Home » Modeling » UML2 » Transition Effects Calling Methods of Classes Visible to State Machine Owner
Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471360] |
Wed, 07 March 2007 15:06 |
Originally posted by: mtribast.inf.ed.ac.uk
Hi all,
I have a UML2 model describing two classes A and B with an association
which makes an instance of B be visible to A (A.b). A owns a state
machine. I would like a transition in that state machine to have an
Effect calling a method b.doSomething(). I've tried to accomplish this
both programmatically and graphically by using RSA, with no luck.
Could you point me to the correct UML2 API for creating such an effect?
Thanks in advance for your help.
Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471625 is a reply to message #471624] |
Thu, 08 March 2007 15:51 |
Hi James,
Many thanks for this. I tried to do as you suggested and now I have an
Interaction under the Opaque Behavior representing the effect of my
transition. However, the model doesn't validate and I get the following
error:
Assembly connector '<Connector>' must only be defined from a role end
requiring an interface to a role end providing that interface.
The sequence diagram has two lifelines a:A and b:B and the message
b.doSomething. As the problem occurs every time I create an interaction
between two associated classes, I think I might be developing the model
in a wrong way. On the other hand, the validation on the RSA sample
sequence diagrams gives the same results. Any ideas about that?
Thanks again for your time
Cheers
Mirco
James Bruck wrote:
> ... From RSA it looks like when you create an effect you get an opaque
> behavior.
> You can create your interaction with sequence diagram under that opaque
> behavior.
> In general, you should be able to simply create an Interaction as the
> effect.
> - James.
> "James Bruck" <jbruck@ca.ibm.com> wrote in message
> news:esnlr2$hhu$1@utils.eclipse.org...
>> Hi Mirco,
>> An effect is a Behavior. I would suggest creating an Interaction (
> which
>> is a Behavior ) and specify a lifeline b:B that with a message whose
>> signature is "doSomething()". Set your effect to be that Interaction.
>> "An effect is just an optional behavior that is performed when the
>> transition fires"
>> Regards,
>> - James.
>> "Mirco Tribastone" <mtribast@inf.ed.ac.uk> wrote in message
>> news:esmkn1$9r0$1@utils.eclipse.org...
>>> Hi all,
> Effect
>>> calling a method b.doSomething(). I've tried to accomplish this both
>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471626 is a reply to message #471625] |
Thu, 08 March 2007 17:50 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Mirco,
RSA creates an assembly connector between the two lifelines indicating that
there is some communication at runtime.
RSA does this because they can automatically generate communication diagrams
from the sequence diagram. Those communication diagrams require the
specification of the connector to show that the two lifelines interact ( ie
Message Pathways are Connectors ).
You can understand this better by deleting automatically generated connector
under the interaction, then select the interaction and create a
communication diagram.
Now, put the connector back and create a communication diagram by selecting
the interaction and creating the diagram.
In one case, the lifelines are connected, in the other, they are disjoint.
The validation rule is complaining because of constraints around connectors
requiring assembly connectors to be connected to "compatible" Connectable
Elements. Your model in effect is incomplete ( it should just be a warning
by the way .. not an error ).
If your lifelines were typed by components requiring and providing
interfaces you would not get this warning. You can complete your model
by creating Interface realizations and Usages from the classifiers typing
the lifeline's to a common interface. You might alternatively use a
Composite structure diagram to complete your model.
However, you could simply delete the connector and consider your sequence
diagram to be a "sketch" as opposed to a completely specified model.
- James.
news:espboi$4b5$1@utils.eclipse.org...
> Hi James,
> error:
> Cheers
> Mirco
> > behavior.
> > behavior.
> > effect.
> > - James.
> >> Hi Mirco,
> > which
> >> transition fires"
> >> Regards,
> >> - James.
> >>> Hi all,
> > Effect
effect?
> >>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471630 is a reply to message #471626] |
Fri, 09 March 2007 10:52 |
Hi James,
Thank you for your thorough and interesting reply. I completed my model
by creating an interface exposing doSomething(). B realizes the
interface and A uses it. Now the model validates.
I have one more question about the UML metamodel and its relationship
with RSA and the UML2 API. I actually realized that I could make the
model simpler by getting rid of the classes owning the state machines,
as a state machine is itself a class according to the UML2 API.
