Home » Modeling » UML2 Tools » Integrating UML2 Tools and RCP application
Re: Integrating UML2 Tools and RCP application [message #474454 is a reply to message #474445] |
Sat, 28 June 2008 06:28 |
Rafael Chaves Messages: 362 Registered: July 2009 |
Nogueira,
The UML2Tools has quite a vast list of requirements, which go way beyond
what is in the basic RCP runtime or SDK.
Check out the "Build Dependencies" in the download page:
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools
You might not need the entire Eclipse SDK, just Platform (which is more
than the RCP anyway) should be enough. But you will still need EMF, EMF
Query, Transaction, Validation, UML2, OCL, GEF and GMF.
Rafael
Nogueira wrote:
> Hello,
> How can I integrate the UML2Tools plugin with my RCP application?
> I wanna create and open UML diagrams in my application but I don't know
> how to call this plugin.
> Thanks in advance for all replies,
> Nogueira
Re: Integrating UML2 Tools and RCP application [message #474455 is a reply to message #474454] |
Mon, 30 June 2008 20:59 |
Bill Hinge Messages: 156 Registered: July 2009 |
Hi Rafael
I got the impression that Nogueira was asking how to call a uml editor
(eg clazz) in RCP, in effect how to build a RCP UML tool.
I did something similar using only clazz but I would like the ability to
add my own profiles to the class diag. The way I did this was to copy
the solution generated by GMF's RCP output (my RCP contains my own DSL
editor (non UML) plus the uml2tools class diag editor). Since I have my
own DSL editor, the dependencies are covered but I am not sure if this
is the best method for doing this. ie is there a class that allows a
user to select their choice of uml2tools diag eg class, use case etc?
regards
Steve
Rafael Chaves wrote:
> Nogueira,
> Cheers,
> Rafael
> Nogueira wrote:
>> Hello,
>> know how to call this plugin.
>> Nogueira
Re: Integrating UML2 Tools and RCP application [message #620468 is a reply to message #474445] |
Nogueira,
Rafael
Nogueira wrote:
> Hello,
> Nogueira
Re: Integrating UML2 Tools and RCP application [message #620469 is a reply to message #474454] |
Hi Rafael
regards
Steve
> Nogueira,
> Cheers,
> Rafael
> Nogueira wrote:
>> Hello,
>> Nogueira
Current Time: Fri Apr 26 02:56:39 GMT 2024
Powered by FUDForum. Page generated in 0.03453 seconds
