Home » Modeling » Papyrus » add interaction operands to a combined fragment
add interaction operands to a combined fragment [message #470252] Fri, 19 June 2009 09:24 Go to next message
hi,
I don't succeed in adding an interaction operand to a combined fragment
(type parallele or alternative for exemple) with papyrus. I saw the button
Interaction operand in the sequence diagram but when I use it I can't
click on a combined fragment.
Could you help me,
thanks
Aurélie
Re: add interaction operands to a combined fragment [message #470253 is a reply to message #470252] Fri, 19 June 2009 11:01 Go to previous messageGo to next message
guenin a écrit :
> hi,
> button Interaction operand in the sequence diagram but when I use it I
> can't click on a combined fragment.
> Could you help me,
> thanks
> Aurélie
Hi Aurélie,
I suppose you are talking about Papyrus v1(http://www.papyrusuml.org)
I suggest you to post your question at this address : papyrus@cea.fr
MDT-Papyrus is a new editor for UML regrouping the team of several UML
editors (Papyrus, Topcased, Moskitt...)
Currently, with MDT-Papyrus, you can't add interaction operand, but it
will be available in few months.
Thibault
Re: add interaction operands to a combined fragment [message #554124 is a reply to message #470252] Fri, 20 August 2010 05:10 Go to previous messageGo to next message
Wrong forum for my question,
sorry
[Updated on: Fri, 20 August 2010 05:35] by Moderator
Re: add interaction operands to a combined fragment [message #554243 is a reply to message #554124] Fri, 20 August 2010 13:29 Go to previous messageGo to next message
Hi Souleymane,
you should probably put this message on SWTBot forum ;-)
regards
raphaël
Le 20/08/2010 11:10, Souleymane a écrit :
> Hello!
> I am using swtbot on papyrus for tests automation,I have got a problem.
> I can't put a combined Fragment on the diagram using swtbot.
> When I try,he just appear on the diagram a menu with "Create
> CombienedFragment" item.
> Thanks
Re: add interaction operands to a combined fragment [message #586405 is a reply to message #470252] Fri, 19 June 2009 11:01 Go to previous messageGo to next message
guenin a écrit :
> hi,
> Could you help me,
> thanks
> Aurélie
Hi Aurélie,
Thibault
Re: add interaction operands to a combined fragment [message #606030 is a reply to message #470252] Fri, 20 August 2010 05:10 Go to previous messageGo to next message
Hello!
When I try,he just appear on the diagram a menu with "Create CombienedFragment" item.
Re: add interaction operands to a combined fragment [message #606032 is a reply to message #554124] Fri, 20 August 2010 13:29 Go to previous messageGo to next message
Hi Souleymane,
regards
raphaël
> Hello!
> Thanks
Re: add interaction operands to a combined fragment [message #1732414 is a reply to message #470252] Tue, 17 May 2016 02:54 Go to previous message
You should select the Interaction Operand and drag and drop it to the corner of Combined Fragment where is written alt\opt\seq. Then the Interaction Operand will be generated.
Previous Topic:How to organize a new Papyrus model?
Next Topic:Change color of UML element
Current Time: Sat Nov 08 23:18:28 EST 2025
Powered by FUDForum. Page generated in 0.03993 seconds
