| Images in Use Case [message #472678] |
Wed, 23 January 2008 13:19  |
Hello!!!
I would like to know where should I change in the source code, to modify
the default images (the images in toolbar) from th Use Case Diagram.
Thanks...
Raphael
| Re: Images in Use Case [message #472689 is a reply to message #472683] |
Wed, 23 January 2008 15:44   |
Hello Tatiana!!!
Ok, I found this line in UMLElementTypes class:
public static final IElementType Actor_2002 =
getElementType("org.eclipse.uml2.diagram.usecase.Actor_2002 ");
//$NON-NLS-1$
So sorry for the question, but, where did it find the location in my
computer for the images?!?
Does it search for images in
"\org.eclipse.uml2.diagram.common\icons\obj16" directory?! If yes, where
should I change this in the source?!?
Thanks again Tatiana,
Thanks for your pacience!!
Raphael
Tatiana Fesenko wrote:
> Hello Raphael,
> To change an icon in the palette entry go to
UMLPaletteFactory#create<element_kind>CreationTool().
> Modify code that sets icon.
> For Actor element it will be 'createActor2CreationTool()' method,
entry.setSmallIcon(UMLElementTypes.getImageDescriptor(UMLEle mentTypes.Actor_2002));
> code.
> Best wishes,
> Tatiana.
>> Hello!!!
>> modify the default images (the images in toolbar) from th Use Case
>> Diagram.
>> Thanks...
>> Raphael
| Re: Images in Use Case [message #472698 is a reply to message #472689] |
Thu, 24 January 2008 07:17  |
Hello Raphael!!
As I understand now, you want to change icons everywhere - not only in the
toolbar, but also element icons and icons in the modeling assistant.
Icons are provided by UMLItemProviderAdapterFactory class from org.eclipse.uml2.uml.edit
plugin. It takes them from org.eclipse.uml2.uml.edit\icons\obj16.
You can implement your own UMLItemProviderAdapterFactory which returns icons
that you need. You can take AlternativeUMLItemProviderAdapterFactory from
our org.eclipse.uml2.diagram.common plugin as example. It is it that takes
icons from \org.eclipse.uml2.diagram.common\icons\obj16. This factory provides
alternative icons in ClassD if a user changes icon style in the preferences
page.
Best wishes,
Tatiana.
> Hello Tatiana!!!
> //$NON-NLS-1$
> where should I change this in the source?!?
> Raphael
>> Hello Raphael,
>> Modify code that sets icon. For Actor element it will be
> Actor_2002));
>> code.
>> Best wishes,
>> Tatiana.
>>> Hello!!!
>>> Diagram.
>>> Thanks...
>>> Raphael
| Re: Images in Use Case [message #617089 is a reply to message #472678] |
Wed, 23 January 2008 13:31  |
Hello Raphael,
To change an icon in the palette entry go to UMLPaletteFactory#create<element_kind>CreationTool().
code.
Best wishes,
Tatiana.
> Hello!!!
> Diagram.
> Thanks...
> Raphael
| Re: Images in Use Case [message #617095 is a reply to message #472683] |
Hello Tatiana!!!
//$NON-NLS-1$
Raphael
> Hello Raphael,
> code.
> Best wishes,
> Tatiana.
>> Hello!!!
>> Diagram.
>> Thanks...
>> Raphael
| Re: Images in Use Case [message #617552 is a reply to message #472689] |
Hello Raphael!!
page.
Best wishes,
Tatiana.
> Hello Tatiana!!!
> //$NON-NLS-1$
> Raphael
>> Hello Raphael,
> Actor_2002));
>> code.
>> Best wishes,
>> Tatiana.
>>> Hello!!!
>>> Diagram.
>>> Thanks...
>>> Raphael
FUDForum. Page generated in 0.06379 seconds
