Home » Modeling » UML2 Tools » Problem installing uml plug-in via update manager
Problem installing uml plug-in via update manager [message #476466] Thu, 07 May 2009 04:22 Go to next message
I am trying to install the uml2 plug in via the update manager and I have
a the following 'unsatisfied dependency' problem (this is jsut a part of
my Details view):
Cannot complete the request. See the details.
Unsatisfied dependency: [org.eclipse.uml2.diagram.feature.group
0.9.0.v200903192032] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.gmf.runtime.diagram.ui .properties/0.0.0
org.eclipse.equinox.p2.iu/org.eclipse.gmf.runtime.draw2d.ui/ 0.0.0
I am using the Glassfish Tools Bundle for Eclipse.
I added the MDT Update site in my Eclipse Update Manager and from MDT
UML2TOOLs SDK, I tried to install UML2Diagramming and UML2 Tools. Is there
something I should have installed before installing these two?
Also, I'd like to ask if these two plug ins suffice for my purposes - I
only want to generate diagrams from an existing Java code?
Thanks a lot!
Geri
Re: Problem installing uml plug-in via update manager [message #476482 is a reply to message #476466] Thu, 14 May 2009 12:08 Go to previous message
Hi Geri,
> my Details view):
UML2Tools requires the following components to be installed:
EMF - Eclipse Modeling Framework Core Runtime
EMF Common
EMF Common UI
EMF Ecore Edit
EMF Edit
EMF Edit UI
EMF Model Query
EMF Model Transaction
EMF Validation Framework
Graphical Editing Framework GEF
Graphical Editing Framework Draw2d
Graphical Modeling Framework Runtime
EMF Model Transaction Workbench Integration
Graphical Modeling Framework Notation
Third-Party Components for GMF Runtime
Object Constraint Language (OCL) 2.0 Compatibility
UML2 End-User Features
The good news is that the components will be installed automatically if checkbox
'Contact all update sites during install to find required software' from
the first page of the update manager is enabled. I used Eclipse 3.5M7.
No, UML2Tools doesn't support reverse ingineering.
Best wishes,
Tanya.
Re: Problem installing uml plug-in via update manager [message #623885 is a reply to message #476466] Thu, 14 May 2009 12:08 Go to previous message
Hi Geri,
> my Details view):
EMF Common
EMF Common UI
EMF Ecore Edit
EMF Edit
EMF Edit UI
EMF Model Query
Best wishes,
Tanya.
Previous Topic:[CompositeStructuresD] InstanceSpecification with slots as boxes
Next Topic:Suggestion for UML2 newbie?
Current Time: Wed Nov 05 11:33:24 EST 2025
Powered by FUDForum. Page generated in 0.04419 seconds
