Home » Modeling » UML2 » Programmatically modifiying an association end
| Programmatically modifiying an association end [message #476346] |
Mon, 08 October 2007 07:59  |
I am trying - desperately - to write code to move one association end
from one class to another. I changed the type successfully of the
association end/property (prop.setType(newType)), but the property
remains listed as an attribute of the initial class. I get a run-time
exception if I try to do things like
myInitialClass.getAttributes().remove(prop). Anyone has any idea of what
I'm doing wrong?
JP
| Re: Programmatically modifiying an association end [message #476349 is a reply to message #476348] |
Tue, 09 October 2007 02:38   |
JP,
If you look at the Javadoc for Classifier#getAttributes(), it says:
changeable="false"
That means you cannot add anything to the collection returned.
To add an existing attribute to a classifier you can add it to the
collection returned by StructuredClassifier#getOwnedAttributes() (also
part of Class's protocol).
Rafael
JP wrote:
> Dave Carlson wrote:
>> JP,
>> You need to add the property to the new class. Because this is a
>> containment relationship on the metamodel, it will be automatically
>> removed from the old class when you add to the new class. So,
>> something like:
>> myNewClass.getAttributes().add(prop)
>> "JP" <jp.schoch@fr.ibm.com> wrote in message
>> news:fed62c$1bi$1@build.eclipse.org...
>>> Hello,
>>> what I'm doing wrong?
>>> Regards,
>>> JP
> Hi Dave,
> Thanks for your reply. I had try this and I did double-check. Still get
> the following run-time exception:
> Property 'test'
> java.lang.UnsupportedOperationException
> at
> org.eclipse.uml2.common.util.DerivedEObjectEList$DerivedList Iterator.add(Unknown
> Source)
> Here is the code I am executing:
> Package pkg = inCl.getNearestPackage();
> Class c = pkg.createOwnedClass("Temp", false);
> for (Object obj:inCl.getAttributes()) {
> Property p = (Property) obj;
> System.out.println(p.getName());
> if (p.getName().equals("test")) c.getAttributes().add(p);
> Any clue?
> Thanks
> JP
| Re: Programmatically modifiying an association end [message #476352 is a reply to message #476349] |
Tue, 09 October 2007 11:54   |
JP,
Yes, I overlooked the missing 'Owned' in your original code snippet. As
Rafael pointed out, it should be:
>> c.getOwnedAttributes().add(p)
"Rafael Chaves" <rafael@no.spam.abstratt.com> wrote in message
news:fef7ku$g92$1@build.eclipse.org...
> JP,
> changeable="false"
> Cheers,
> Rafael
> JP wrote:
>> Dave Carlson wrote:
>>> JP,
>>> removed from the old class when you add to the new class. So, something
>>> like:
>>>> Hello,
>>>> Regards,
>>>> JP
>> Hi Dave,
>> Property 'test'
>> at
>> Source)
>> Any clue?
>> Thanks
>> JP
| Re: Programmatically modifiying an association end [message #476391 is a reply to message #476352] |
Mon, 15 October 2007 12:19  |
Dave, Rafael,
A big thank you to both of you. I was finally able to get to the end of
my problem. BTW I was trying to change a class inCl into an interface
inInt and to that effect I am also migrating the association ends from
inCl to inInt. So the code now looks like:
Association assoc = ...;
// prop is the association role/property that needs to be moved from
// the class to the interface
Property prop = (Property) assoc.getMemberEnds().get(0);
Property otherEnd = (Property) assoc.getMemberEnds().get(1);
if (prop.getType() != inCl) {
prop = (Property) assoc.getMemberEnds().get(1);
otherEnd = (Property) assoc.getMemberEnds().get(0);
prop.setType(inInt);
inInt.getOwnedAttributes().add(otherEnd);
Cheers
JP
Dave Carlson wrote:
> JP,
>> JP,
>> changeable="false"
>> Cheers,
>> Rafael
>> JP wrote:
>>> Dave Carlson wrote:
>>>> JP,
>>>> like:
>>>>> Hello,
>>>>> Regards,
>>>>> JP
>>> Hi Dave,
>>> Property 'test'
>>> at
>>> Source)
>>> Any clue?
>>> Thanks
>>> JP
| Re: Programmatically modifiying an association end [message #625117 is a reply to message #476346] |
Mon, 08 October 2007 10:31  |
JP,
containment relationship on the metamodel, it will be automatically removed
from the old class when you add to the new class. So, something like:
> Hello,
> I am trying - desperately - to write code to move one association end from
> one class to another. I changed the type successfully of the association
> end/property (prop.setType(newType)), but the property remains listed as
> an attribute of the initial class. I get a run-time exception if I try to
> do things like myInitialClass.getAttributes().remove(prop). Anyone has any
> idea of what I'm doing wrong?
> JP
| Re: Programmatically modifiying an association end [message #625118 is a reply to message #476347] |
Mon, 08 October 2007 19:03  |
Dave Carlson wrote:
> JP,
>> Hello,
>> Regards,
>> JP
Hi Dave,
Property 'test'
Source)
Any clue?
JP
| Re: Programmatically modifiying an association end [message #625161 is a reply to message #476348] |
JP,
changeable="false"
Rafael
JP wrote:
> Dave Carlson wrote:
>> JP,
>> something like:
>>> Hello,
>>> Regards,
>>> JP
> Hi Dave,
> Property 'test'
> at
> Source)
> Any clue?
> Thanks
> JP
| Re: Programmatically modifiying an association end [message #625164 is a reply to message #476349] |
JP,
> JP,
> changeable="false"
> Cheers,
> Rafael
> JP wrote:
>> Dave Carlson wrote:
>>> JP,
>>> like:
>>>> Hello,
>>>> Regards,
>>>> JP
>> Hi Dave,
>> Property 'test'
>> at
>> Source)
>> Any clue?
>> Thanks
>> JP
| Re: Programmatically modifiying an association end [message #625224 is a reply to message #476352] |
Dave, Rafael,
Cheers
JP
Dave Carlson wrote:
> JP,
>> JP,
>> changeable="false"
>> Cheers,
>> Rafael
>> JP wrote:
>>> Dave Carlson wrote:
>>>> JP,
>>>> like:
>>>>> Hello,
>>>>> Regards,
>>>>> JP
>>> Hi Dave,
>>> Property 'test'
>>> at
>>> Source)
>>> Any clue?
>>> Thanks
>>> JP
Current Time: Fri Oct 31 23:24:47 EDT 2025
Powered by FUDForum. Page generated in 0.06529 seconds
