Home » Modeling » UML2 » Technical Documents for UML2
| Technical Documents for UML2 [message #473064] |
Thu, 31 May 2007 09:32  |
Originally posted by: nickkirtley.gmail.com
I'm going to extend the uml2 plugin. I was wondering if there is any
documentation available regarding the structure and inner workings of the
plugin.
And that of uml2tools as well.
regards,
Nick
| Re: Technical Documents for UML2 [message #473077 is a reply to message #473073] |
Fri, 01 June 2007 09:47   |
Nick,
The majority of the code in UML2 is based directly on the UML
specification - it is generated from a source model based on the UML
metamodel using (a customized version of) the EMF code generator, and this
approach is quite structured (it's model-driven). Most of our clients are
building tools that support UML modeling, and so that are interested in the
API based on the UML specification, for which there is ample documentation -
Javadoc and the UML specification itself. Certain aspects of the API are
"EMFisms", for which ample documentation is provided by the EMF project. The
articles on the UML2 documentation page provide a fairly good starting point
for becoming familiar with how to use the API in UML2, but of course there
always a need for more articles (as suggested by James).
We didn't initially expect many clients to develop plug-ins that extend the
UML2 plug-ins (that's why the implementation classes in UML2 are designated
as internal), but as interest in doing so has been increasing of late, we've
attempted to provide documentation to help our clients, in the form of a
long talk at EclipseCon 2007 (available from our documentation page at
http://www.eclipse.org/modeling/mdt/uml2/docs/presentations/ EclipseCon2007_LongTalk.html)
and articles on the various ways to extend UML2/UML (currently in draft
format attached to https://bugs.eclipse.org/bugs/show_bug.cgi?id=77413). We
appreciate any feedback you may have, and of course (as James also
suggested), contributions in this area are greatly appreciated!
Kenn
"Nick Kirtey" <nickkirtley@gmail.com> wrote in message
news:afc49a1406909002e445e8c2fd461eb1$1@www.eclipse.org...
> I'm not criticizing the project or anything but isn't documentation (as
> you work) important? Especially since the project is about software
> modelling. By using software modelling it suggests you develop programs in
> a structured way. Lack of documentation would only suggest that it's
> developed in an ad-hoc way.
| Re: Technical Documents for UML2 [message #473089 is a reply to message #473078] |
Mon, 04 June 2007 11:16   |
Hi James and Kenn,
I was just interested in general documentation about the implementation of
uml2. Not anything precise at the moment. And I won't be making any heavy
extensions, only light ones so really I'm not extending
uml2. However I will be developing a plugin that will use uml2, uml2-ocl and
uml2tools and having to integrate the 3 will require me to understand how
they work.
Actually my project consists of the following:
To develop a plugin/program that can model architectural primitives (see
http://portal.acm.org/citation.cfm?id=1094811.1094822 ). Architectural
primitives are basically a group of stereotypes
and as a whole they define entities that perform common tasks within
Architectural modelling (for example callback and layers), thus saving time
by not having to reinvent the wheel. The plugin should be able to
graphically model the primitives
and users should be able to add primitives themselves (probably by extending
the set of primitives described in the paper).
This will all be taking place in the component connector view.
Validation (hence the ocl questions) is also an important issue in the
project.
I still find the validation part of my project somewhat of a grey area. I
think the following should clarify why (I find it a grey area).
In the attached diagram I show the four UML layers of metamodeling
architecure. The diagram shows (1), (2) and (3).
These are three areas in which I want to validate the relevant layer. So (1)
is the metamodel validation, these constraints are embedded in uml2. (2) is
the stereotypes that extend the metaclasses
and also require validation. As I understand it , (2) does not have
validation at runtime, meaning that if I define stereotypes that extend
metaclasses (which in my case are the primtitives) I cannot
validate them when I model them??? which is (3) in my diagram!
As for implementing ocl constraints (the other thread I believe) - I would
like to try but not sure if I will be able to, I don't have much eclipse
development experience and am working hard on this project. However I could
give it a shot. This is actually another reason why it would be handy to
have a list of constraints that have/not been implemented - so that the
developer knows which ones to implement.
As for stubs, do you mean that methods have been left open for whoever is
going to implement the ocl constraints ?
your help is appreciated,
regards, Nick
| Re: Technical Documents for UML2 [message #473091 is a reply to message #473089] |
Mon, 04 June 2007 15:44   |
Hi Nick,
some comments below ..
- James.
"Nick Kirtley" <nickkirtley@gmail.com> wrote in message
news:f41abk$ba6$1@build.eclipse.org...
> Hi James and Kenn,
and
> they work.
time
extending
> project.