Therefore I now have two state machines for which I want to describe the
communication between each other. I drew a little class diagram
including the two state machines A and B as well as the common interface
as you suggested. I wanted to draw an interface realization line between
B and the interface but apparently I am not allowed to do so. My
question is: Am I doing something wrong or doesn't RSA support offer
this possibility?
Thank you again
Mirco
James Bruck wrote:
> Hi Mirco,
> Regards,
> - James.
>> Hi James,
>> error:
>> Cheers
>> Mirco
>>> behavior.
>>> behavior.
>>> effect.
>>> - James.
>>>> Hi Mirco,
>>> which
>>>> transition fires"
>>>> Regards,
>>>> - James.
>>>>> Hi all,
>>> Effect
> effect?
>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471631 is a reply to message #471630] |
Fri, 09 March 2007 14:46 |
Hi Mirco,
I'll try not to turn this into a RSA forum but from what you describe, you
should be able to draw that interface realization.
I have made myself a little model that I think follows what you are doing
and it seems to work.
From what I understand your state machine does not have a context and you
are having problems because you cannot visualize that statemachine as a
class on a class diagram and then draw an interface realization. Try
selecting your State Machine, then go to the Properties > Advanced. Now
select the collections editor. Select Interface Realization and then browse
to the interface you are interested in. ( There might be an easier way that
I'm unaware of ). In general, you have access to all the opensource
options via the advanced tab in RSA. More common properties are added to
other tabs.
If you could describe the ultimate problem you are trying to solve there is
a slim chance I might be able to make semi-reasonable comments :)
- James.
news:esrekf$n2$1@utils.eclipse.org...
> Hi James,
> this possibility?
> Thank you again
> Regards,
> Mirco
> James Bruck wrote:
> > Hi Mirco,
that
diagrams
( ie
connector
selecting
disjoint.
connectors
Connectable
warning
model
typing
sequence
> > Regards,
> > - James.
> >> Hi James,
> >> error:
> >> Cheers
> >> Mirco
> >>> behavior.
opaque
> >>> behavior.
> >>> effect.
> >>> - James.
> >>>> Hi Mirco,
> >>> which
Interaction.
> >>>> transition fires"
> >>>> Regards,
> >>>> - James.
> >>>>> Hi all,
association
> >>> Effect
> > effect?
> >>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471632 is a reply to message #471631] |
Fri, 09 March 2007 17:07 |
Hi James,
I'm sorry for having (ab)used this newsgroup for RSA-related isses.
Thank you for your patience in answering these questions.
Well, I try to describe what I'm doing in a few lines. Basically I want
to apply UML to a formal language which ultimately lets me do
performance modeling of the system under study. I'd like to be able to
draw a model and get analysis results back after the model has been
evaluated using this formal language. So, RSA is the graphical tool and
I use the UML2 API to do the mapping, carry out performance analysis and
annotate the results in the UML model.
UML is a lot bigger and far more complicated than the meta-model of the
formal language, so I am now working on figuring out what is the best
subset of the UML which lets me do that. I think there are different
ways and I want to analyze their pros and cons in order to focus on the
simplest and most intuitive one. The main constraint is that the model
drawn using RSA should validate OK.
The main problem I've had so far is how to model interaction between two
state machines, i.e. an effect of a transition of a state machine
calling a method of another class visible to that state machine. This
discussion has been very helpful to give me insights into that. I'm not
entirely happy with the solution of state machines exposing interfaces
in order to have a valid sequence diagram which models their interaction.
I would very much appreciate a "semi-reasonable comment" ;-) on whether
you would suggest drawing a Composite structure diagram instead.
Mirco
James Bruck wrote:
> Hi Mirco,
> other tabs.
> Regards,
> - James.
>> Hi James,
>> this possibility?
>> Thank you again
>> Regards,
>> Mirco
>> James Bruck wrote:
>>> Hi Mirco,
> that
> diagrams
> ( ie
> connector
> selecting
> disjoint.
> connectors
> Connectable
> warning
> model
> typing
> sequence
>>> Regards,
>>> - James.
