| Error, "The element may not have duplicate name and target namespace" [message #48065] |
Mon, 21 June 2004 08:28  |
I am having difficulty tracking down an error whem loading an EMF model
from an XML Schema. Specifically, I receive an "Concversion Error" with
the following message:
XSD: The element may not have duplicate name and target namespace
'http://www.some.org/abc##SomeThing'
Note that the same error is displayed under "Problems" when opening the
schema file in the Sample XML Schema Editor.
However, when I open the same file in the WSAD 5.1 XML Schema editor,
there is not an error displayed.
I proceed anyhow with Model Generation, but that end sin a Null Pointer
Exception, which is shown at the end of this post.
This file imports schemas, none of which individually causes an error.
Any hints?
Thanks, chris
My versions:
EMF: Version: 2.0.0 Build id: 200406100948
XSD: Version: 2.0.0 Build id: 200406100948
Eclipse RC2: Version: 3.0.0 Build id: 200406111814
!ENTRY org.eclipse.emf.codegen.ecore.ui 2 0 Jun 21, 2004 14:20:53.357
!MESSAGE
!STACK 0
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl$D ependency
Helper.<init>(GenPackageImpl.java:1160)
org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.g enerate(G
enPackageImpl.java:1685)
org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel ActionBar
Contributor$3.generate(GenModelActionBarContributor.java:181 )
Contributor$8.execute(GenModelActionBarContributor.java:305)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModify
Operation.java:91)
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1673
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOp
eration.java:105)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalCont
ext.java:303)
org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:253)
org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDi
alog.java:397)
Contributor$GenerateAction.run(GenModelActionBarContributor. java:321)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContri
butionItem.java(Inlined Compiled Code))
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionC
ontributionItem.java(Compiled Code))
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java(Inlined
Compiled
Code))
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compil
ed Code))
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compile
d Code))
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1333)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.jav
a:252)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformAct
ivator.java:334)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.ja
va:272)
va:128)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.
java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcces
sorImpl.java:41)
at java.lang.reflect.Method.invoke(Method.java:386)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
| Re: Error, "The element may not have duplicate name and target namespace" [message #48125 is a reply to message #48065] |
Mon, 21 June 2004 10:37  |
Chris,
It sounds like you have duplicate element declarations but without a sample,
I can only guess.
Chris Giblin wrote:
> Any hints?
> Thanks, chris
> My versions:
> !MESSAGE
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> Operation.java:91)
> at
> at
> eration.java:105)
> at
> ext.java:303)
> at
> at
> alog.java:397)
> at
> at
> at
> at
> at
> Code))
> Compiled
> Code))
> at
> ed Code))
> at
> Code))
> at
> d Code))
> at
> a:252)
> at
> at
> at
> ivator.java:334)
> at
> va:272)
> at
> va:128)
> at
> java:79)
> at
> sorImpl.java:41)
| Re: Error, "The element may not have duplicate name and target namespace" [message #589409 is a reply to message #48065] |
Chris,
I can only guess.
Chris Giblin wrote:
> Any hints?
> Thanks, chris
> My versions:
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> Operation.java:91)
> at
> at
> eration.java:105)
> at
> ext.java:303)
> at
> at
> alog.java:397)
> at
> at
> at
> at
> at
> Code))
> Compiled
> Code))
> at
> ed Code))
> at
> Code))
> at
> d Code))
> at
> a:252)
> at
> at
> at
> ivator.java:334)
> at
> va:272)
> at
> va:128)
> at
> java:79)
> at
> sorImpl.java:41)
FUDForum. Page generated in 0.04443 seconds
