Home » Archived » AMW » Programmatically launching a composition: java.lang.reflect.InvocationTargetException
Programmatically launching a composition: java.lang.reflect.InvocationTargetException [message #470301] Sat, 27 June 2009 18:47 Go to next message
--------------050706060507030606020403
Content-Type: multipart/alternative;
boundary="------------000103090702000907050506"
--------------000103090702000907050506
Hi everybody,
I'm trying to launch a composition programmatically,
but can't get it right.
The composition works fine with the same models in a launch configuration.
I use the same metamodels (I register them in a plugin, and use them as
"uri:..") both in the launch configuration and the java transf.
I only don't register weaving metamodel , I use it locally for the
launch, and an exact copy of it in the plugin (I'm telling just in case
this affects somehow).
I also use a piece of code that works fine with ATL transformations
(based on
http://wiki.eclipse.org/JWT_Transformations#How_to_call_an_A TL_transformation_in_java_.28e.g._in_a_transformation_plugin .29
), but a little tweaked for loading the AMW models.
Some excerpts of my code follow.
To get the handlers, I write:
emfModelHandler = (AtlEMFModelHandler)
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
amwModelHandler = new AmwModelHandler(); // --> I DIDN'T FIND A STATIC
METHOD TO GET THE HANDLER!!.
I load the weaving metamodel (I use to load the metamodel as
ASMEMFModel, but it wasn't working, so I tried it this way) and the
weaving model as ASMAMWModels:
ASMAMWModel weavingModel = (ASMAMWModel) amwModelHandler.loadModel(
"SOMENAME", amwModelHandler.getMof(), "SOMEPATH"); //
---> SHOULD IT BE getAtl() ?? Doesn't work either
The rest of the (meta)models, as ASMEMFModels:
(ASMEMFModel) emfModelHandler.loadModel(...
and then launch as:
AtlLauncher.getDefault().launch(this.transfoResource,
Collections.EMPTY_MAP, models,
Collections.EMPTY_LIST, Collections.EMPTY_MAP);
Regretfully, when running this code, I get the attached exception (after
some tranformation's "print-to-screen debugging" comments).
Any ideas on the probable cause?, I guess I'm doing something wrong with
the handlers and/or the loading, but can't find any example code to base
mine on.
Thanks in advance and best regards,
Juan Pedro
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Hi everybody, <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; I'm trying to launch a composition
programmatically, but can't get it right.<br>
configuration.<br>
"uri:..") both in the launch configuration and the java transf.<br>
this affects somehow).<br>
(based on <br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/JWT_Transformations#How_to_call_an_A TL_transformation_in_java_.28e.g._in_a_transformation_plugin .29"> http://wiki.eclipse.org/JWT_Transformations#How_to_call_an_A TL_transformation_in_java_.28e.g._in_a_transformation_plugin .29</a><br>
), but a little tweaked for loading the AMW models.<br>
<br>
Some excerpts of my code follow.<br>
To get the handlers, I write:<br>
<font face="Courier New, Courier, monospace"><br>
<font color="#009900">emfModelHandler = (AtlEMFModelHandler)
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);&nbs p;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
&nbsp;&nbsp; <br>
amwModelHandler = new AmwModelHandler(); // --&gt; I DIDN'T FIND A
STATIC METHOD TO GET THE HANDLER!!.</font></font><font color="#009900"><br>
</font><br>
weaving model as ASMAMWModels:<br>
<br>
<font color="#009900" face="Courier New, Courier, monospace">ASMAMWModel
weavingModel = (ASMAMWModel) amwModelHandler.loadModel(<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; "SOMENAME", amwModelHandler.getMof(), "SOMEPATH");&nbsp;&nbsp; //
---&gt; SHOULD IT BE getAtl() ?? Doesn't work either<br>
</font><br>
The rest of the (meta)models, as ASMEMFModels: <br>
<br>
<font color="#009900" face="Courier New, Courier, monospace">(ASMEMFModel)
emfModelHandler.loadModel(...<br>
</font><br>
and then launch as:<br>
<br>
<font color="#009900">AtlLauncher.getDefault().launch(this.transfoResource, <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Collections.EMPTY_MAP, models,
Collections.EMPTY_MAP,<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Collections.EMPTY_LIST, Collections.EMPTY_MAP);<br>
<br>
<font color="#000000">Regretfully, when running this code, I get the
attached exception </font></font><font color="#009900"><font
color="#000000">(after some tranformation's "print-to-screen
debugging" comments).</font></font><br>
<font color="#009900"><font color="#000000">Any ideas on the probable
cause?, I guess I'm doing something wrong with the handlers and/or the
loading, but can't find any example code to base mine on.<br>
Thanks in advance and best regards,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; Juan Pedro<br>
<br>
</font></font><br>
</body>
</html>
--------------000103090702000907050506--
name="ProgrammAMWException.txt"
Content-Disposition: inline;
filename="ProgrammAMWException.txt"
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: null