>>>> Hi James,
>>>> error:
>>>> Cheers
>>>> Mirco
>>>>> behavior.
> opaque
>>>>> behavior.
>>>>> effect.
>>>>> - James.
>>>>>> Hi Mirco,
>>>>> which
> Interaction.
>>>>>> transition fires"
>>>>>> Regards,
>>>>>> - James.
>>>>>>> Hi all,
> association
>>>>> Effect
>>> effect?
>>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471633 is a reply to message #471632] |
Fri, 09 March 2007 23:07 |
Hi Mirco,
I don't want to give you the impression that you 'have' to expose interfaces
from your state machine. There are many different ways to complete your
model. You might want to use ports etc.
You might want to see some of the draft articles here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=77413 for some ideas on
extending UML or restricting yourself to those language units you might be
interested in.
Composite structure diagram is your best bet to fine tune the interaction
between parts/ports. Lifelines represent ConnectableElements ... parts and
ports are connectable elements.
( By the way I hope you have RSA 7.x ... there are some nice enhancements in
this version that try to hide some "nastiness" when creating required and
provided interfaces :) ).
-James.
news:ess4ja$nkb$1@utils.eclipse.org...
> Hi James,
> Regards,
> Mirco
> James Bruck wrote:
> > Hi Mirco,
you
doing
you
Now
browse
that
to
> > other tabs.
is
> > Regards,
> > - James.
> >> Hi James,
the
interface
between
> >> this possibility?
> >> Thank you again
> >> Regards,
> >> Mirco
> >> James Bruck wrote:
> >>> Hi Mirco,
> > that
> > diagrams
> > ( ie
> > connector
> > selecting
> > disjoint.
> > connectors
> > Connectable
> > warning
> > model
> > typing
> > sequence
> >>> Regards,
> >>> - James.
> >>>> Hi James,
an
following
> >>>> error:
interaction
model
> >>>> Cheers
> >>>> Mirco
opaque
> >>>>> behavior.
> > opaque
> >>>>> behavior.
the
> >>>>> effect.
> >>>>> - James.
> >>>>>> Hi Mirco,
> >>>>> which
whose
> > Interaction.
> >>>>>> transition fires"
> >>>>>> Regards,
> >>>>>> - James.
> >>>>>>> Hi all,
> > association
an
> >>>>> Effect
both
> >>> effect?
> >>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471634 is a reply to message #471633] |
Sat, 10 March 2007 02:25 |
.... two other points...
You pointed out that a StateMachine is a Class and therefore doesn't have to
have any context. Although this is technically true, I'm not sure what it
really means to have a Behavior with no context. From the spec p. 447 "
Behavior is a specification of how its context classifier changes state over
time..." p448 shows the cardinality of context to be [0..1] suggesting it is
ok to be 0 but I question how practical that is. I believe that a behavior
is a class is a side effect of behaviors requiring attributes, operations
and other inherited attributes.
Also, the constraint you were getting hung up on is described on p159
constraint [5] "An assembly connector must only be defined from a required
Interface or Ports to a provided Interface or Port". From what I
understand, there is an issue raised on OMG to relax some of the constraints
on connectors ( this one in particular) that would allow your model to
validate ( once adopted into the spec ).
I'll follow up on that first point and get back to you with the intent of
"context".
- James.
news:esspcb$mea$2@utils.eclipse.org...
> Hi Mirco,
> interfaces
> interested in.
> and
> in
> Cheers,
> -James.
>> Hi James,
>> Regards,
>> Mirco
>> James Bruck wrote:
>> > Hi Mirco,
> you
> doing
> you
> Now
> browse
> that
> to
>> > other tabs.
>> > there
> is
>> > Regards,
>> > - James.
>> >> Hi James,
>> >> model
> the
> interface
> between
>> >> this possibility?
>> >> Thank you again
>> >> Regards,
>> >> Mirco
>> >> James Bruck wrote:
>> >>> Hi Mirco,
>> >>> indicating
>> > that
>> > diagrams
>> >>> interact
>> > ( ie
>> > connector
>> > selecting
>> > disjoint.
>> > connectors
>> > Connectable
>> > warning
>> > model
>> > typing
>> > sequence
>> >>> Regards,
>> >>> - James.
