Home » Eclipse Projects » Platform - User Assistance (UA) » Override Eclipse CSS
Override Eclipse CSS [message #474617] Thu, 16 October 2008 11:38 Go to next message
Originally posted by: j.hurrell.don'tspamme.castsoftware.com
This must be such a common request, but I can't find anything about it
in this newsgroup, nor on Google.
I use my own CSS stylesheet to govern the format of my plugin html help
pages. This works fine. However, it seems that the CSS files that are
automatically added by Eclipse are overriding my CSS and making the page
look slightly odd.
This is the header before I view it via Eclipse:
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="StyleSheet" type="text/css" href="../css/cast.css">
<title>Plug-in for Eclipse</title>
</head>
When viewed through Eclipse help system the header looks like this:
<head>
<link rel="stylesheet"
href=" ../content/PLUGINS_ROOT/org.eclipse.help.webapp/advanced/bre adcrumbs.css "
charset="ISO-8859-1" type="text/css"></link>
<script type="text/javascript"
src="../content/PLUGINS_ROOT/org.eclipse.help/livehelp.js"> </script>
href="../content/PLUGINS_ROOT/PRODUCT_PLUGIN/narrow_book.css "
href=" ../content/PLUGINS_ROOT/PRODUCT_PLUGIN/win32_narrow_book.css "
<script type="text/javascript">
if (parent.ContentToolbarFrame &&
parent.ContentToolbarFrame.setButtonState)
parent.ContentToolbarFrame.setButtonState("toggle_highlight ","hidden");
</script>
</head>
Any ideas how to stop the Eclipse CSS from "upsetting" my own CSS?
Re: Override Eclipse CSS [message #474618 is a reply to message #474617] Thu, 16 October 2008 12:02 Go to previous messageGo to next message
Note that the display only seems to be "upset" when viewing my help
through the Eclipse internal Help window view.
When using the Help > Help Contents option, my plugin displays as it
should, However, on closer examination, Eclipse doesn't seem to add the
following two stylesheets when viewed through the Help > Help COntents menu:
Any ideas how I can rectify this or stop Eclipse using its own stylesheets?
> look slightly odd.
> <head>
> </head>
> <head>
> </script>
> </head>
> Thanks
Re: Override Eclipse CSS [message #474619 is a reply to message #474617] Mon, 20 October 2008 12:27 Go to previous messageGo to next message
It is a common request, in Eclipse 3.4 we added a new product
customization that lets you override the standard CSS. From
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/ua_help_setup_preferences.htm
The four css preferences allow for the control of page appearance by
inserting css files into every page served by the help server. Each can
each contain zero or more comma separated paths of the form
/plugin/path. These paths should contain only ASCII characters.
If a path contains ${os} then that will be replaced with the name of the
OS, any other parameters of the form ${parameter} are reserved for
future use.
topic_css A list of css file(s) to include in every non navigation page
served by help system.
nav_css A list of css file(s) to include in every navigation page served
by help system
narrow_css A list of css file(s) to include in every page displayed in
the help view or help tray .
disabled_css A list of css file(s) to include in every page served by
help system from a capability that is not enabled.
Re: Override Eclipse CSS [message #474701 is a reply to message #474619] Tue, 21 October 2008 11:49 Go to previous messageGo to next message
> future use.
> by help system
Thanks Chris. I'm struggling somewhat with this... reading around the
subject, i gather these preferences should be placed in a
plugin_customization.ini file? Is that correct?
If so, where do i place the .ini file (at the root of the Help plugin?)
and does it need referencing somewhere - such as the plugin.xml?
Or have I misunderstood and the plugin_customization.ini file can only
be used when you launch Eclipse and it is valid for all plugins?
Re: Override Eclipse CSS [message #474702 is a reply to message #474701] Tue, 21 October 2008 12:34 Go to previous messageGo to next message
The way I usually do this is to add a command line option when you start
eclipse such as
eclipse -pluginCustomization plugin_customization.ini
I think that you can also specify the location of the customization file
at the product file, see
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/reference/extension-points/org_eclipse_core_runtime_ products.html
Re: Override Eclipse CSS [message #474703 is a reply to message #474702] Wed, 22 October 2008 05:01 Go to previous message
> eclipse such as
Many thanks Chris. That seems to work fine.
Re: Override Eclipse CSS [message #620093 is a reply to message #474617] Thu, 16 October 2008 12:02 Go to previous message
> look slightly odd.
> <head>
> </head>
> <head>
> </script>
> </head>
> Thanks
Re: Override Eclipse CSS [message #620094 is a reply to message #474617] Mon, 20 October 2008 12:27 Go to previous message
future use.
by help system
Re: Override Eclipse CSS [message #621645 is a reply to message #474619] Tue, 21 October 2008 11:49 Go to previous message
> future use.
> by help system
Re: Override Eclipse CSS [message #621646 is a reply to message #474701] Tue, 21 October 2008 12:34 Go to previous message
eclipse such as
Re: Override Eclipse CSS [message #621647 is a reply to message #474702] Wed, 22 October 2008 05:01 Go to previous message
> eclipse such as
Previous Topic:Infocenter Webapp Usage
Next Topic:Removing default plug-ins from Infocenter
Current Time: Tue Aug 19 01:37:50 EDT 2025
Powered by FUDForum. Page generated in 0.11153 seconds
