Template Parameter Binding to UML Classes and Ecore Primitive Types [message #476367] |
Fri, 03 April 2009 03:29 |
John T.E. Timm Messages: 161 Registered: July 2009 |
I have defined a template class and would like to bind the template
parameter to other classes in my model and to some of the Ecore Primitive
Types that ultimately map to Java classes (e.g. EBooleanObject,
EIntegerObject, EDoubleObject, etc.). With these Ecore types being modeled
as UML Primitive Types, I am unable to use them if my template parameter
type is set to "Class". Conversely, if I set my template parameter type to
"Primitive Type", then I can no longer bind to other classes in my model.
Does anyone have a solution that will allow me to bind to both of these
things? A similar issue occurs if I try to bind EDoubleObject to the
template parameter of EEList.
JT
FUDForum. Page generated in 0.03459 seconds
