Home » Eclipse Projects » Platform - User Assistance (UA) » How to use Eclipses embedded AppServer
How to use Eclipses embedded AppServer [message #474842] Fri, 21 November 2008 12:24 Go to next message
I have a war file that currently runs on an external app server. I would
like to run it on Eclipses’ (our RCP) embedded app server.
I’m not sure of the following:
1) How do I package it in the plug-in? Can I just stick the war in
it? Is there a certain dir structure?
2) What changes do I need to make to the embedded app server? Do I
need to change the web.xml?
Any pointers would be greatly appreciated.
Thanks for your time,
Andrew
Re: How to use Eclipses embedded AppServer [message #474852 is a reply to message #474842] Fri, 21 November 2008 17:32 Go to previous messageGo to next message
Can you clarify what you are wanting to do. Are you looking to create an
application which simultaneously has the Eclipse help system and your
war file running on the same port or are you just looking to create an
RCP application which can also host your web application?
> would like to run it on Eclipses� (our RCP) embedded app server.
> I�m not sure of the following: 1) How do I package it in the
> plug-in? Can I just stick the war in it? Is there a certain dir
> structure? 2) What changes do I need to make to the embedded app
> server? Do I need to change the web.xml?
> Andrew
Re: How to use Eclipses embedded AppServer [message #474884 is a reply to message #474852] Mon, 24 November 2008 11:02 Go to previous messageGo to next message
I am trying to have an RCP that can have several webapps running on the
same port with different contexts that uses the internal appserver. I am
using the 3.4 Eclipse build.
Re: How to use Eclipses embedded AppServer [message #474885 is a reply to message #474884] Tue, 25 November 2008 13:43 Go to previous messageGo to next message
While this seems like an obvious thing to want to do but I'm not sure
that the Equinox web server supports this. The help system is launched
in org.eclipse.help.internal.server.WebappManager.start(String) and it
uses JettyConfigurator.start() to start the server. I don't believe
there is any API to start two contexts on the same port, or add a second
context to an existing server instance. This has been requested before
and I thought there was a bug already open but I didn't see one when I
did a quick search.
>> an application which simultaneously has the Eclipse help system and
>> your war file running on the same port or are you just looking to
>> create an RCP application which can also host your web application?
> am using the 3.4 Eclipse build.
Re: How to use Eclipses embedded AppServer [message #474887 is a reply to message #474885] Mon, 01 December 2008 11:17 Go to previous message
Chis,
I think the bug# https://bugs.eclipse.org/bugs/show_bug.cgi?id=204465
addresses this issue.
Re: How to use Eclipses embedded AppServer [message #622237 is a reply to message #474842] Fri, 21 November 2008 17:32 Go to previous message
> Andrew
Re: How to use Eclipses embedded AppServer [message #622615 is a reply to message #474852] Mon, 24 November 2008 11:02 Go to previous message
Re: How to use Eclipses embedded AppServer [message #622616 is a reply to message #474884] Tue, 25 November 2008 13:43 Go to previous message
did a quick search.
Re: How to use Eclipses embedded AppServer [message #622618 is a reply to message #474885] Mon, 01 December 2008 11:17 Go to previous message
Chis,
Previous Topic:User Assistance Tips and Tricks
Next Topic:How to get Intro page formatted like Overview one
Current Time: Sat Jul 05 03:04:01 EDT 2025
Powered by FUDForum. Page generated in 0.05661 seconds
