Override Eclipse CSS [message #474617] |
Thu, 16 October 2008 15:38 |
Originally posted by: j.hurrell.don'tspamme.castsoftware.com
This must be such a common request, but I can't find anything about it
in this newsgroup, nor on Google.
I use my own CSS stylesheet to govern the format of my plugin html help
pages. This works fine. However, it seems that the CSS files that are
automatically added by Eclipse are overriding my CSS and making the page
look slightly odd.
This is the header before I view it via Eclipse:
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="StyleSheet" type="text/css" href="../css/cast.css">
<title>Plug-in for Eclipse</title>
</head>
When viewed through Eclipse help system the header looks like this:
<head>
<link rel="stylesheet"
href=" ../content/PLUGINS_ROOT/org.eclipse.help.webapp/advanced/bre adcrumbs.css "
charset="ISO-8859-1" type="text/css"></link>
<script type="text/javascript"
src="../content/PLUGINS_ROOT/org.eclipse.help/livehelp.js"> </script>
href="../content/PLUGINS_ROOT/PRODUCT_PLUGIN/narrow_book.css "
href=" ../content/PLUGINS_ROOT/PRODUCT_PLUGIN/win32_narrow_book.css "
<script type="text/javascript">
if (parent.ContentToolbarFrame &&
parent.ContentToolbarFrame.setButtonState)
parent.ContentToolbarFrame.setButtonState("toggle_highlight ","hidden");
</script>
</head>
Any ideas how to stop the Eclipse CSS from "upsetting" my own CSS?
Re: Override Eclipse CSS [message #474618 is a reply to message #474617] |
Thu, 16 October 2008 16:02 |
Note that the display only seems to be "upset" when viewing my help
through the Eclipse internal Help window view.
When using the Help > Help Contents option, my plugin displays as it
should, However, on closer examination, Eclipse doesn't seem to add the
following two stylesheets when viewed through the Help > Help COntents menu:
Any ideas how I can rectify this or stop Eclipse using its own stylesheets?
> look slightly odd.
> <head>
> </head>
> <head>
> </script>
> </head>
> Thanks
Re: Override Eclipse CSS [message #474701 is a reply to message #474619] |
Tue, 21 October 2008 15:49 |
Chris Goldthorpe wrote:
> It is a common request, in Eclipse 3.4 we added a new product
> customization that lets you override the standard CSS. From
> http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/ua_help_setup_preferences.htm
> The four css preferences allow for the control of page appearance by
> inserting css files into every page served by the help server. Each can
> each contain zero or more comma separated paths of the form
> /plugin/path. These paths should contain only ASCII characters.
> If a path contains ${os} then that will be replaced with the name of the
> OS, any other parameters of the form ${parameter} are reserved for
> future use.
> topic_css A list of css file(s) to include in every non navigation page
> served by help system.
> nav_css A list of css file(s) to include in every navigation page served
> by help system
> narrow_css A list of css file(s) to include in every page displayed in
> the help view or help tray .
> disabled_css A list of css file(s) to include in every page served by
> help system from a capability that is not enabled.
Thanks Chris. I'm struggling somewhat with this... reading around the
subject, i gather these preferences should be placed in a
plugin_customization.ini file? Is that correct?
If so, where do i place the .ini file (at the root of the Help plugin?)
and does it need referencing somewhere - such as the plugin.xml?
Or have I misunderstood and the plugin_customization.ini file can only
be used when you launch Eclipse and it is valid for all plugins?
Re: Override Eclipse CSS [message #620093 is a reply to message #474617] |
> look slightly odd.
> <head>
> </head>
> <head>
> </script>
> </head>
> Thanks
Re: Override Eclipse CSS [message #621645 is a reply to message #474619] |
> future use.
> by help system
FUDForum. Page generated in 0.03074 seconds
