Home » Archived » AMW » New user
New user [message #470177] Wed, 10 June 2009 03:24 Go to next message
Hi ,
I'm new AMW.I have 2 Models .
LDM.ecore(metamodel) PDM.ecore(MetaModel)
LDM Model.xmi PDMModel.xmi
i saw so many examples available.(AMW2ATL,Mantis2Bugzilla..)
I have to match all the Epackage 2 Epackage
Eclass 2 Eclass
EAttributes2 EAttributes
Ereference 2 Ereference
Enum 2 Enum
what all are the KM3 files i need to select to create a waeving model.
thanks in Advance,
venkatesh
Re: New user [message #470179 is a reply to message #470177] Wed, 10 June 2009 15:15 Go to previous messageGo to next message
if you want to use the matching transformations available in the
"transformation.extension" plugin, you need the following KM3 extensions:
mw_base_extension.km3, mmw_match.km3, mmw_compare.km3, mmw_propagation.km3
(optional).
There is a "how to" in the metamodel comparison use case.
http://www.eclipse.org/gmt/amw/examples/Scade/Scade_doc.php
Marcos.
Re: New user [message #470184 is a reply to message #470179] Mon, 15 June 2009 01:38 Go to previous messageGo to next message
Hi Marcos,
My Metamodel structure will look like this
MM1 MM2
Eclass A Eclass A'
Ereference x Ereference x'
Ereference y Ereference y '
what i have done in amw is
Eclass A MatchModel Eclass A'
|__Eref x <ownedElement>ELementEqual A2A' |__ Eref x'
|___Erefy |____<child>ReferenceEqual |__ Eref y'
| <left>Element x
| <right>Element x'
|____ <child>ReferenceEqual
| <left>Element y
| <right>Element y'
|____<left> Element A
|____<Right>Elemnet A'
after doing this i clicked on Hot transformation.It has genenerated the
LDM2PDM_hot.ecore file but i'm not able to open this file.I registered
Atl.ecore file also.
From LDM2PDM_hot.ecore file i clicked on "Extract ATL 0.2 Model to ATL 0.2
file" .it has created "LDM2PDM_hot.atl" file
LDM2PDM_hot.atl file has the following content.
-- @atlcompiler atl2006
module T_In2Out;
create
Thanks in Advance
venky
Re: New user [message #470185 is a reply to message #470184] Tue, 16 June 2009 03:57 Go to previous messageGo to next message
The transformation failed in its first steps, i.e., in the moment it was
setting up the input and output models (after the "create" keyword).
Which are the settings that you have used for creating the weaving model?
for instance, left and right metamodels, as well as the "WElementRefs" ?
Marcos.
Re: New user [message #470186 is a reply to message #470185] Wed, 17 June 2009 01:05 Go to previous messageGo to next message
Hi Marcos,
My LDM2PDM.amw.prop file look like this
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<weaver>
<weaving>
<relative-path>/LDM2PDMtransformation/LDM2PDM.amw</relative-path >
<panel>TransformationWeavingPanelExtension</panel>
<wmodel>MatchModel</wmodel>
</weaving>
<metamodels>
<plugin>
<relative-path> org.eclipse.gmt.weaver.matchextensions/metamodels/mmw_match. km3 </relative-path>
<relative-path> org.eclipse.gmt.weaver.matchextensions/metamodels/mmw_propag ation.km3 </relative-path>
<relative-path> org.eclipse.gmt.weaver.matchextensions/metamodels/mmw_compar e.km3 </relative-path>
<relative-path> org.eclipse.weaver.extension.base/metamodels/mw_base_extensi on.km3 </relative-path>
</plugin>
<local/>
<complete/>
</metamodels>
<woven id="0">
<model-relative-path>null</model-relative-path>
<metamodel-relative-path>/LDMMetamodel/model/LdmMetaModel.ecore </metamodel-relative-path>
<reference>leftM</reference>
<title>leftM</title>
<panel>XMIWovenPanelExtension</panel>
<wmodelref>ModelRefXMI</wmodelref>
</woven>
<woven id="1">
<metamodel-relative-path>/PDMMetamodel/model/PdmModel.ecore </metamodel-relative-path>
<reference>rightM</reference>
<title>rightM</title>
</woven>
</weaver>
Thanks in Advance,
venkatesh
Re: New user [message #470188 is a reply to message #470186] Wed, 17 June 2009 13:53 Go to previous messageGo to next message
Your settings are correct.
