl@1e13e07 (eProxyURI:
resources/MARTE.profile.uml#_A_vtYBJeEdy3Td9UhuLFPg)]
my code:
URI uri = URI.createURI("essai2/essai2.uml");
try {
ResourceSetImpl resourceSet = new ResourceSetImpl();
// Plug in UML model loader (package and file extension recognition)
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
UMLResource resource = (UMLResource) resourceSet.getResource(uri, true);
Model mod=(Model)EcoreUtil.getObjectByType(((Resource)
resource).getContents(), UMLPackage.eINSTANCE.getModel());
System.out.println(mod.getAllAppliedProfiles());
System.out.println(mod.getAllAppliedProfiles().get(1).getOwn edStereotypes());
} catch (WrappedException we) {
we.printStackTrace();
System.exit(1);
Aurélie
Re: getAllAppliedProfile [message #476607 is a reply to message #476605] |
Thu, 23 July 2009 11:57 |
Tatiana Fesenko Messages: 530 Registered: July 2009 |
Hello Aurélie,
The given code looks correct.
You can check it by printing owned stereotypes of Standard.profile.uml:
System.out.println(mod.getAllAppliedProfiles().get(0).getOwn edStereotypes());
Note, that I take the first, not second, profile here: #get(0).
Can it happen that there are no stereotypes in your profiles?
BTW, this is UML2 Tools newsgroup. Papyrus has its own newsgroup -- http://www.eclipse.org/newsportal/thread.php?group=eclipse.p apyrus.
Best wishes,
Tanya.
> the function "getOwnedStereotypes()" on these profiles I obtain an
> empty list.I work with papyrus and my code to load my model is also
> here under.
> my code:
> public static void main(String[] args) {
> try {
> recognition)
> true);
> pes());
> System.exit(1);
> Aurélie
Re: getAllAppliedProfile [message #476612 is a reply to message #476607] |
Thu, 23 July 2009 14:29 |
Thank you for answering me.
My first try was with the standard profile (get(0)) and I had the same
problem (the list is empty). the problem seems a problem with loading. I
will post my question on papyrus forum.
Aurélie
Re: getAllAppliedProfile [message #624652 is a reply to message #476605] |
Hello Aurélie,
Best wishes,
Tanya.
> here under.
> my code:
> try {
> recognition)
> true);
> pes());
> System.exit(1);
> Aurélie
Re: getAllAppliedProfile [message #624657 is a reply to message #476607] |
Aurélie
Current Time: Fri Apr 26 17:47:26 GMT 2024
Powered by FUDForum. Page generated in 0.03295 seconds
