Home » Modeling » UML2 Tools » inner (nested) classes
| Re: inner (nested) classes [message #473499 is a reply to message #473345] |
Fri, 28 March 2008 11:12   |
Hi Tatiana, Marius,
If I'm not mistaken, the composite aggregation is different from a nested
classifier. A nested classifier does not necessarily have to be part of
the internal structure of its owning parent. Tatiana, in your example,
MenuBar would own a property "dst" of type Button, whereas if one just
showed that Button was a nested classifier then no such property would exist
(necessarily).
Please correct me if I'm wrong.
- James.
"Tatiana Fesenko" <tatiana.fesenko@borland.com> wrote in message
news:6785c52638e68ca47533a2633ab@news.eclipse.org...
Hello Marius,
The owned class is always shown as a label inside 'classes' compartment. But
you can use Composite Aggregation link. It handles required to you semantics
of whole/part relationship. The picture how your example with MenuBar/Button
will look like if using Composite Aggregation is in the file attached.
To create Composite Aggregation use Links/Association/Composite Aggregation
palette entry.
Best wishes,
Tatiana.
> When i nest a class inside another class (i.e. to get an inner class)
> it shows up as an entry in the "class" compartment in the associated
> diagram (see
> < http://stud3.tuwien.ac.at/~e9926236/e_uml2_innerclass_is.png>). Is
> there any way to have the uml2 visualisation as shown in
> < http://stud3.tuwien.ac.at/~e9926236/e_uml2_innerclass_should .png>?
> cheers,
> marius
| Re: inner (nested) classes [message #473513 is a reply to message #473499] |
Thu, 03 April 2008 04:34  |
Thank you, James, you are always correct =)
Yes, composite aggregation semantics is close to the semantics of owned property,
not to the semantics of nested classifier.
However, the only representation for the nested classifier I've found in
the UML specification is a label inside parent classifier. Please correct
me if I am wrong.
Marius,
your second picture ( http://stud3.tuwien.ac.at/~e9926236/e_uml2_innerclass_should .png)
looks very like as Composite or Shared Aggregation, which hangles a bit different
from nested classifier semantics.
For more information reference corresponding sections of UML specification.
Tatiana.
> Hi Tatiana, Marius,
> nested classifier. A nested classifier does not necessarily have to
> be part of the internal structure of its owning parent. Tatiana, in
> your example, MenuBar would own a property "dst" of type Button,
> whereas if one just showed that Button was a nested classifier then no
> such property would exist (necessarily).
> Cheers,
> - James.
> Hello Marius,
> compartment. But you can use Composite Aggregation link. It handles
> required to you semantics of whole/part relationship. The picture how
> your example with MenuBar/Button will look like if using Composite
> Aggregation palette entry.
> Best wishes,
> Tatiana.
>> diagram (see
>> cheers,
>> marius
| Re: inner (nested) classes [message #618448 is a reply to message #473342] |
Wed, 27 February 2008 06:27  |
----++Omea_Parts_Splitter.251213308075077
Content-Type: text/plain; charset=koi8-r
Hello=20Marius,
The=20owned=20class=20is=20always=20shown=20as=20a=20label=2 0inside=20'classes'=20compartment=2e=20But=20you=20can=20use =20Composite=20Aggregation=20link=2e=20It=20handles=20requir ed=20to=20you=20semantics=20of=20whole/part=20relationship=2 e=20The=20picture=20how=20your=20example=20with=20MenuBar/Bu tton=20will=20look=20like=20if=20using=20Composite=20Aggrega tion=20is=20in=20the=20file=20attached=2e
To=20create=20Composite=20Aggregation=20use=20Links/Associat ion/Composite=20Aggregation=20palette=20entry=2e
Best=20wishes,
Tatiana=2e
>=20Hi,
>=20
> =20When=20i=20nest=20a=20class=20inside=20another=20class=20 (i=2ee=2e=20to=20get=20an=20inner=20class)
>=20it=20shows=20up=20as=20an=20entry=20in=20the=20"class"=20compartment=20in=20the=20associated
>=20diagram=20(see
>=20< http://stud3=2etuwien=2eac=2eat/~e9926236/e=5fuml2=5finnercl ass=5fis=2epng>)=2e=20Is
> =20there=20any=20way=20to=20have=20the=20uml2=20visualisatio n=20as=20shown=20in
>=20< http://stud3=2etuwien=2eac=2eat/~e9926236/e=5fuml2=5finnercl ass=5fshould=2epng>?
>=20
>=20cheers,
>=20marius
Content-Type: image/x-png; name="MenuBar.PNG"
Content-Disposition: attachment; filename="MenuBar.PNG"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----++Omea_Parts_Splitter.251213308075077--
| Re: inner (nested) classes [message #618650 is a reply to message #473345] |
Hi Tatiana, Marius,
(necessarily).
- James.
Hello Marius,
palette entry.
Best wishes,
Tatiana.
> diagram (see
> cheers,
> marius
| Re: inner (nested) classes [message #619653 is a reply to message #473499] |
me if I am wrong.
Marius,
Tatiana.
> Hi Tatiana, Marius,
> Cheers,
> - James.
> Hello Marius,
> Best wishes,
> Tatiana.
>> diagram (see
>> cheers,
>> marius
Current Time: Fri Nov 07 00:34:12 EST 2025
Powered by FUDForum. Page generated in 0.29019 seconds