Do you have any error message, or some entry on the error log? If
everything is alright, a couple of lines with the XMI of your models could
help to discover the issue.
Marcos.
Re: New user [message #470189 is a reply to message #470188] Thu, 18 June 2009 01:24 Go to previous messageGo to next message
Hi Marcos,
when i click on "Generate transformation(Hot)" i am getting the following
error
SEVERE: ****** BEGIN Stack Trace
SEVERE: exception:
SEVERE: The 'no null' constraint is violated
java.lang.IllegalArgumentException: The 'no null' constraint is violated
at org.eclipse.emf.common.util.BasicEList.validate(BasicEList.j ava:175)
at org.eclipse.emf.ecore.util.EcoreEList.validate(EcoreEList.ja va:63)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:645)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:331)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:315)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 26)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.set(A SMEMFModelElement.java:254)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:292)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:325)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:155)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
org.eclipse.gmt.weaver.transformation.util.TransformationUti l.executeTransfo(TransformationUtil.java:103)
org.eclipse.gmt.weaver.transformation.panel.TransformationWe avingPanel$TAction.run(TransformationWeavingPanel.java:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
SEVERE: A.main() : ??#215 null
SEVERE: local variables = {null=right!PdmModel, self=AMWtoATL_Match :
ASMModule}
SEVERE: local stack = []
SEVERE: A.__exec__() : ??#8 null
SEVERE: local variables = {e=TransientLink {rule = 'Module',
sourceElements = {amw = IN!<notnamedyet>}, targetElements = {atl =
OUT!T_In2Out}, variables = {}}, self=AMWtoATL_Match : ASMModule}
SEVERE: A.__applyModule(1 : NTransientLink;) : ??#25 52:25-52:46
SEVERE: local variables = {atl=OUT!T_In2Out, amw=IN!<notnamedyet>,
link=TransientLink {rule = 'Module', sourceElements = {amw =
IN!<notnamedyet>}, targetElements = {atl = OUT!T_In2Out}, variables = {}},
SEVERE: local stack = [OUT!T_In2Out]
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
SEVERE: null
java.lang.RuntimeException
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:77)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:163)
Caused by: java.lang.IllegalArgumentException: The 'no null' constraint is
violated
... 43 more
venkatesh
Re: New user [message #470191 is a reply to message #470189] Thu, 18 June 2009 15:26 Go to previous messageGo to next message
hi,
There is a reference with 1+ cardinality that is set up to "null".
Do you create links between EEnum and EPackages? These elements are not
supported by the transformation, only EClass, EReference and EAttributes.
Can you paste a part of your weaving model (in XMI)?
Marcos.
Re: New user [message #470192 is a reply to message #470191] Fri, 19 June 2009 01:40 Go to previous messageGo to next message
Hi Marcos,
This is my amw file in XMI format.I have nearly 50 Eclassess in LDM.ecore
and PDM.ecore but in weaving model i have compared only few & generated
hot transformation to test it .
