Home » Eclipse Projects » JavaServer Faces » Setup Visual Page Designer
Setup Visual Page Designer [message #472943] |
Tue, 12 September 2006 15:58 |
Originally posted by: marcomangiante.despammed.com
I'm totally new to eclipse, and I see that finally there is a great effort
to give at the project a visual designer for web page, and overall for
jsf. I am a beginner of jsf, but I like it. Until now I used the Sun Java
Studio Creator, but it is not open source, so now because it is possible
to have a designer in eclipse, I decided to switch to yours.
Like I say I am completely new to the IDE, so my question is: how to build
the designer so I can use as plug in?
I read on the "bug" page where the designer is presented this sentence:
"The plugins here can then be imported to the workspace as source and run
as a
child workbench"
Can someone help me to do this, or give me step by step guide to use the
plugin, or point me on documentation?
Thanks in advance for the help and excuse me for my bad english.
Marco Mangiante
Re: Setup Visual Page Designer [message #472945 is a reply to message #472944] |
Tue, 12 September 2006 21:13 |
Hi Cam,
first of all thank for your post and your attention. I'll try it and say
if it all goes well.
Now my second question is: every time that I want to use the visual page
designer, I must do all these operations?
Thanks in advance for your help.
Marco Mangiante
> Hi Marco,
> I should point out that the VPD has not been fully integrated yet which is
> why it is hard to get up and going with it. In the mean time it is there
> to try it out.
> Try these steps:
> --Cam
Re: Setup Visual Page Designer [message #472949 is a reply to message #472946] |
Wed, 13 September 2006 17:13 |
Hello Cam,
I do all the steps that you have written on the previous post but found a
problem. If I click on the jsp page and do the command Open with, there is
no page designer. I think that the problem is connected to an error that I
have received when I created the dynamic web project: it seems that the
system can't create jsf and I received this message box:
Failed while installing JavaServer Faces 1.1
If I click on "Details" button in the message box the error is:
Sincerely I don't understand why I received this error, maybe it is
connected to my beginner phase with the IDE.
Another question: you say to click "Import" in the "Project workspace".
What kind of project I must create? Infact in the "Import" dialog there is
a message that you must link the pagedesigner.zip file with an open
project.
Hope you can help me.
Marco Mangiante
Re: Setup Visual Page Designer [message #472951 is a reply to message #472950] |
Thu, 14 September 2006 07:14 |
Hi Cam,
thanks for your continuous help. I tried to create a web dynamic project,
but I received the error that I write in the previous post regarding the
jsf. Now, I think I not installed well the jsf plugin, so I say what I do:
1. Downloaded the file
wtp-all-in-one-sdk-R-1.5.0-200606281455-linux-gtk.tar.tar and extracted it
in my home directory.
2. Downloaded the file wtp-jsf-R-1.5.0-200606281455 and extracted it in
eclipse directory (and I remember it ask to overwrite some files).
Now my question: is this the good way to do or I must install the basic
jsf plugin in another way? I know that I can install the wtp related
package from a, say, clean installation of eclipse sdk, but it takes much
time with 56k, so I downloaded the first file that include all.
Hope you can help.
Marco Mangiante
Re: Setup Visual Page Designer [message #472952 is a reply to message #472951] |
Thu, 14 September 2006 17:00 |
Cameron Bateman Messages: 481 Registered: July 2009 |
The packages you have downloaded should work. That should provide
everything you need. Do you still get those JSF errors with these zips
installed?
--Cam
Marco Mangiante wrote:
> Hi Cam,
> Hope you can help.
> Regards,
> Marco Mangiante
Re: Setup Visual Page Designer [message #472953 is a reply to message #472952] |
Thu, 14 September 2006 21:51 |
Hi Cam,
I still have the problem, but I do want some experimentation: I wanna do
the step by step instructions that are present in eclipse jsf
documentation for a simple hello world jsf application.
However, even with the error, eclipse load the project and if I add a jsp
file and click with right mouse click on it, the menu show the web page
editor shot. If I click on it I obtain a window similar to that of sybase
presentation of june, but if I show the "Palette", I have only html and
jsp voices and no jsf core and jsf html.
Have you some explanation for these two problems? Is there a simple sample
jsf application that I can download and try the web page designer on it?
Thank you very much for your patience and support.
Marco Mangiante
P.S.: I'm using eclipse in kubuntu 6.06 with sun java 5 vm
> installed?
> --Cam
Re: Setup Visual Page Designer [message #472956 is a reply to message #472954] |
Mon, 18 September 2006 11:03 |
Hi Cam,
> So do I understand correctly that have successfully loaded everything
> except that the pallete for the visual editor does not contain core or
> html?
> If that is correct, then I think you will need to put a JSF implementation
> on the on your class path. You can do this by downloading the
> implementation JARS (a free one can be download from myfaces.apache.com)
> and adding them as JSF component libraries. There should be information
> about adding component libraries in the docs.
Now it works. I have the palette with JSF Core and JSF HTML, but also have
other entries (now I'm not in front of the program, I write you the other
in another post). I followed your suggestion. Now I try to do some
experimentation.
Marco Mangiante
Re: Setup Visual Page Designer [message #606110 is a reply to message #472944] |
Hi Cam,
Marco Mangiante
> Hi Marco,
> to try it out.
> Try these steps:
> --Cam
Re: Setup Visual Page Designer [message #606127 is a reply to message #472946] |
Hello Cam,
project.
Marco Mangiante
Re: Setup Visual Page Designer [message #606134 is a reply to message #472950] |
Hi Cam,
Hope you can help.
Marco Mangiante
Re: Setup Visual Page Designer [message #606137 is a reply to message #472951] |
installed?
--Cam
> Hi Cam,
> Hope you can help.
> Regards,
> Marco Mangiante
Re: Setup Visual Page Designer [message #607611 is a reply to message #472952] |
Hi Cam,
Marco Mangiante
> installed?
> --Cam
Re: Setup Visual Page Designer [message #607614 is a reply to message #472954] |
Hi Cam,
> html?
experimentation.
Marco Mangiante
Current Time: Mon May 13 07:32:45 GMT 2024
Powered by FUDForum. Page generated in 0.04875 seconds