(1)
is
It is possible to validate constraints on stereotypes after they are applied
when you validate the model. Certain tools such as RSA have this
capability built in.
could
It would be easy for the user to create such a list by going through all the
XXXOperations() classes and checking which validateXXX stubs have not been
implemented.
Yes. A user could implement the stub ( based on OCL from the spec ) then
submit a patch to the opensource project. Those contributions will be
looked over and committed if they are ok.
> regards, Nick
| Re: Technical Documents for UML2 [message #473113 is a reply to message #473110] |
Thu, 07 June 2007 09:56  |
Hi Nick,
comments below...
"nick Kirtley" <nickkirtley@gmail.com> wrote in message
news:bb8bfbfdf6371532412aa78d5902baca$1@www.eclipse.org...
> about the constraint of steroetypes that extend metaclasses. These
> constraints should be validated as entered (which should only be a syntax
> kind of validation) and a validation when I model them - checking that the
> rules are not actually broken.
> Can I do this using uml2-ocl?
You can use UML2-ocl to do syntax checking of your OCL expression. You can
check out the "New and Noteworthy" of the OCL component.
> The fact that RSA has it only means that
> it's possible with a lot of work and a lot of development.
Runtime validation of OCL expressions for applied steroetypes is possible to
do without a "lot" of code development. That particular capability was not
added since it would introduce a circular build dependency on the OCL
component. That is a feature that could be added to the UMLTools component
for example.
> I'm asking because it says in the
> Customizing UML:Which technique is right for you?
> document, the following:
> Q:Add new constraints
> A:Yes
> Add OCL constraints. Currently no runtime checks
> I think this would mean that you cannot check the constraints within a
> model.
The capability to evaluate OCL constraints on Models is now supported.
Evaluating OCL constraints on Stereotypes that have been applied to a model
is possible with minor modifications but has not been added because of build
dependencies on the OCL component.
> regards,
> Nick
| Re: Technical Documents for UML2 [message #619418 is a reply to message #473064] |
Thu, 31 May 2007 15:22  |
Nick,
There is no real documentation on how to extend the plugin directly but
there is documentation on how to extend the UML metamodel.
If you had specific questions regarding extending the plugin you could ask
them here.
If there are features lacking you could also request enhancements through
bugzilla.
- James.
news:bae5208b9f61803948eed23973d65271$1@www.eclipse.org...
> plugin.
> regards,
> Nick
| Re: Technical Documents for UML2 [message #619420 is a reply to message #473066] |
Thu, 31 May 2007 15:42  |
.... oh yeah ... you can also contribute code / documentation yourself....
contributions are always welcomed.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f3n7a4$e39$2@build.eclipse.org...
> Nick,
> them here.
> bugzilla.
> - James.
> > Hi,
the
> > plugin.
> > regards,
> > Nick
| Re: Technical Documents for UML2 [message #619433 is a reply to message #473067] |
Fri, 01 June 2007 04:26  |
| Re: Technical Documents for UML2 [message #619441 is a reply to message #473073] |
Nick,
Kenn
| Re: Technical Documents for UML2 [message #619666 is a reply to message #473073] |
Fri, 01 June 2007 09:57  |
Hi Nick,
- There are documents being produced as development takes place
- Some of the getting started articles are slightly out of date because
there is a focus on new features/bug fixing in the beginning of the cycle
and documents get updated at the end of the cycle after code freeze.
- There are also Eclipse-Con presentations explaining how to extend the
meta-model and of course, the official UML spec at OMG.org.
When you say "extend the uml plugin" I think you probably really want to
create heavy-weight extensions to UML? There is documentation on that as
mentioned previously.
What other documentation would you like to see precisely?
- James.
| Re: Technical Documents for UML2 [message #619677 is a reply to message #473078] |
Hi James and Kenn,
they work.
project.
regards, Nick
| Re: Technical Documents for UML2 [message #619679 is a reply to message #473089] |
Hi Nick,
- James.
> Hi James and Kenn,
and
> they work.
time
extending
> project.
(1)
is
could
implemented.
> regards, Nick
| Re: Technical Documents for UML2 [message #619775 is a reply to message #473091] |
Thu, 07 June 2007 07:58  |
Can I do this using uml2-ocl? The fact that RSA has it only means that
A:Yes
model.
regards,
Nick
| Re: Technical Documents for UML2 [message #619780 is a reply to message #473110] |
Hi Nick,
comments below...
for example.
> A:Yes
> model.
> regards,
> Nick
Current Time: Wed Nov 05 15:19:01 EST 2025
Powered by FUDForum. Page generated in 0.08670 seconds