<?xml version="1.0" encoding="ASCII"?>
<MatchModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="mmw_match"
xmlns:_1="mw_base_ext" xmi:id="MatchModel1">
<ownedElement xsi:type="ElementEqual" xmi:id="ElementEqual1"
name="LDMModel2PDMModel">
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual1">
<left xsi:type="Element" xmi:id="Element1" name="applicationModels"
element="ElementRefXMI1"/>
<right xsi:type="Element" xmi:id="Element2" name="applicationModels"
element="ElementRefXMI2"/>
</child>
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual2">
<left xsi:type="Element" xmi:id="Element3" name="coreModel"
element="ElementRefXMI3"/>
<right xsi:type="Element" xmi:id="Element4" name="coreModel"
element="ElementRefXMI4"/>
</child>
<child xsi:type="ElementEqual" xmi:id="ElementEqual8"/>
<left xsi:type="Element" xmi:id="Element5" name="LDMModel"
element="ElementRefXMI5"/>
<right xsi:type="Element" xmi:id="Element6" name="PDMModel"
element="ElementRefXMI6"/>
</ownedElement>
<ownedElement xsi:type="ElementEqual" xmi:id="ElementEqual2"
name="LDMApplicationModel_PDMApplicationModel">
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual3">
<left xsi:type="Element" xmi:id="Element7" name="application"
element="ElementRefXMI7"/>
<right xsi:type="Element" xmi:id="Element8" name="application"
element="ElementRefXMI8"/>
</child>
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual4">
<left xsi:type="Element" xmi:id="Element9" name="serviceArea"
element="ElementRefXMI9"/>
<right xsi:type="Element" xmi:id="Element10" name="serviceArea"
element="ElementRefXMI10"/>
</child>
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual5">
<left xsi:type="Element" xmi:id="Element11"
name="serviceAreaCounter" element="ElementRefXMI11"/>
<right xsi:type="Element" xmi:id="Element12"
name="serviceAreaCounters" element="ElementRefXMI12"/>
</child>
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual6">
<left xsi:type="Element" xmi:id="Element13"
name="applicationSpecificNsr" element="ElementRefXMI13"/>
<right xsi:type="Element" xmi:id="Element14"
name="applicationSpecificNsr" element="ElementRefXMI14"/>
</child>
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual7">
<left xsi:type="Element" xmi:id="Element15" name="accessArea"
element="ElementRefXMI15"/>
<right xsi:type="Element" xmi:id="Element16" name="accessArea"
element="ElementRefXMI16"/>
</child>
<child xsi:type="ReferenceEqual" xmi:id="ReferenceEqual8">
<left xsi:type="Element" xmi:id="Element17" name="deviceArea"
element="ElementRefXMI17"/>
<right xsi:type="Element" xmi:id="Element18" name="deviceArea"
element="ElementRefXMI18"/>
</child>
<left xsi:type="Element" xmi:id="Element19" name="LDMApplicationModel"
element="ElementRefXMI19"/>
<right xsi:type="Element" xmi:id="Element20"
name="PDMApplicationModel" element="ElementRefXMI20"/>
</ownedElement>
<leftM xsi:type="_1:ModelRefXMI" xmi:id="ModelRefXMI1" name="leftM"
ref="/LDMMetamodel/model/LdmMetaModel.ecore">
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI1"
name="ref_applicationModels" ref="EReference3"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI3"
name="ref_coreModel" ref="EReference5"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI5"
name="ref_LDMModel" ref="EClass2"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI7"
name="ref_application" ref="EReference8"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI9"
name="ref_serviceArea" ref="EReference10"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI11"
name="ref_serviceAreaCounter" ref="EReference12"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI13"
name="ref_applicationSpecificNsr" ref="EReference14"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI15"
name="ref_accessArea" ref="EReference16"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI17"
name="ref_deviceArea" ref="EReference18"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI19"
name="ref_LDMApplicationModel" ref="EClass7"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI21"
name="ref_name" ref="EAttribute22"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI23"
name="ref_LDMNamedElement" ref="EClass21"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI25"
name="ref_entities" ref="EReference27"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI27"
name="ref_aliases" ref="EReference29"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI29"
name="ref_views" ref="EReference31"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI31"
name="ref_groups" ref="EReference33"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI33"
name="ref_LDMApplication" ref="EClass26"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI35"
name="ref_base" ref="EReference37"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI37"
name="ref_superEntity" ref="EAttribute39"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI39"
name="ref_LDMApplicationEntity" ref="EClass36"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI41"
name="ref_plainAttributes" ref="EReference44"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI43"
name="ref_LDMEntity" ref="EClass51"/>
</leftM>
<rightM xsi:type="_1:ModelRefXMI" xmi:id="ModelRefXMI2" name="rightM"
ref="/PDMMetamodel/model/PdmModel.ecore">
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI2"
name="ref_applicationModels" ref="EReference8"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI4"
name="ref_coreModel" ref="EReference10"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI6"
name="ref_PDMModel" ref="EClass7"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI8"
name="ref_application" ref="EReference15"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI10"
name="ref_serviceArea" ref="EReference17"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI12"
name="ref_serviceAreaCounters" ref="EReference19"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI14"
name="ref_applicationSpecificNsr" ref="EReference21"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI16"
name="ref_accessArea" ref="EReference25"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI18"
name="ref_deviceArea" ref="EReference27"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI20"
name="ref_PDMApplicationModel" ref="EClass14"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI22"
name="ref_documentation" ref="EAttribute5"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI24"
name="ref_PDMNamedElement" ref="EClass2"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI26"
name="ref_entities" ref="EReference31"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI28"
name="ref_aliases" ref="EReference33"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI30"
name="ref_views" ref="EReference35"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI32"
name="ref_groups" ref="EReference37"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI34"
name="ref_PDMApplication" ref="EClass30"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI36"
name="ref_superEntity" ref="EAttribute43"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI38"
name="ref_base" ref="EReference41"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI40"
name="ref_LdapApplicationObjectClass" ref="EClass40"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI42"
name="ref_plainAttributes" ref="EReference288"/>
<ownedElementRef xsi:type="_1:ElementRefXMI" xmi:id="ElementRefXMI44"
name="ref_LdapObjectClassWithAliases" ref="EClass61"/>
</rightM>
</MatchModel>
thanks ,
venkatesh
Re: New user [message #470194 is a reply to message #470192] Mon, 22 June 2009 03:14 Go to previous messageGo to next message
Hi Marcos,
I have created the weaving model to the Port example(which i have
downloaded the source code from the below site).
