Home » Modeling » UML2 » A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype con
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #473121 is a reply to message #473120] |
Thu, 07 June 2007 19:33 |
Hi, Nicolas,
If the Shaddock profile defines this stereotype, then just do:
self.getProfile().isStrict
HTH,
Christian
Nicolas Rouquette wrote:
> Suppose a fictitious UML profile called 'Shaddock' defines a stereotype
> that extends uml:Class.
> The following OCL snippet seems to determine whether the application of
> the 'Shaddock' profile was strict or not.
> self.base_Class.getModel().getAllProfileApplications()->exists
> (pa:ProfileApplication
> | pa.appliedProfile.getLabel() = 'Shaddock' and pa.isStrict)
> If I have N stereotypes that need to know ProfileApplication.isStrict
> and they are instantiated on average M times, then I'll have N*M
> expensive queries whenever I do full-scale validation.
> Since I am using RSA 7.0.0.2, I'm bound to the limitations of the
> UML/OCL implementation in Eclipse 3.2 which doesn't have support for
> derived values. With derived values, I know -- at least in principle --
> how to solve this problem better. Without derived values, I don't know
> how to solve this problem without paying the O(N*M) complexity tax.
> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #473127 is a reply to message #473121] |
Fri, 08 June 2007 13:29 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Ah, but it's the _application_ of the profile that is strict or not.
Nicolas, how are you using this information in your application? Typically
the strictness of a profile application is used by a tool to limit the set
of metaclasses available in the the tool the the ones that are referenced
from the profile...
Kenn
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:f49mhf$j8r$1@build.eclipse.org...
> Hi, Nicolas,
> HTH,
> Christian
>> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #473128 is a reply to message #473127] |
Fri, 08 June 2007 13:38 |
Doh!
In that case, the proper OCL would be
self.getProfile().profileApplication->forAll(isStrict)
Of course, this would require that MDT OCL support navigation of unnamed
association ends. It currently supports navigation of non-navigable ends,
but only if they are explicitly named.
This would be a good enhancement request for OCL 1.2 (hint).
Christian
> from the profile...
> Kenn
>> Hi, Nicolas,
>> HTH,
>> Christian
>>> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #473171 is a reply to message #473128] |
Mon, 11 June 2007 18:35 |
Nicolas Rouquette Messages: 157 Registered: July 2009 |
See below for responses to Christian & Kenn.
Christian W. Damus wrote:
> Doh!
Can you please confirm that you are referring to two associations in
org.eclipse.uml2.uml.resources/metamodels/UML.metamodel.uml, which,
in terms of the UML 2.1.1 spec (formal/2007-02-05) mean:
1) 'A_ownedStereotype_profile'
per '/ownedStereotype' in 18.3.6, p. 657
2) 'A_profileApplication_applyingPackage'
per 'applyingPackage' in 18.3.7, p. 664
If I grokked this right, I can write this enhancement request.
> Cheers,
> Christian
>> from the profile...
I am working with 3 profiles that define sub-languages of the UML: P1,
P2, P3.
P1 is the smallest sub-language.
P2 extends P1 (i.e., P1 is applied to P2)
P3 extends P1 and P2 (i.e., P1 and P2 are applied to P3)
A constraint Ci in a profile Pj can have two kinds of semantic roles:
- a "closed-world semantics" to ensure that a <<Pj>>-profiled instance
model is properly contained within the Pj sub-language of the UML.
- an "open-world semantics" that allows a <<Pj>>-profiled instance model
to be properly contained in a language L with the constraint that the Pj
sub-language of the UML must be a proper subset of L.
My convention is to associate a "strict" profile application to mean
that the applied profile has "closed-world semantics" and a "non-strict"
profile application mean that the applied profile has "open-world
semantics" for the model.
This seems to work fine except that the cost of checking strict vs.
non-strict profile application could be very expensive for large
instance models and/or large numbers of constraints with "closed-world
semantics".
-- Nicolas.
>> Kenn
>>> Hi, Nicolas,
>>> HTH,
>>> Christian
>>>> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #473172 is a reply to message #473171] |
Mon, 11 June 2007 18:56 |
Hi, Nicolas,
See some replies in-line, below.
Christian
>> Doh!
>> ends, but only if they are explicitly named.
I mean the owned end of A_profileApplication_appliedProfile, the end that is
opposite to the ProfileApplication::appliedProfile attribute.
Yes, anybody can request an enhancement, like this:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=MDT& bug_severity=enhancement&component=OCL&version=1.1.0
>> Cheers,
>> Christian
<snip>
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #619906 is a reply to message #473120] |
Hi, Nicolas,
HTH,
Christian
> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #619915 is a reply to message #473121] |
from the profile...
Kenn
> Hi, Nicolas,
> HTH,
> Christian
>> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #619916 is a reply to message #473127] |
Doh!
Christian
> from the profile...
> Kenn
>> Hi, Nicolas,
>> HTH,
>> Christian
>>> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #619981 is a reply to message #473128] |
> Doh!
> Cheers,
> Christian
>> from the profile...
P2, P3.
semantics".
-- Nicolas.
>> Kenn
>>> Hi, Nicolas,
>>> HTH,
>>> Christian
>>>> -- Nicolas.
Re: A better/cleaner way to determine ProfileApplication.isStrict within the context of a stereotype [message #619983 is a reply to message #473171] |
Hi, Nicolas,
Christian
>> Doh!
>> Cheers,
>> Christian
<snip>
Current Time: Tue Sep 24 13:13:45 GMT 2024
Powered by FUDForum. Page generated in 0.04742 seconds
