Home » Eclipse Projects » Platform - User Assistance (UA) » Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets
Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets [message #472380] |
Thu, 13 March 2008 18:07 |
mowry Messages: 51 Registered: July 2009 |
Member |
In my RCP application, Ctrl-C, Ctrl-V, orCtrl-X doesn't work as expected.
I tested in dialogs, editors,..
Is there any thing missing in my rcp application? or is something I added
without knowingly causing this problem.
Note: When I use right mosue options copy, paste, or cut works fine as
expected.
Mowry
Re: Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets [message #472383 is a reply to message #472380] |
Fri, 14 March 2008 20:08 |
Chris Goldthorpe Messages: 815 Registered: July 2009 |
Cross posting to the swt and rcp newsgroups
mowry wrote:
> added without knowingly causing this problem.
> expected.
> Mowry
Re: Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets [message #472384 is a reply to message #472383] |
Fri, 14 March 2008 21:00 |
Carolyn MacLeod Messages: 149 Registered: July 2009 |
Please say which OS you are running on, which version of eclipse, and if
possible please provide an SWT snippet that shows the problem.
http://www.eclipse.org/swt/snippets/
Carolyn
"Chris Goldthorpe" <cgold@us.ibm.com> wrote in message
news:frelv1$1ur$2@build.eclipse.org...
> mowry wrote:
>> Hi,
>> expected.
>> Thanks,
>> Mowry
Re: Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets [message #472385 is a reply to message #472384] |
Sat, 15 March 2008 00:54 |
Member |
I am on windows-xp, eclipse 3.3.1.
I tested with simple InputDialog.
Here is the code snippet:
InputDialog d = new
InputDialog(HandlerUtil.getActiveShell(event),"New Folder", "Enter the
folder name", "",null);
d.open();
In this particular scenario, Ctrl-C doesn't work, but ctrl-x works.
in some other places nothing works.But all right mouse options works as
expected.
Mowry
Re: Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets [message #610610 is a reply to message #472380] |
mowry wrote:
> expected.
> Mowry
Re: Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets [message #610613 is a reply to message #472383] |
Carolyn
> mowry wrote:
>> Hi,
>> expected.
>> Thanks,
>> Mowry
Re: Ctrl-C, Ctrl-V, or Ctrl-X doesn't work in swt widgets [message #610616 is a reply to message #472384] |
Member |
InputDialog d = new
d.open();
expected.
Mowry
Current Time: Fri Apr 26 11:21:25 GMT 2024
Powered by FUDForum. Page generated in 0.04068 seconds
