Re: Best Way to Import Existing UML model into Papyrus [message #557105 is a reply to message #470458] |
Sat, 04 September 2010 12:10 |
Yannick Duchene (Hibou57) Messages: 50 Registered: September 2010 Location: Metz (France - Europe) |
Member |
Sebastien Gerard wrote on Wed, 05 August 2009 03:01 | Hi,
there is another mean to do that: select the uml file, right click on it and
create with this context a new Papyrus model. The current model will be the
base for your new project.
S
I have just tried this as I had the same question as the OP. This technique does not work well. It creates no view at all.
You may add a view manually, but then, it is empty, and it is not that easy : you have to peek element from the model explorer, then move it to the view. However, this oftenly goes wrong, and sometime, some stuff cannot be added in the view this way, like comment links and some others;
I guess this would not be easy to create something which would create a layout automatically. But this could be easier and still nice to have something which would do the bare minimum, that, add all element from the model to a view. The user will then have to adjust element position and the like.
Re: Best Way to Import Existing UML model into Papyrus [message #606947 is a reply to message #470458] |
Member |
> Regards,
> S
Re: Best Way to Import Existing UML model into Papyrus [message #991557 is a reply to message #607420] |
Wed, 19 December 2012 18:19 |
has someone solved that? I dont see the menu entry nither
Also, it is working for me if I try to create a class diagram, but now I am trying to load an interaction diagram (sequence diagram) and Papyrus doesnt let me drag and drop the items from the model explorer to the diagram editor pane ... Is it supposed to be working, or is it an unimplemented feature?
thank you in advance!
FUDForum. Page generated in 0.04481 seconds
