Home » Eclipse Projects » JavaServer Faces » WTP JSF with MyFaces
Re: WTP JSF with MyFaces [message #471467 is a reply to message #470903] |
Wed, 08 February 2006 18:47 |
Gerry Kessler Messages: 125 Registered: July 2009 |
Hi Chris,
A problem at runtime is nearly always a classpath problem of some kind.
With that said, you may want to post this question on a MyFaces newsgroup.
What jars have you included in your JSF Implementation Libary? Does
someone else montitoring this list have any suggestions?
Gerry Kessler
WTP JSF Tools team
"Chris Gage" <a@b.com> wrote in message
news:dsd563$9kt$1@utils.eclipse.org...
>I have been using JSF with WSAD and RAD6 for 18 months so I know my way
>around reasonably well, but I have clearly become accustomed to the comfy
>chair that RAD puts you in. I am now having a rather basic problem getting
>it to work on WTP.
> I installed all the WTP pieces from scratch and WTP itself appears to be
> working as designed. I then added the JSF support but chose to use
> MyFaces instead of Sun RI, seeing as everyone says it is a better
> implementation.
> I have a simple app that has one page with an input "name" field and a
> button, and the navigation passes to another page which says "hello
> name" - it is a tutorial out there on the Web I found. The backing bean
> is correctly defined in faces-config.xml as far as I can see. I run the
> initial page, and it displays, but when I type in a name and press the
> button, expecting it to invoke the backing bean called PersonBean, instead
> I get the following which I think means it cannot find my backing bean.
> HTTP Status 500 -
> type Exception report
> description The server encountered an internal error () that prevented it
> from fulfilling this request.
> exception javax.servlet.ServletException: Base is null: PersonBean
> javax.faces.webapp.FacesServlet.service(FacesServlet.java:20 2)
> root cause
> javax.faces.el.PropertyNotFoundException: Base is null: PersonBean
> org.apache.myfaces.el.ValueBindingImpl.resolveToBaseAndPrope rty(ValueBindingImpl.java:455)
> org.apache.myfaces.el.ValueBindingImpl.getType(ValueBindingI mpl.java:169)
> com.sun.faces.renderkit.html_basic.HtmlBasicInputRenderer.ge tConvertedValue(HtmlBasicInputRenderer.java:111)
> javax.faces.component.UIInput.getConvertedValue(UIInput.java :713)
> javax.faces.component.UIInput.validate(UIInput.java:638)
> javax.faces.component.UIInput.executeValidate(UIInput.java:8 49)
> javax.faces.component.UIInput.processValidators(UIInput.java :412)
> javax.faces.component.UIForm.processValidators(UIForm.java:1 70)
> javax.faces.component.UIComponentBase.processValidators(UICo mponentBase.java:912)
> javax.faces.component.UIViewRoot.processValidators(UIViewRoo t.java:342)
> org.apache.myfaces.lifecycle.LifecycleImpl.processValidation s(LifecycleImpl.java:240)
> org.apache.myfaces.lifecycle.LifecycleImpl.execute(Lifecycle Impl.java:76)
> javax.faces.webapp.FacesServlet.service(FacesServlet.java:19 7)note The
> full stack trace of the root cause is available in the ApacheTomcat/5.0.30
> logs.Apache Tomcat/5.0.30
Re: WTP JSF with MyFaces [message #471468 is a reply to message #471467] |
Wed, 08 February 2006 19:01 |
Yury Kats Messages: 104 Registered: July 2009 |
Yes, this sounds like a generic JSF issue, unrelated to WTP/JSF project.
Something like that should be asked on MyFaces user list (since MyFaces
is used) or on a generic JSF forum (like SUN's or RAD's).
Having said that, one would need to see the JSP and faces-config.xml
to be able to tell anything about what might've gone wrong. The exception
suggests that the managed bean wasn't created.
On 2/8/2006 1:47 PM, Gerry Kessler wrote:
> Hi Chris,
> Regards,
> Gerry Kessler
> WTP JSF Tools team
>> it to work on WTP.
>> implementation.
>> HTTP Status 500 -
>> root cause
Re: WTP JSF with MyFaces [message #471488 is a reply to message #470903] |
Fri, 17 February 2006 10:47 |
Werner Punz Messages: 52 Registered: July 2009 |
Member |
> it to work on WTP.
> working as designed. I then added the JSF support but chose to use MyFaces
> instead of Sun RI, seeing as everyone says it is a better implementation.
> button, and the navigation passes to another page which says "hello name" -
> it is a tutorial out there on the Web I found. The backing bean is
> button, expecting it to invoke the backing bean called PersonBean, instead I
> HTTP Status 500 -
> root cause
> org.apache.myfaces.el.ValueBindingImpl.resolveToBaseAndPrope rty(ValueBindingImpl.java:455) org.apache.myfaces.el.ValueBindingImpl.getType(ValueBindingI mpl.java:169) com.sun.faces.renderkit.html_basic.HtmlBasicInputRenderer.ge tConvertedValue(HtmlBasicInputRenderer.java:111) javax.faces.component.UIInput.getConvertedValue(UIInput.java :713) javax.faces.component.UIInput.validate(UIInput.java:638) javax.faces.component.UIInput.executeValidate(UIInput.java:8 49) javax.faces.component.UIInput.processValidators(UIInput.java :412) javax.faces.component.UIForm.processValidators(UIForm.java:1 70) javax.faces.component.UIComponentBase.processValidators(UICo mponentBase.java:912) javax.faces.component.UIViewRoot.processValidators(UIViewRoo t.java:342) org.apache.myfaces.lifecycle.LifecycleImpl.processValidation s(LifecycleImpl.java:240) org.apache.myfaces.lifecycle.LifecycleImpl.execute(Lifecycle Impl.java:76) javax.faces.webapp.FacesServlet.service(FacesServlet.java:19 7)note The full stack
trace of the root cause is available in the ApacheTomcat/5.0.30 logs.Apache Tomcat/5.0.30
Just a wild guess here, first of all which jsf version are you using?
Secondly di you have any tangeling classpath references into the RI?
or any sun related or third party jsf lib (which has explicit hooks into
the sun class hierarchy instead of javax.jsf...
the line:
does definitely not look like myfaces, myfaces cannot have and does not
have to my knowledge any referenes into com.sun.xx..
(It is not allowed to)
Re: WTP JSF with MyFaces [message #589314 is a reply to message #470903] |
Hi Chris,
Gerry Kessler
WTP JSF Tools team
>it to work on WTP.
> implementation.
> HTTP Status 500 -
> root cause
Re: WTP JSF with MyFaces [message #589325 is a reply to message #471467] |
> Hi Chris,
> Regards,
> Gerry Kessler
> WTP JSF Tools team
>> it to work on WTP.
>> implementation.
>> HTTP Status 500 -
>> root cause
Re: WTP JSF with MyFaces [message #596531 is a reply to message #470903] |
Member |
> it to work on WTP.
> HTTP Status 500 -
> root cause
the line:
Current Time: Thu Sep 19 05:34:54 GMT 2024
Powered by FUDForum. Page generated in 0.05423 seconds
