Home » Modeling » UML2 » Exporting UML diagram and profile
Exporting UML diagram and profile [message #472898] |
Mon, 14 May 2007 09:42 |
Originally posted by: antti.evesti.vtt.fi
I have a problem with exporting UML model with the profile, i.e.
component diagram and applied profile. I have made component diagram which
contains stereotypes from UML profile, this is just I wish. However, when
I save the model and try open it from another project the problem appears.
The saved component diagram does not find the needed UML profile. So how I
must apply UML profile to the diagram, so that I can open diagram in
another project? Of course, I have moved both files to another project,
i.e. the component diagram and UML profile file.
Footnote, I am not trying make this by code, just using UML2 editor of
Eclipse.
BR,
Antti
Re: Exporting UML diagram and profile [message #473100 is a reply to message #472900] |
Wed, 06 June 2007 12:58 |
Ok. But is these pathmaps something that has to be used via a programmatic
approach, or can I utilize it via the UML editor of Eclipse? Because I tried
to find the right place from the UML editor but I cannot find anything
relating about 'pathmaps'
Antti
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f29ljm$d0s$1@build.eclipse.org...
> Antti,
> The profile must exist in the same location (relative to the model) in
> order to successfully open it from another project. The alternative is to
> use "pathmaps" as a way of referencing profiles (and other shared
> resources) in a location-neutral way. If you do a search on this and/or
> the legacy UML2 newsgroup (eclipse.tools.uml2) you'll be sure to find
> useful information on how to use pathmaps...
> Kenn
> "Antti Evesti" <antti.evesti@vtt.fi> wrote in message
> news:a548b799946cfcafbacae5be98a8cbc8$1@www.eclipse.org...
>> Hi,
>> I have a problem with 'exporting' UML model with the profile, i.e.
>> which contains stereotypes from UML profile, this is just I wish.
>> However, when I save the model and try open it from another project the
>> problem appears. The saved component diagram does not find the needed UML
>> profile. So how I must apply UML profile to the diagram, so that I can
>> open diagram in another project? Of course, I have moved both files to
>> another project, i.e. the component diagram and UML profile file.
>> Eclipse.
>> BR,
>> Antti
Re: Exporting UML diagram and profile [message #473104 is a reply to message #473100] |
Wed, 06 June 2007 17:37 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Antti,
"Pathmaps" must be declared either programmatically or via the EMF extension
point; there is no UI available to manage them in UML2.
Kenn
"Antti" <antti.evesti@vtt.fi> wrote in message
news:f46b1k$esd$1@build.eclipse.org...
> tried to find the right place from the UML editor but I cannot find
> anything relating about 'pathmaps'
> Antti
>> Antti,
>> Kenn
>>> Hi,
>>> UML profile. So how I must apply UML profile to the diagram, so that I
>>> can open diagram in another project? Of course, I have moved both files
>>> to another project, i.e. the component diagram and UML profile file.
>>> Eclipse.
>>> BR,
>>> Antti
Re: Exporting UML diagram and profile [message #473123 is a reply to message #473104] |
Fri, 08 June 2007 05:42 |
So, I have to make an own plug-in, which make it possible to add profiles to
UML models in a consistent way.
Antti
news:f46rck$8jn$1@build.eclipse.org...
> Antti,
> extension point; there is no UI available to manage them in UML2.
> Kenn
>> programmatic approach, or can I utilize it via the UML editor of Eclipse?
>> Because I tried to find the right place from the UML editor but I cannot
>> find anything relating about 'pathmaps'
>> Antti
>>> Antti,
>>> to use "pathmaps" as a way of referencing profiles (and other shared
>>> Kenn
>>>> Hi,
>>>> Eclipse.
>>>> BR,
>>>> Antti
Re: Exporting UML diagram and profile [message #619751 is a reply to message #472900] |
Antti
> Antti,
> Kenn
>> Hi,
>> Eclipse.
>> BR,
>> Antti
Re: Exporting UML diagram and profile [message #619762 is a reply to message #473100] |
Antti,
Kenn
> Antti
>> Antti,
>> Kenn
>>> Hi,
>>> Eclipse.
>>> BR,
>>> Antti
Re: Exporting UML diagram and profile [message #619910 is a reply to message #473104] |
Antti
> Antti,
> Kenn
>> Antti
>>> Antti,
>>> Kenn
>>>> Hi,
>>>> Eclipse.
>>>> BR,
>>>> Antti
Current Time: Fri Apr 26 08:50:42 GMT 2024
Powered by FUDForum. Page generated in 0.03643 seconds
