Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #474861 is a reply to message #474860] |
Thu, 19 July 2007 15:54 |
Originally posted by: liming.wu.icesoft.com
Thanks Cameron.
What I want to do is to customize the behavior of trait
"requires-html-form" so that instead of h:form but my custom form
component gets inserted. Is there an alternative way to do that?
Cameron Bateman wrote:
>> I have tried to use extension point
>> org.eclipse.jst.pagedesigner.tagCreationFactories but defined custom
>> TagCreator via org.eclipse.jst.pagedesigner.tagCreationFactories is
>> not respected.
> Can you describe what you are trying to do? Perhaps we can direct you
> to an alternative solution.
> --Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #474953 is a reply to message #474945] |
Tue, 31 July 2007 21:06 |
Thank you very much.
Could you please provide me with the workaround through editPolicy?
Very appreciated.
Liming
> Hi Liming,
> There is no easy way to do this at present. I can you provide you with
> a workaround that should work if you are willing to learn about how GEF
> edit policies work.
> If a more generalized framework approach is important to you, please log
> a bug describing the scenario(s) you need supported.
> --Cam
> Liming wrote:
>> Thanks Cameron.
>> Thanks
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #475013 is a reply to message #475005] |
Thu, 09 August 2007 21:54 |
Cameron,
Thank you very much. Unfortunately I still have problem with
getCommand(request).
I have install EditorPolicy ItemCreationRequest.REQ_ITEM_CREATION with
my ItemCreationEditPolicy object. But the request objects passed in with
getCommand (request) are instances of GroupRequest not
ItemCreationRequest which we expect because the getCommand call with
ItemCreationRequest has been issued before createEditPolicy. Without
ItemCreationRequest and IDomPosition, I couldn't find the way to insert
parent components. Are there other way around?
Thanks again!
Liming
> You will need to use the ElementEdit extension point to override the
> default edit policy on the ElementEditPart. To do this you can use the
> org.eclipse.jst.pagedesigner.pageDesignerExtension extension point with
> "elementEditFactory" sequence to define a factory for creating
> ElementEdit's associated with the tag lib URI you are interested in.
> There are examples of this in the org.eclipse.jst.pagedesigner.jsf.ui
> plugin. Once you have an ElementEdit factory you create new
> ElementEdit objects for the tag you are interested in. See
> JSFHTMLElementEditFactory for an example of how this is done.
> In the ElementEdit object for the tag(s) you are interested in, you will
> need to implement the createEditPolicies method and install your own
> ItemCreationRequest.REQ_ITEM_CREATION edit policy. To look at the
> default one, start at NodeEditPart.createEditPolicies(). Within your own
> edit policy for element creation (you can probably sub-class the
> existing one called ItemCreationEditPolicy or the common DropEditPolicy)
> you need to tailor the creation command returned by the getCommand method.
> This is fairly involved I know, but as I said it is a workaround. Let
> me know if you have any further questions.
> --Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #475017 is a reply to message #475015] |
Fri, 10 August 2007 16:56 |
Thank you much for your help!
I have 2 questions regarding stylesheet to bother you.
1. I have a link stylesheet component and it needs to be dropped into
<head> section but it looks like the section is not droppable. Am I
right? Is there a way around?
2. For <link> tag, the value of href attribute (actually relative path
to a css file) is resolved against webroot which is observed via view
source in preview mode event though in source text it is still a
relative path. What I want is to resolve the relative path based on
plugin's path. Is it possible?
Thank you very much
Liming
> I'm going to try and escalate a work around for this issue. I don't
> know if we'll be able to get it in for 2.0.1 and it won't be a full
> solution, but I'm hoping to get something that lets you workaround this
> issue more satisfactorily.
> If you want to track the issue, you can CC yourself on:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=199295
> Regards,
> Cameron
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #475020 is a reply to message #475019] |
Mon, 13 August 2007 19:41 |
> Are you aiming to change the way the <link> tag works or write a custom
> tag converter for your own component?
Yes, you are right.
> How would loading the file
> relative to a plugin map to runtime behaviour? What if you copied the
> file from the plugin into the web content folder and then point to it?
> --Cam
Good question. Actually in runtime, default CSS and other resources are
embedded in a jar file. There is no problem in runtime. But in
designtime, WTP doesn't scan for such resources embedded in jar file. So
that the best way for us is to have those resources in plugin map and
customize loading process. We are trying to avoid making duplication of
those resources in web root folder.
Thank you.
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613099 is a reply to message #474860] |
Thanks Cameron.
>> not respected.
> --Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613258 is a reply to message #474945] |
Very appreciated.
Liming
> Hi Liming,
> edit policies work.
> --Cam
> Liming wrote:
>> Thanks Cameron.
>> Thanks
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613871 is a reply to message #475005] |
Cameron,
Thanks again!
Liming
> --Cam
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613875 is a reply to message #475015] |
Thank you very much
Liming
> Regards,
> Cameron
Re: extension point org.eclipse.jst.pagedesigner.tagCreationFactories doesn't work [message #613878 is a reply to message #475019] |
Yes, you are right.
> --Cam
Thank you.
FUDForum. Page generated in 0.04268 seconds