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:69)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:683)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at itecban.stras.sips.utils.AMWTransformationLauncher.iBuilderC ompSecureUML(AMWTransformationLauncher.java:205)
at itecban.stras.cheatsheets.sips.handlers.UML2iBuilderCommandH andler.execute(UML2iBuilderCommandHandler.java:53)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:619)
at org.eclipse.ui.menus.CommandContributionItem.access$10(Comma ndContributionItem.java:605)
at org.eclipse.ui.menus.CommandContributionItem$4.handleEvent(C ommandContributionItem.java:595)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getWovenAS MModel(ASMAMWModelElement.java:117)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getReferre dElement(ASMAMWModelElement.java:192)
... 57 more
GRAVE: A.main() : ??#66 null
GRAVE: local variables = {self=weaving_tranfo_iBSecUML : ASMModule}
GRAVE: local stack = []
GRAVE: A.__matcher__() : ??#1 null
GRAVE: A.__matchnewAction() : ??#8 24:22-24:47
GRAVE: local variables = {attr=IN!FinancialDataDelete, self=weaving_tranfo_iBSecUML : ASMModule}
GRAVE: NativeOperation public static org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getReferre dElement(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclips e.m2m.atl.drivers.emf4atl.ASMEMFModelElement)
GRAVE: args = [IN!FinancialDataDelete]
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow continuation after errors).
GRAVE: null
java.lang.RuntimeException
at org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:87)
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:77)
Caused by: java.lang.reflect.InvocationTargetException
... 52 more
... 57 more
at itecban.stras.sips.utils.AMWTransformationLauncher.dispose(A MWTransformationLauncher.java:221)
at itecban.stras.sips.utils.AMWTransformationLauncher.iBuilderC ompSecureUML(AMWTransformationLauncher.java:211)
--------------050706060507030606020403--
Re: Programmatically launching a composition: java.lang.reflect.InvocationTargetException [message #470302 is a reply to message #470301] Sun, 28 June 2009 14:04 Go to previous messageGo to next message
--------------010607010603070704010503
*Update: *Launching it programmatically using the launch configuration
(by means of the DebugUITools.launch(..) method) also works fine.
I still believe I might be messing it up with the handlers
or something.
Juan Pedro Silva escribi
Re: Programmatically launching a composition: java.lang.reflect.InvocationTargetException [message #470305 is a reply to message #470301] Wed, 01 July 2009 16:32 Go to previous messageGo to next message
It is probably that the handler is not been registered correctly, so it
cannot find methods such as "getReferredElement", which are part of the
AMWModelHandler. If you do not call handler-specific methods, you may even
use only the standard EMFModelHandler.
You should get the handle this way:
AtlModelHandler modelHandler =
AtlModelHandler.getDefault(TransformationConstant.AMWModelHa ndler);
Check the code of package org.eclipse.gmt.weaver.transformation.util. It
has an example of transformations that are launched programmatically and
that have weaving models as input and as output.
http://dev.eclipse.org/viewsvn/index.cgi/plugins/trunk/org.e clipse.gmt.weaver.transformation/src/org/eclipse/gmt/weaver/ transformation/util/TransformationUtil.java?revision=12& root=Modeling_AMW&view=markup
Marcos.
Re: Programmatically launching a composition: java.lang.reflect.InvocationTargetException [message #470309 is a reply to message #470305] Fri, 03 July 2009 11:35 Go to previous messageGo to next message
Thanks Marcos.
I won't be able to try just yet, because I may need to recompile my AMW
(my current version doesn't export the "transformation" package,
although I'm trying with just replacing the manifest file).
I was going to try to compile it for Galileo, but once again I face the
problem of the TCS dependency, and as ATL version changes quite a lot,
this time is not enough with the binary version you provided last time.
Juan Pedro
Marcos Didonet Del Fabro escribió:
> Hello,
> it cannot find methods such as "getReferredElement", which are part of
> the AMWModelHandler. If you do not call handler-specific methods, you
> may even use only the standard EMFModelHandler.
> It has an example of transformations that are launched
> programmatically and that have weaving models as input and as output.
> Regards,
> Marcos.
Re: Programmatically launching a composition: java.lang.reflect.InvocationTargetException [message #470311 is a reply to message #470309] Mon, 06 July 2009 05:40 Go to previous message
actually, the link I sent is just an example of how we launched ATL
transformations that use the AMW model handler. You may use as a starting
point to implement your code.
Marcos.
Previous Topic:[AMW] weaving "n" metamodels and ATL transformation
Next Topic:ATLLauncher
Current Time: Fri May 23 20:50:05 EDT 2025
Powered by FUDForum. Page generated in 0.04184 seconds
