Re: JSF with Eclipse - Tutorial [message #476063 is a reply to message #476062] |
Thu, 13 November 2008 21:18 |
Hi Wolfgang,
thank you for the feedback.
To 1.5 I believe the following is true (I added it also to the article):
JSP EL expressions are using the ${...} syntax. These EL expressions are
immediately evaluated. JSF EL expressions are of the type #{...}. These
are only evaluated when needed (and otherwisestored as strings).
To 3.3. Shame, I really would like to have a separate download for this.
I'm neither using JBoss nor do I want to download glassfish just for
these libs. So I hope for a better and brighter future and leave this
comment in the article... ;-)
4.4 Fixed
5.4. Fixed
5.5 Fixed
Best regards, Lars
Wolfgang Knauf wrote:
> Hi Lars,
> good tutorial!
> Some minor things:
> 1.5 Value and Method Binding:
> "Tip: Expression Language statements either start with "${" or "#{" and
> end with "}" " => could you explain the difference beetween "$" and "#"
> (I know that there is one, but I don't know it myself ;-) )
> 3.3. Download the JSTL library
> "If you know where I find the standard JSTL1.2 reference implementation
> please email this information to me." => there is no separate download,
> it seems to be part of the JavaEE5 RI
> (http://java.sun.com/javaee/downloads/index.jsp). I found it also as
> part of JBoss 5.
> 4.4. Create Java Server Page
> Image and code snippet seem to be swapped (correct: first image, then code)
> 5.4. Validators
> I miss the implementation of the "validate" (with check for
> login="tester").
> 5.5. Resource bundle for messages -> typo in file name:
> "message.properites"
> Best regards
> Wolfgang
Lars Vogel
http://www.vogella.de/eclipse.html - Tutorials about Eclipse
http://www.vogella.de/articles/RichClientPlatform/article.ht ml - Eclipse
RCP Tutorial
Re: JSF with Eclipse - Tutorial [message #476108 is a reply to message #476064] |
Fri, 14 November 2008 22:23 |
Cameron Bateman Messages: 481 Registered: July 2009 |
> I found this article about the "Unified EL":
> http://java.sun.com/products/jsp/reference/techart/unifiedEL .html
> If I find the time to read it, it will hopefully remove the fog in my
> There seems to be more about it than just deferred evaluation.
In JSP 2.0 and before the main difference is, as you say, early vs.
late-bound compilation. ${} is resolved when the JSP page is compiled
into Java. #{} is not resolved until the compiled Java for a JSP is
executed.
So the expression: bean.foo
When it's in ${bean.foo}, the variable 'bean' must be defined when the JSP
page is compiled. You can think of this as similar to variables in Java.
When it's in #{bean.foo}, the variable bean need not be defined until
runtime. That's why it is used in JSF, since JSF injects things into the
runtime that JSP doesn't know about at compile time, like managed beans.
In JSP 2.1 (Faces 1.2), Unified EL created a separate standard for EL. In
the new standard, the meaning of $ vs. # is left to the implementer.
However, I believe in the JSP context the meaning is the same. On the
other hand, in something like Facelets all EL is "late-bound" regardless
of $ or #.
--Cam
Re: JSF with Eclipse - Tutorial [message #618732 is a reply to message #476062] |
Hi Wolfgang,
4.4 Fixed
5.4. Fixed
5.5 Fixed
Best regards, Lars
> Hi Lars,
> good tutorial!
> Some minor things:
> part of JBoss 5.
> 5.4. Validators
> login="tester").
> Best regards
> Wolfgang
Lars Vogel
RCP Tutorial
Re: JSF with Eclipse - Tutorial [message #618736 is a reply to message #476064] |
executed.
of $ or #.
--Cam
FUDForum. Page generated in 0.04114 seconds
