JSF 1.2 and Dynamic Web Module 2.5 in Europa [message #475152] |
Tue, 30 October 2007 14:58 |
Originally posted by: baier.itbayern.de
Hi all,
I am trying to add the JSF 1.2 facet in the Dynamic Web Project facet
wizard. However the wizard tells me that I cannot do such a thing without
also selecting the Dynamic Web Module 2.5. But the version 2.5 is not on
available on the list of versions for Dynamic Web Module (only the
versions 2.2, 2.3, 2.4).
I'm running Eclipse IDE for Java EE Developers - Linux.
Does anyone know in which plugin the Dynamic Web Modules exist? Or which
version of this plugin contains the version 2.5 of the Dynamic Web Module?
Herbert Baier
Re: JSF 1.2 and Dynamic Web Module 2.5 in Europa [message #475157 is a reply to message #475154] |
Tue, 30 October 2007 19:02 |
Hi Iam,
I am using GlassFish V2. I also installed the GlassFish Eclipse plugin
glassfish-eclipse-plugin_installer_0_4.zip. I need an application server
that supports EJB. If the problem is GlassFish, I can try another
application server, per jboss. Do you have some suggestion?
Herbert
Re: JSF 1.2 and Dynamic Web Module 2.5 in Europa [message #475173 is a reply to message #475164] |
Fri, 02 November 2007 10:52 |
Cameron, your idea does not work well. When I try to run the application
on the server, I can not select glassfish (following error message: The
server does not support version 2.5 of the J2EE Web module specification).
Now I am using JBoss. It's works. My problem now is with Eclipse itself. I
am running on Linux and Eclipse crashes very frequently :-(
SF 1.2 and Dynamic Web Module 2.5 in Europa [message #475390 is a reply to message #475152] |
Mon, 10 December 2007 03:59 |
Originally posted by: jyzhou817.yahoo.com
I have a problem to use eclipse 3.3 to generate a dynmic web project with
JSF1.2.
the errors:
Referenced file contains errors
(jar:file:C:/eclipse/plugins/org.eclipse.jst.standard.schema s_1.0.0.v200706221355.jar
!/dtdsAndSchemas/javaee_5.xsd). For more information, right click on the
message and select "Show Details..."
the web.xml is with error and can not pass validation.
Any one have such experience? please provide help.
Re: JSF 1.2 and Dynamic Web Module 2.5 in Europa [message #614454 is a reply to message #475154] |
Hi Iam,
Herbert
Re: JSF 1.2 and Dynamic Web Module 2.5 in Europa [message #614465 is a reply to message #475164] |
FUDForum. Page generated in 0.05471 seconds