>> >>>> Hi James,
> an
> following
>> >>>> error:
>> >>>> end
> interaction
> model
>> >>>> Cheers
>> >>>> Mirco
> opaque
>> >>>>> behavior.
>> > opaque
>> >>>>> behavior.
> the
>> >>>>> effect.
>> >>>>> - James.
>> >>>>>> Hi Mirco,
>> >>>>>> Interaction
>> >>>>> which
> whose
>> > Interaction.
>> >>>>>> transition fires"
>> >>>>>> Regards,
>> >>>>>> - James.
>> >>>>>>> Hi all,
>> > association
>> >>>>>>> state
> an
>> >>>>> Effect
> both
>> >>> effect?
>> >>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471637 is a reply to message #471634] |
Mon, 12 March 2007 19:08 |
Hi Mirco,
.... so I just confirmed that you should really be creating your statemachine
in the context of some class and creating interface realizations to that
context class....
- James
news:est4pl$3o0$1@utils.eclipse.org...
to
over
is
behavior
constraints
> "context".
> Regards,
> - James.
> > Hi Mirco,
> > interfaces
your
be
> > interested in.
interaction
> > and
enhancements
> > in
and
> > Cheers,
> > -James.
> >> Hi James,
and
two
interaction.
whether
> >> Regards,
> >> Mirco
> >> James Bruck wrote:
> >> > Hi Mirco,
describe,
> > you
> > doing
> > you
a
Try
> > Now
> > browse
way
> > that
opensource
added
> > to
> >> > other tabs.
> >> > there
> > is
> >> > Regards,
> >> > - James.
> >> >> Hi James,
> >> >> model
relationship
machines,
> > the
> > interface
> > between
> >> >> this possibility?
> >> >> Thank you again
> >> >> Regards,
> >> >> Mirco
> >> >> James Bruck wrote:
> >> >>> Hi Mirco,
> >> >>> indicating
> >> > that
> >> > diagrams
the
> >> >>> interact
> >> > ( ie
> >> > connector
> >> > selecting
> >> > disjoint.
> >> > connectors
> >> > Connectable
> >> > warning
your
> >> > model
> >> > typing
a
> >> > sequence
model.
> >> >>> Regards,
> >> >>> - James.
> >> >>>> Hi James,
have
> > an
my
> > following
> >> >>>> error:
> >> >>>> end
> > interaction
> > model
sample
> >> >>>> Cheers
> >> >>>> Mirco
> > opaque
> >> >>>>> behavior.
> >> > opaque
> >> >>>>> behavior.
> > the
> >> >>>>> effect.
> >> >>>>> - James.
> >> >>>>>> Hi Mirco,
> >> >>>>>> Interaction
> >> >>>>> which
> > whose
> >> > Interaction.
the
> >> >>>>>> transition fires"
> >> >>>>>> Regards,
> >> >>>>>> - James.
> >> >>>>>>> Hi all,
> >> > association
> >> >>>>>>> state
have
> > an
> >> >>>>> Effect
> > both
> >> >>> effect?
> >> >>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #471638 is a reply to message #471637] |
Tue, 13 March 2007 14:43 |
Hi James,
Thank you very much for your precious help.
To recap, my valid model now has classes owning state machines which
describe their dynamic behavior. In order to model interaction between
the classes, they use and realize some interfaces. This lets me draw
valid sequence diagrams as effects of state machines' transitions.
I am now investigating a component-centric approach using ports and
composite structure diagrams, which I think is more expressive in the
context of the domain I am interested in. I might get back to you with
questions regarding that!
Thank you again.
Cheers
Mirco
James Bruck wrote:
> Hi Mirco,
> context class....
> Regards,
> - James
> to
> over
> is
> behavior
> constraints
>> "context".
>> Regards,
>> - James.
>>> Hi Mirco,
>>> interfaces
> your
> be
>>> interested in.
> interaction
>>> and
> enhancements
>>> in
> and
>>> Cheers,
>>> -James.
>>>> Hi James,
> and
> two
> interaction.
