Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474626 is a reply to message #474625] |
Sat, 09 June 2007 07:33 |
Originally posted by: joachim.fischer.email.freenet.de
Hello Cameron,
thanks for your answers.
I have identified a problem with the
" org.eclipse.datatools.sqltools.sqleditor.attachProfileAction ".
I got the problem, when I tried to work through the Cheat Sheets for JPA
"Create a JPA"
in the first step:
Setup the Environment -> click to perform.
So the view in "Help -> About Eclipse -> Plugin Details" at the topic
Eclipse Data Tools Platform SQL Editor has a cross behind the medal :-(
> Fischer, Joachim wrote:
>> Oh sorry, they are in "HELP" -> "About ECLIPSE SDK" -> "Plug-in
>> Details",
>> in Eclipse 3.3RC1. There are the status of the Plug-Ins.
>> Now I tried Eclipse 3.3RC2 and there are some little crosses behind a
>> medal. Is that correct?
> I don't know if it is correct, I seem to have a lot of unsigned bundles
> and don't have an problems. I would check to make sure that the versions
> you are using are correct. The versions of the dependencies (GEF, EMF
> etc.) that you listed do not appear to be line up with what is on the web
> page link for RC2 that you posted.
> If there are actual problems, you will see errors in Help->Software
> Updates->Manage Configuration. Be sure to click the action button for
> "Show disabled features".
> --Cam
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #611844 is a reply to message #474625] |
Hello Cameron,
"Create a JPA"
in the first step:
>> Details",
> --Cam
FUDForum. Page generated in 0.04183 seconds
