Re: help contexts question [message #472297] |
Tue, 05 February 2008 09:24  |
The newsgroup for Help-related discussion is eclipse.platform.ua; I'm
redirecting this thread to there.
Derek Morris wrote:
> Apologies if this is the wrong place to ask this question - I looked but
> couldn't find a better one.
> I am trying to define and use help contextIds across plugins. I have a
> single documentation plugin and wish to use helpContextIds from my other
> plugins.
> In my documentation plugin.xml I have defined:
> <extension
> point="org.eclipse.help.contexts">
> <contexts
> file="helpContexts.xml"
> plugin="com.mydocsplugin">
> </contexts>
> </extension>
> In the plugin.xml of another plugin, I have defined:
> <extension
> <contexts
> plugin="com.crt.docs">
> </contexts>
> </extension>
> But this doesn't work (I get a file not found warning for
> helpContexts.xml). In the manifest editor, the "Browse" for the file
> only shows files in this plugin and not in the docs plugin.
> I've read the docs, but there is very little detail. Can anybody point
> me in the right direction for solving this?
> Thanks
Re: help contexts question [message #472301 is a reply to message #472298] |
Wed, 06 February 2008 07:32  |
Perfect - thats exactly what I wanted!
Now, why isn't that documented better - it's so easy!
Thanks for your help.
Derek
Chris Goldthorpe wrote:
> You are not alone in finding the docs confusing.
> Each context is defined by a context id and a plugin id. When your Java
> code includes a line like this:
> PlatformUI.getWorkbench().getHelpSystem().setHelp(viewer.get Control(),
> "org.eclipse.test.viewer");
> it defines the context id to be "viewer" and the context plugin to be
> "org.eclipse.test". setHelp() should probably take two parameters, one
> for the context id and one for the plugin id but instead it uses just
> one parameter. When you hit F1 it will look for a context id of "viewer"
> associated with plugin "org.eclipse.test".
> In the extension point the "file" is always the path of a file from the
> same plugin as the plugin.xml file which defines the contexts. The
> "plugin" parameter if present defines the plugin id for any contexts in
> that file, if omitted the plugin id will be that of the enclosing plugin.
> The idea behind this is that you can define the contexts in a plugin
> different to the one in which your java code lives, and you have
> multiple contributions to the same context.
Re: help contexts question [message #609374 is a reply to message #472297] |
Tue, 05 February 2008 19:49  |
Re: help contexts question [message #609380 is a reply to message #472298] |
Derek
FUDForum. Page generated in 0.03466 seconds
