Home » Modeling » UML2 » Problem creating LinkEndData and LinkEndDestructionData
Problem creating LinkEndData and LinkEndDestructionData [message #472910] Wed, 16 May 2007 05:46 Go to next message
Originally posted by: francois.nizou.thalesgroup.com
Greeting,
I've encountered an issue using UML2:
I have a model, a class within, this class have a Behavior Activity and
this activity a Node Create (or Delete) Link Action.
The creation of two types of child within those nodes, "LinkEndData" and
"Link End Desctruction Data" doesn't work.
The log shows the following:
eclipse.buildId=M20060921-0945
java.version=1.6.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
Warning
Wed May 16 11:01:07 CEST 2007
An exception was ignored during command execution
org.eclipse.emf.common.util.WrappedException: An exception was ignored
org.eclipse.emf.common.command.BasicCommandStack.handleError (BasicCommandStack.java:279)
org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:98)
org.eclipse.emf.edit.ui.action.StaticSelectionCommandAction. run(StaticSelectionCommandAction.java:230)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:188)
org.eclipse.emf.common.util.BasicEList.addAllUnique(BasicELi st.java:774)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddAl lUnique(NotifyingListImpl.java:494)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:435)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:396)
at org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:688)
org.eclipse.emf.edit.command.AddCommand.doExecute(AddCommand .java:400)
org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:128)
org.eclipse.emf.common.command.CommandWrapper.execute(Comman dWrapper.java:179)
org.eclipse.emf.edit.command.CreateChildCommand.execute(Crea teChildCommand.java:258)
org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:91)
... 27 more
After that, the editor is in an inconsistant state and throws
NullPointerException when selecting the Node Action.
Note: The problem doesn't occur for Node Read Link Action
I've tried the same operation on two differents versions of Eclipse (with
UML 2.0.1 UML 2.0.3) and editors (UML2 editor and Acceleo Reflective
editor) and the result remains the same.
Does anyone has an idea of what is happening when using type of Action?
Many thanks in advance,
François
Re: Problem creating LinkEndData and LinkEndDestructionData [message #472912 is a reply to message #472910] Wed, 16 May 2007 16:56 Go to previous messageGo to next message
Fran
Re: Problem creating LinkEndData and LinkEndDestructionData [message #472924 is a reply to message #472912] Mon, 21 May 2007 11:07 Go to previous message
kenn,
i've submited a report, thank you.
Francois.
Re: Problem creating LinkEndData and LinkEndDestructionData [message #615880 is a reply to message #472910] Wed, 16 May 2007 16:56 Go to previous message
Fran
Re: Problem creating LinkEndData and LinkEndDestructionData [message #617171 is a reply to message #472912] Mon, 21 May 2007 11:07 Go to previous message
kenn,
Francois.
Previous Topic:Load Model from Enterprise Architect
Next Topic:Refactor Action
Current Time: Wed Oct 29 23:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.79935 seconds
