Home » Eclipse Projects » JavaServer Faces » get list of added JSF component libraries
get list of added JSF component libraries [message #473455] Thu, 21 September 2006 12:53 Go to next message
Dear Helpers,
I am trying to write a plugin for a new project facet which depends on
jsf facet 1.1, I wonder if there is a way to get a list of JSF component
libraries which have been added in jsf project creation wizard from my
new project facet installation delegate?
JSFLibraryRegistry doesn't know anything about a specific library is
selected or not
Re: get list of added JSF component libraries [message #473459 is a reply to message #473455] Thu, 21 September 2006 19:52 Go to previous messageGo to next message
During project creation, you can query the wizard page data model for
the following two properties.
For example,
List implLibs =
(List)config.getProperty(IJSFFacetInstallDataModelProperties .IMPLEMENTATION_LIBRARIES);
List compLibs =
(List)config.getProperty(IJSFFacetInstallDataModelProperties .COMPONENT_LIBRARIES);
There is currently no available API for an already JSF faceted web
project. We will be fixing that in 2.0. You may, at your own risk, use
the internal JSFLibraryConfigModelAdapter class. Use
getSavedJSFImplementationLibrary and getSavedJSFComponentLibraries to
access the JSF library references once a project is created.
Justin
Re: get list of added JSF component libraries [message #473461 is a reply to message #473459] Fri, 22 September 2006 15:24 Go to previous messageGo to next message
Thanks Justin,
I can get reference of JSFFacetInstallDataModelProvider, but how can i
get reference of JSFLibraryConfigModelAdapter?
William
> For example,
> List implLibs =
> List compLibs =
> Justin
Re: get list of added JSF component libraries [message #473462 is a reply to message #473461] Fri, 22 September 2006 17:34 Go to previous message
William,
You create a new instance of JSFLibraryConfigModelAdapter from IProject.
You need to update the model with library selections obtained from
JSFFacetInstallDataModelProvider during *facet installation* time.
For example,
JSFLibraryConfigModelAdapter model = new
JSFLibraryConfigModelAdapter(project);
model.updateJSFImplementationLibrary((JSFLibraryDecorator)
implLibs.get(0));
model.updateJSFComponentLibraries(compLibs);
... model.getSavedJSFImplementationLibrary();
... model.getSavedJSFComponentLibraries();
Justin
Re: get list of added JSF component libraries [message #607985 is a reply to message #473455] Thu, 21 September 2006 19:52 Go to previous message
For example,
List implLibs =
List compLibs =
Justin
Re: get list of added JSF component libraries [message #607992 is a reply to message #473459] Fri, 22 September 2006 15:24 Go to previous message
Thanks Justin,
William
> For example,
> List implLibs =
> List compLibs =
> Justin
Re: get list of added JSF component libraries [message #607995 is a reply to message #473461] Fri, 22 September 2006 17:34 Go to previous message
William,
For example,
implLibs.get(0));
Justin
Previous Topic:get list of added JSF component libraries
Next Topic:Visual Pafe Designer features document posted on the wiki..
Current Time: Sun Nov 09 02:36:37 EST 2025
Powered by FUDForum. Page generated in 0.04679 seconds
