Home » Modeling » UML2 Tools » Creating State Charts
Creating State Charts [message #475298] |
Thu, 21 August 2008 17:36 |
Markus Messages: 2 Registered: July 2009 |
Hi.
Obviously I'm the only one in this universe who can't edit states and
transitions in a state chart model. I can't find any thread for this; but,
let me start from the beginning:
I installed eclipse 3.4 and updated with the update manager the missing
features (UML2, CDT, oAW) (platform is Win XP)
My goal is to generate c-code from a state machine model, so I created an
oAW-Project and added a state machine diagram in the src-folder. First,
the region to add is as big as the whole state machine and can't be
changed.
I can add states, transitions etc. into the region, BUT second, I can't
add actions (entry, exit, during), also impossible is to create guards,
events or activities for transitions. I tried to double-click, use context
menue, use the properties view, but nothing. So, please help... I'm
getting nuts :p
Re: Creating State Charts [message #475308 is a reply to message #475298] |
Thu, 28 August 2008 12:14 |
Sergey Gribovsky Messages: 42 Registered: July 2009 |
Member |
Hi Markus,
> First, the region to add is as big as the whole state machine and can't be
> changed.
Sorry, but I didn't understand what's wrong with resizing of region.
According UML specification, vertices could not be nested into state machine
directly (except connection points). Why it's necessary to have an extra
space outside of region? If you add one more region, it will be possible to
resize both.
> getting nuts :p
These properties are so-called advanced. Press "Show Advanced Properties"
button on toolbar of properties view to show them. Unfortunately it's
impossible to create required Constraint or Behavior using context menu of
diagram view. May be it will be implemented in frame of further releases.
You can use uml editor (double click on *.uml resource) to create necessary
elements.
Sergey.
Re: Creating State Charts [message #622682 is a reply to message #475298] |
Member |
Hi Markus,
> changed.
resize both.
> getting nuts :p
elements.
Sergey.
Current Time: Fri Apr 26 18:06:26 GMT 2024
Powered by FUDForum. Page generated in 0.03599 seconds
