Versions [message #475314] |
Wed, 03 September 2008 12:51 |
Originally posted by: ML1984.gmx.de
Hi.
What Eclipse version and GMF version do you use for development of
uml2tools?
Mark
Re: Versions [message #475319 is a reply to message #475315] |
Thu, 11 September 2008 13:59 |
Hi Sergey.
I tried to generate the GMF diagram code for UML activity diagrams on
the basis of the models in org.eclipse.uml2.diagram.def. It didn't work,
so I thought wrong version could be the problem.
I get strange errors about 'labelParsers'. It seems that you extended
the GMF generator model. Is this the reason?
How do you create diagram code?
Do you use the GMF dashboard?
(I do and at the moment I don't know how to handle all these different
..gmfgraph files.)
Any hints are greatly appreciated.
Mark
Sergey Gribovsky wrote:
> Hi Mark,
> Use following configuration for current version of source codes:
> Eclipse: 3.4 release
> GMF: 2.1 release + source code of GMF generation framework (all plugins from
> "org.eclipse.gmf/plugins" folder without "runtime" in path) up to date for
> today morning.
> You can use 0.8 release configuration, but you should check out source code
> by "Root_R0_8_0Maintenance" tag in such case.
> Sergey.
> "Mark L." <ML1984@gmx.de> wrote in message
> news:g9m18q$rmf$1@build.eclipse.org...
>> Hi.
>> uml2tools?
>> Cheers,
>> Mark
Re: Versions [message #475320 is a reply to message #475319] |
Thu, 11 September 2008 15:40 |
Sergey Gribovsky Messages: 42 Registered: July 2009 |
Member |
I think the reason is old version of GMF. LabelParsers was implemented a
couple of weeks ago. Unfortunately we can't use 2.2M1, so we are using 2.1
release with checked out source codes generation framework up to date for
last Monday morning in development workspace. Also don't forget to check out
"org.eclipse.uml2.diagram.codegen" and
"org.eclipse.uml2.diagram.codegen.edit" plugins in development workspace as
well, and use "Generate UML2Tools Diagrams" action of context menu instead
of "Generate diagram code" in target platform.
I'm creating wiki page to describe how to regenerate UML2 tools diagrams
more in detail, but I think it will be done next week.
I'm not using GMF dashboard, I'm using default editor for GMF graph models.
Sergey.
news:gab86t$h7l$1@build.eclipse.org...
> Hi Sergey.
> I tried to generate the GMF diagram code for UML activity diagrams on the
> basis of the models in org.eclipse.uml2.diagram.def. It didn't work, so I
> I get strange errors about 'labelParsers'. It seems that you extended the
> .gmfgraph files.)
> Cheers,
> Mark
>> Hi Mark,
>> from "org.eclipse.gmf/plugins" folder without "runtime" in path) up to
>> date for today morning.
>> code by "Root_R0_8_0Maintenance" tag in such case.
>> Sergey.
>>> Hi.
>>> uml2tools?
>>> Cheers,
>>> Mark
Re: Versions [message #622705 is a reply to message #475315] |
Hi Sergey.
..gmfgraph files.)
Mark
> Hi Mark,
> today morning.
> Sergey.
>> Hi.
>> uml2tools?
>> Cheers,
>> Mark
Re: Versions [message #622707 is a reply to message #475319] |
Member |
Sergey.
> Hi Sergey.
> .gmfgraph files.)
> Cheers,
> Mark
>> Hi Mark,
>> Sergey.
>>> Hi.
>>> uml2tools?
>>> Cheers,
>>> Mark
FUDForum. Page generated in 0.04206 seconds