> whether
>>>> Regards,
>>>> Mirco
>>>> James Bruck wrote:
>>>>> Hi Mirco,
> describe,
>>> you
>>> doing
>>> you
> a
> Try
>>> Now
>>> browse
> way
>>> that
> opensource
> added
>>> to
>>>>> other tabs.
>>>>> there
>>> is
>>>>> Regards,
>>>>> - James.
>>>>>> Hi James,
>>>>>> model
> relationship
> machines,
>>> the
>>> interface
>>> between
>>>>>> this possibility?
>>>>>> Thank you again
>>>>>> Regards,
>>>>>> Mirco
>>>>>> James Bruck wrote:
>>>>>>> Hi Mirco,
>>>>>>> indicating
>>>>> that
>>>>> diagrams
> the
>>>>>>> interact
>>>>> ( ie
>>>>> connector
>>>>> selecting
>>>>> disjoint.
>>>>> connectors
>>>>> Connectable
>>>>> warning
> your
>>>>> model
>>>>> typing
> a
>>>>> sequence
> model.
>>>>>>> Regards,
>>>>>>> - James.
>>>>>>>> Hi James,
> have
>>> an
> my
>>> following
>>>>>>>> error:
>>>>>>>> end
>>> interaction
>>> model
> sample
>>>>>>>> Cheers
>>>>>>>> Mirco
>>> opaque
>>>>>>>>> behavior.
>>>>> opaque
>>>>>>>>> behavior.
>>> the
>>>>>>>>> effect.
>>>>>>>>> - James.
>>>>>>>>>> Hi Mirco,
>>>>>>>>>> Interaction
>>>>>>>>> which
>>> whose
>>>>> Interaction.
> the
>>>>>>>>>> transition fires"
>>>>>>>>>> Regards,
>>>>>>>>>> - James.
>>>>>>>>>>> Hi all,
>>>>> association
>>>>>>>>>>> state
> have
>>> an
>>>>>>>>> Effect
>>> both
>>>>>>> effect?
>>>>>>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598375 is a reply to message #471624] |
Hi James,
error:
Cheers
Mirco
> behavior.
> behavior.
> effect.
> - James.
>> Hi Mirco,
> which
>> transition fires"
>> Regards,
>> - James.
>>> Hi all,
> Effect
>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598377 is a reply to message #471625] |
Hi Mirco,
- James.
> Hi James,
> error:
> Cheers
> Mirco
> > behavior.
> > behavior.
> > effect.
> > - James.
> >> Hi Mirco,
> > which
> >> transition fires"
> >> Regards,
> >> - James.
> >>> Hi all,
> > Effect
effect?
> >>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598409 is a reply to message #471626] |
Hi James,
this possibility?
Thank you again
Mirco
James Bruck wrote:
> Hi Mirco,
> Regards,
> - James.
>> Hi James,
>> error:
>> Cheers
>> Mirco
>>> behavior.
>>> behavior.
>>> effect.
>>> - James.
>>>> Hi Mirco,
>>> which
>>>> transition fires"
>>>> Regards,
>>>> - James.
>>>>> Hi all,
>>> Effect
> effect?
>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598416 is a reply to message #471630] |
Hi Mirco,
other tabs.
- James.
> Hi James,
> this possibility?
> Thank you again
> Regards,
> Mirco
> James Bruck wrote:
> > Hi Mirco,
that
diagrams
( ie
connector
selecting
disjoint.
connectors
Connectable
warning
model
typing
sequence
> > Regards,
> > - James.
> >> Hi James,
> >> error:
> >> Cheers
> >> Mirco
> >>> behavior.
opaque
> >>> behavior.
> >>> effect.
> >>> - James.
> >>>> Hi Mirco,
> >>> which
Interaction.
> >>>> transition fires"
> >>>> Regards,
> >>>> - James.
> >>>>> Hi all,
association
> >>> Effect
> > effect?
> >>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598424 is a reply to message #471631] |
Hi James,
Mirco
James Bruck wrote:
> Hi Mirco,
> other tabs.
> Regards,
> - James.
>> Hi James,
>> this possibility?
>> Thank you again
>> Regards,
>> Mirco
>> James Bruck wrote:
>>> Hi Mirco,
> that
> diagrams
> ( ie
> connector
> selecting
> disjoint.
