Re: [ATL] Developing a plugin which executes ATL transformations [message #48523 is a reply to message #48415] |
Mon, 25 June 2007 07:43 |
Originally posted by: quentin.glineur.obeo.fr
I think your problem comes from the way you launch the ant build :
Try to configure the launch as follow :
-right click the ant file: run as...
-under the refresh tab select refresh the entire workspace
-under the jre tab select "run in the same jre as the workspace"
Quentin
Bea a écrit :
> I think that the problem is that eclipse doesn't find the
> org.eclipse.gmt.am3.tools.ant_1.0.0.20070619.jar. I have tried with right
> click on the build.xml and selecting the second Ant run. In the classpath
> section I have added that .jar but it doesn't work.
> "Bea" <beaperez@unizar.es> escribió en el mensaje
> news:f5g94g$qv7$1@build.eclipse.org...
>> Hello again
>> I have problems with am3.loadmodel sentence. I get the error "Ant could
>> not find the task or a class this task relies upon.".
>> In my build.xml file I have:
>> <am3.loadModel modelHandler="EMF" name="UML2" metamodel="MOF"
>> path="uri:http://www.eclipse.org/uml2/1.0.0/UML"/>
>> I have the plugin org.eclipse.gmt.am3.tools.ant installed but I thinnk
>> that it doesn't work Any idea?
>> Thank you.
>> "urs zeidler" <ich@urszeidler.de> escribió en el mensaje
>> news:f5eb34$3jo$1@build.eclipse.org...
>>> Bea schrieb:
>>>> I use MOFScript for model to text transformations and ATL for model to
>>>> model transformations. So I would like to create a plugin which execute
>>>> the defined transformations in the order I want.
>>>> Do you know how I can invoke an ANT script?
>>>> Thanks
>>> You can start ANT like an other process :
>>> Process process = Runtime.getRuntime().exec(cmd);
>>> or with the launcher :
>>> org.apache.tools.ant.launch.Launcher
>>> see ANT manual
>>> http://ant.apache.org/manual/index.html
>>> greetings, urs.
Re: [ATL] Developing a plugin which executes ATL transformations [message #48611 is a reply to message #48551] |
Mon, 25 June 2007 08:26 |
Then, I am not sure but you may try to use this form for the am3.loadModel :
<am3.loadModel name="UML2" metamodel="MOF"
nsUri="http://www.eclipse.org/uml2/1.0.0/UML" />
This is the way I load model registered by an uri.
Bea a écrit :
> thank you for your help, but I have already tried it, but it doesn't work. I
> don't know what to do then, any idea?
> "Quentin Glineur" <quentin.glineur@obeo.fr> escribió en el mensaje
> news:f5nrmf$gp2$1@build.eclipse.org...
>> Regards,
>> Quentin
>>> right click on the build.xml and selecting the second Ant run. In the
>>> classpath section I have added that .jar but it doesn't work.
>>>> Hello again
>>>> Thank you.
>>>>>> execute the defined transformations in the order I want.
>>>>>> Thanks
>>>>> see ANT manual
>>>>> greetings, urs.
Re: [ATL] Developing a plugin which executes ATL transformations [message #48758 is a reply to message #48731] |
Mon, 25 June 2007 10:31 |
Currently, I am using:
- Eclipse Version: 3.2.2,
- ATL 1.0.7
- AM3 1.0.0
- and UML2 2.0.3
from http://www.eclipse.org/m2m/atl/download/.
But considering your problem, I don't think this will help you as the
version I use is pretty similar to the bundle.
You can find the ATLBundle-20060501 at
http://www.sciences.univ-nantes.fr/lina/atl/www/atldemo/ATLB undle-20060501.zip
Quentin
Bea a écrit :
> I have seen in the web that some people use ATLBundle-20060501 but I can't
> find it. Doues anybody know where I can find it?
> news:f5nvt1$qs2$1@build.eclipse.org...
>> thank you again but it doesn't work yet. I think that the problem is the
>> plugin. I have tried with the pack
>> http://www.sciences.univ-nantes.fr/lina/atl/www/atldemo/ATLB undle_20070217.zip
>> and with this version, the metamodel is loaded (then, the am3.loadmodel
>> works) but I can't use it because all my models are created using UML2
>> 1.0.0 and this pack is for Eclipse 3.2 and UML2 2.0.0. Could you tell me
>> what version of ATL and AM3 do you use, and where can I find it?
>> Thank you again in advance
>> Bea
>> news:f5nu74$n1i$1@build.eclipse.org...
>>> am3.loadModel :
>>> Bea a écrit :
>>>> Hi,
>>>> work. I don't know what to do then, any idea?
>>>>> Hi,
>>>>> Regards,
>>>>> Quentin
>>>>>>> Hello again
>>>>>>> could not find the task or a class this task relies upon.".
>>>>>>> thinnk that it doesn't work Any idea?
>>>>>>> Thank you.
>>>>>>>>> to model transformations. So I would like to create a plugin which
>>>>>>>>> Thanks
>>>>>>>> see ANT manual
>>>>>>>> greetings, urs.
Re: [ATL] Developing a plugin which executes ATL transformations [message #48815 is a reply to message #48786] |
Mon, 25 June 2007 10:57 |
Bea a écrit :
> Thank you, that works!!!
Great !
Although I have other problems, it works.
Can you please tell what you have changed to make it work ?
Quentin
All
> models are loaded but when the transformation is running I get the error:
> [am3.atl] Executing ATL transformation
> /Plugin/ATLFiles/First/transformation.asm
> [am3.atl] ****** BEGIN Stack Trace
> [am3.atl] message: ERROR: OclUndefined has no property
> news:f5o5h7$i4b$1@build.eclipse.org...
>> - ATL 1.0.7
>> - AM3 1.0.0
>> - and UML2 2.0.3
>> Quentin
>>> can't find it. Doues anybody know where I can find it?
>>>> Hi,
>>>> Bea
>>>>> am3.loadModel :
>>>>> Bea a écrit :
>>>>>> Hi,
>>>>>>> Hi,
>>>>>>> Regards,
>>>>>>> Quentin
>>>>>>>> the classpath section I have added that .jar but it doesn't work.
>>>>>>>>> Hello again
>>>>>>>>> Thank you.
>>>>>>>>>>> model to model transformations. So I would like to create a
>>>>>>>>>>> plugin which execute the defined transformations in the order I
>>>>>>>>>>> want.
>>>>>>>>>>> Thanks
>>>>>>>>>> see ANT manual
>>>>>>>>>> greetings, urs.
FUDForum. Page generated in 0.05166 seconds