http://www.eclipse.org/m2m/atl/basicExamples_Patterns/
This port example has TypeA.ecore & TypeB.ecore.
I created a weaving model to get the TypeA2TypeB.atl
typeA2typeB.amw.prop file look like this
<weaver>
<weaving>
<relative-path>/Port/typeA2typeB.amw</relative-path>
</weaving>
<metamodels>
<plugin>
</plugin>
<local/>
<complete/>
</metamodels>
<woven id="0">
<metamodel-relative-path>/Port/Metamodel/TypeA.ecore</metamodel-relative-path >
</woven>
<woven id="1">
<metamodel-relative-path>/Port/Metamodel/TypeB.ecore</metamodel-relative-path >
</woven>
</weaver>
TypeA2TypeB.amw file look like this
<ownedElement xsi:type="ElementEqual" xmi:id="ElementEqual1">
name="inputports2outputports">
<left xsi:type="Element" xmi:id="Element1" name="inputPorts"
<right xsi:type="Element" xmi:id="Element2" name="inputPorts"
</child>
<left xsi:type="Element" xmi:id="Element3" name="outputPorts"
<right xsi:type="Element" xmi:id="Element4" name="outputPorts"
</child>
<left xsi:type="Element" xmi:id="Element5" name="BlockA"
<right xsi:type="Element" xmi:id="Element6" name="BlockB"
</ownedElement>
<ownedElement xsi:type="ElementEqual" xmi:id="ElementEqual2">
<child xsi:type="AttributeEqual" xmi:id="AttributeEqual1">
<left xsi:type="Element" xmi:id="Element7" name="name"
<right xsi:type="Element" xmi:id="Element8" name="name"
</child>
</ownedElement>
ref="/Port/Metamodel/TypeA.ecore">
name="ref_inputPorts" ref="EReference3"/>
name="ref_outputPorts" ref="EReference5"/>
name="ref_BlockA" ref="EClass2"/>
name="ref_name" ref="EAttribute8"/>
</leftM>
ref="/Port/Metamodel/TypeB.ecore">
name="ref_BlockB" ref="EClass2"/>
</rightM>
</MatchModel>
and in this also i'm getting the same error
SEVERE: exception:
SEVERE: local variables = {null=right!ecore, self=AMWtoATL_Match :
ASMModule}
SEVERE: null
violated
... 43 more
can u tell me for this example how to create the weaving model.
Thanks ,
venkatesh
Re: New user [message #470196 is a reply to message #470194] Mon, 22 June 2009 07:56 Go to previous messageGo to next message
The metamodels typeA and typeB refer directly to elements of Ecore
(EString). These elements do not have an XMI ID associated, thus the
editor cannot handle them correctly.
Try to replace "XMIModelRef" and "XMIWovenPanel" by "ModelRef" and
"DefaultWovenPanel".
You should avoid referencing to Ecore elements in your metamodels, in
order to keep a clear separation between metamodeling levels.
This may be the same problem in your previous example.
Marcos.