> connectors
> Connectable
> warning
> model
> typing
> sequence
>>> Regards,
>>> - James.
>>>> Hi James,
>>>> error:
>>>> Cheers
>>>> Mirco
>>>>> behavior.
> opaque
>>>>> behavior.
>>>>> effect.
>>>>> - James.
>>>>>> Hi Mirco,
>>>>> which
> Interaction.
>>>>>> transition fires"
>>>>>> Regards,
>>>>>> - James.
>>>>>>> Hi all,
> association
>>>>> Effect
>>> effect?
>>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598429 is a reply to message #471632] |
Hi Mirco,
interested in.
-James.
> Hi James,
> Regards,
> Mirco
> James Bruck wrote:
> > Hi Mirco,
you
doing
you
Now
browse
that
to
> > other tabs.
is
> > Regards,
> > - James.
> >> Hi James,
the
interface
between
> >> this possibility?
> >> Thank you again
> >> Regards,
> >> Mirco
> >> James Bruck wrote:
> >>> Hi Mirco,
> > that
> > diagrams
> > ( ie
> > connector
> > selecting
> > disjoint.
> > connectors
> > Connectable
> > warning
> > model
> > typing
> > sequence
> >>> Regards,
> >>> - James.
> >>>> Hi James,
an
following
> >>>> error:
interaction
model
> >>>> Cheers
> >>>> Mirco
opaque
> >>>>> behavior.
> > opaque
> >>>>> behavior.
the
> >>>>> effect.
> >>>>> - James.
> >>>>>> Hi Mirco,
> >>>>> which
whose
> > Interaction.
> >>>>>> transition fires"
> >>>>>> Regards,
> >>>>>> - James.
> >>>>>>> Hi all,
> > association
an
> >>>>> Effect
both
> >>> effect?
> >>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598436 is a reply to message #471633] |
"context".
- James.
> Hi Mirco,
> interfaces
> interested in.
> and
> in
> Cheers,
> -James.
>> Hi James,
>> Regards,
>> Mirco
>> James Bruck wrote:
>> > Hi Mirco,
> you
> doing
> you
> Now
> browse
> that
> to
>> > other tabs.
>> > there
> is
>> > Regards,
>> > - James.
>> >> Hi James,
>> >> model
> the
> interface
> between
>> >> this possibility?
>> >> Thank you again
>> >> Regards,
>> >> Mirco
>> >> James Bruck wrote:
>> >>> Hi Mirco,
>> >>> indicating
>> > that
>> > diagrams
>> >>> interact
>> > ( ie
>> > connector
>> > selecting
>> > disjoint.
>> > connectors
>> > Connectable
>> > warning
>> > model
>> > typing
>> > sequence
>> >>> Regards,
>> >>> - James.
>> >>>> Hi James,
> an
> following
>> >>>> error:
>> >>>> end
> interaction
> model
>> >>>> Cheers
>> >>>> Mirco
> opaque
>> >>>>> behavior.
>> > opaque
>> >>>>> behavior.
> the
>> >>>>> effect.
>> >>>>> - James.
>> >>>>>> Hi Mirco,
>> >>>>>> Interaction
>> >>>>> which
> whose
>> > Interaction.
>> >>>>>> transition fires"
>> >>>>>> Regards,
>> >>>>>> - James.
>> >>>>>>> Hi all,
>> > association
>> >>>>>>> state
> an
>> >>>>> Effect
> both
>> >>> effect?
>> >>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598458 is a reply to message #471634] |
Hi Mirco,
context class....
- James
to
over
is
behavior
constraints
> "context".
> Regards,
> - James.
> > Hi Mirco,
> > interfaces
your
be
> > interested in.
interaction
> > and
enhancements
> > in
and
> > Cheers,
> > -James.
> >> Hi James,
and
two
interaction.
whether
> >> Regards,
> >> Mirco
> >> James Bruck wrote:
> >> > Hi Mirco,
describe,
> > you
> > doing
> > you
a
Try
> > Now
> > browse
way
> > that
opensource
added
> > to
> >> > other tabs.
> >> > there
> > is
> >> > Regards,
> >> > - James.
> >> >> Hi James,
> >> >> model
relationship
machines,
> > the
> > interface
> > between
> >> >> this possibility?
