Servlet FacesServlet Exception [message #474946] |
Wed, 25 July 2007 23:51 |
Originally posted by: somecsian.yahoo.com
Hi all,
I am using Eclipse Europa to develop JSF app. by jsf1.2 implementation on
Tomcat server 6.0.
I tried to run the JSFTutorial app. which in Eclipse help. I followed all
instructions But Servlet FacesServlet is not availble Exception was thrwon.
If any one faced this problem before please, give me the solution.
Re: Servlet FacesServlet Exception [message #474947 is a reply to message #474946] |
Wed, 25 July 2007 23:56 |
I was asked from Raghu in wtp-jsf-dev mailing list
" Are you getting this error when you select 'Run on Server.'on the
login.jsp page as described in the section, Testing the JSF JSP Page? "
Yes this error occurs in this case.
Re: Servlet FacesServlet Exception [message #474956 is a reply to message #474950] |
Sat, 04 August 2007 18:36 |
When i was starting the server before running the app. the server would
start But, Exceptions That i writed in the end of message is thrown.
When I was running the app. This error appeared
HTTP Status 404 - Servlet Faces Servlet is not available
type Status report
message Servlet Faces Servlet is not available
description The requested resource (Servlet Faces Servlet is not
available) is not available.
org.apache.catalina.loader.StandardClassLoader@110d81b
javax.faces.webapp.FacesServlet
java.lang.ClassNotFoundException: javax.faces.webapp.FacesServlet
at org.apache.catalina.loader.WebappClassLoader.loadClass
(WebappClassLoader.java:1358)
(WebappClassLoader.java:1204)
at org.apache.catalina.core.StandardWrapper.loadServlet
(StandardWrapper.java:1083)
(StandardWrapper.java:981)
at org.apache.catalina.core.StandardContext.loadOnStartup
(StandardContext.java:4042)
at org.apache.catalina.core.StandardContext.start
(StandardContext.java:4348)
at org.apache.catalina.core.ContainerBase.start
(ContainerBase.java:1045)
at org.apache.catalina.core.StandardHost.start
(StandardHost.java:719)
at org.apache.catalina.core.StandardEngine.start
(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start
(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start
(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start
(Catalina.java:566)
at sun.reflect.NativeMethodAccessorImpl.invoke0
(Native Method)
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
04/08/2007 09:12:45 م org.apache.catalina.core.StandardContext
loadOnStartup
SEVERE: Servlet /JSFTutorial threw load() exception
(Catalina.java:566)
(Native Method)
Re: Servlet FacesServlet Exception [message #613248 is a reply to message #474946] |
Re: Servlet FacesServlet Exception [message #613263 is a reply to message #474950] |
type Status report
(Catalina.java:566)
(Native Method)
loadOnStartup
(Catalina.java:566)
(Native Method)
FUDForum. Page generated in 0.04105 seconds