> >> >> Thank you again
> >> >> Regards,
> >> >> Mirco
> >> >> James Bruck wrote:
> >> >>> Hi Mirco,
> >> >>> indicating
> >> > that
> >> > diagrams
the
> >> >>> interact
> >> > ( ie
> >> > connector
> >> > selecting
> >> > disjoint.
> >> > connectors
> >> > Connectable
> >> > warning
your
> >> > model
> >> > typing
a
> >> > sequence
model.
> >> >>> Regards,
> >> >>> - James.
> >> >>>> Hi James,
have
> > an
my
> > following
> >> >>>> error:
> >> >>>> end
> > interaction
> > model
sample
> >> >>>> Cheers
> >> >>>> Mirco
> > opaque
> >> >>>>> behavior.
> >> > opaque
> >> >>>>> behavior.
> > the
> >> >>>>> effect.
> >> >>>>> - James.
> >> >>>>>> Hi Mirco,
> >> >>>>>> Interaction
> >> >>>>> which
> > whose
> >> > Interaction.
the
> >> >>>>>> transition fires"
> >> >>>>>> Regards,
> >> >>>>>> - James.
> >> >>>>>>> Hi all,
> >> > association
> >> >>>>>>> state
have
> > an
> >> >>>>> Effect
> > both
> >> >>> effect?
> >> >>>>>>> Mirco
Re: Transition Effects Calling Methods of Classes Visible to State Machine Owner [message #598468 is a reply to message #471637] |
Hi James,
Thank you again.
Cheers
Mirco
James Bruck wrote:
> Hi Mirco,
> context class....
> Regards,
> - James
> to
> over
> is
> behavior
> constraints
>> "context".
>> Regards,
>> - James.
>>> Hi Mirco,
>>> interfaces
> your
> be
>>> interested in.
> interaction
>>> and
> enhancements
>>> in
> and
>>> Cheers,
>>> -James.
>>>> Hi James,
> and
> two
> interaction.
> whether
>>>> Regards,
>>>> Mirco
>>>> James Bruck wrote:
>>>>> Hi Mirco,
> describe,
>>> you
>>> doing
>>> you
> a
> Try
>>> Now
>>> browse
> way
>>> that
> opensource
> added
>>> to
>>>>> other tabs.
>>>>> there
>>> is
>>>>> Regards,
>>>>> - James.
>>>>>> Hi James,
>>>>>> model
> relationship
> machines,
>>> the
>>> interface
>>> between
>>>>>> this possibility?
>>>>>> Thank you again
>>>>>> Regards,
>>>>>> Mirco
>>>>>> James Bruck wrote:
>>>>>>> Hi Mirco,
>>>>>>> indicating
>>>>> that
>>>>> diagrams
> the
>>>>>>> interact
>>>>> ( ie
>>>>> connector
>>>>> selecting
>>>>> disjoint.
>>>>> connectors
>>>>> Connectable
>>>>> warning
> your
>>>>> model
>>>>> typing
> a
>>>>> sequence
> model.
>>>>>>> Regards,
>>>>>>> - James.
>>>>>>>> Hi James,
> have
>>> an
> my
>>> following
>>>>>>>> error:
>>>>>>>> end
>>> interaction
>>> model
> sample
>>>>>>>> Cheers
>>>>>>>> Mirco
>>> opaque
>>>>>>>>> behavior.
>>>>> opaque
>>>>>>>>> behavior.
>>> the
>>>>>>>>> effect.
>>>>>>>>> - James.
>>>>>>>>>> Hi Mirco,
>>>>>>>>>> Interaction
>>>>>>>>> which
>>> whose
>>>>> Interaction.
> the
>>>>>>>>>> transition fires"
>>>>>>>>>> Regards,
>>>>>>>>>> - James.
>>>>>>>>>>> Hi all,
>>>>> association
>>>>>>>>>>> state
> have
>>> an
>>>>>>>>> Effect
>>> both
>>>>>>> effect?
>>>>>>>>>>> Mirco
Current Time: Fri Apr 26 06:02:28 GMT 2024
Powered by FUDForum. Page generated in 0.05154 seconds