Re: New user [message #470197 is a reply to message #470196] Tue, 23 June 2009 08:15 Go to previous messageGo to next message
Hi Marcos ,
It's working fine.Now i want to convert port A to Port B.I have created
weaving model and i generated Hot transformation from that i generated the
atl file but .asm file is not created
TypeA2TypeB.atl file look like this
module T_In2Out;
create typeBModel : typeB from typeAModel : typeA;
rule BlockA_2_BlockB2 {
from
v_left : typeA!BlockA
to
v_right : typeA!BlockB (
inputPorts <- Set {v_left.inputPorts},
outputPorts <- Set {v_left.outputPorts}
rule PortA_2_PortB3 {
from
v_left : typeA!PortA
to
v_right : typeA!PortB (
name <- v_left.name
when i try to transform it's give the following error.
SEVERE: null
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.addReference dExtentsFor(ASMEMFModel.java:490)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.addAllRefere ncedExtents(ASMEMFModel.java:467)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.loadASMEMFMo del(ASMEMFModel.java:315)
org.eclipse.m2m.atl.engine.AtlEMFModelHandler.loadModel(AtlE MFModelHandler.java:219)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.loadModel(Atl RegularVM.java:220)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.getTargetMode ls(AtlRegularVM.java:183)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:327)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:759)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
SEVERE: C:\Documents and
Settings\Administrator\NewFoldereclipse\Port\Test\test_hot.a sm (The system
cannot find the file specified)
java.io.FileNotFoundException: C:\Documents and
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.connect(Unknown Source)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(U nknown
Source)
at java.net.URL.openStream(Unknown Source)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:104)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:351)
SEVERE: Resource '/Port/Test/test_hot.atl' does not exist.
org.eclipse.core.internal.resources.ResourceException: Resource
org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:310)
org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:193)
org.eclipse.core.internal.resources.Resource.findMarkers(Res ource.java:858)
org.eclipse.m2m.atl.adt.ui.viewsupport.AtlEditorTickErrorUpd ater.computeHighestServityFlag(AtlEditorTickErrorUpdater.jav a:69)
org.eclipse.m2m.atl.adt.ui.viewsupport.AtlEditorTickErrorUpd ater.getImage(AtlEditorTickErrorUpdater.java:101)
org.eclipse.m2m.atl.adt.ui.viewsupport.AtlEditorTickErrorUpd ater.updateEditorImage(AtlEditorTickErrorUpdater.java:94)
org.eclipse.m2m.atl.adt.ui.viewsupport.AtlEditorTickErrorUpd ater.problemsChanged(AtlEditorTickErrorUpdater.java:55)
org.eclipse.m2m.atl.adt.ui.viewsupport.ProblemMarkerManager$ 1.run(ProblemMarkerManager.java:142)
can u tell me how to create the weaving model for this example to
transform PortA to PortB.
my amw file look like this
element="ElementRef1"/>
element="ElementRef2"/>
</child>
element="ElementRef3"/>
element="ElementRef4"/>
</child>
element="ElementRef5"/>
element="ElementRef6"/>
</ownedElement>
element="ElementRef7"/>
element="ElementRef8"/>
</child>
<left xsi:type="Element" xmi:id="Element9" name="PortA"
element="ElementRef9"/>
<right xsi:type="Element" xmi:id="Element10" name="PortB"
element="ElementRef10"/>
</ownedElement>
<leftM xsi:type="_1:ModelRef" xmi:id="ModelRef1" name="leftM"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef1"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef3"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef5"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef7"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef9"
name="ref_PortA" ref="EClass7"/>
</leftM>
<rightM xsi:type="_1:ModelRef" xmi:id="ModelRef2" name="rightM"
ref="/Port/Metamodel/TypeC.ecore">
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef2"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef4"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef6"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef8"
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef10"
name="ref_PortB" ref="EClass7"/>
</rightM>
</MatchModel>
Thanks in advance
venkatesh
Re: New user [message #470199 is a reply to message #470197] Tue, 23 June 2009 08:31 Go to previous messageGo to next message
to generate the ".asm" file, the project must have an ATL nature (to call
the ATL compiler). The compiler takes all the ".atl" files in a project,
and produces the corresponding ".asm".
You need to create your project through the New->ATL project menu.
Marcos.
Re: New user [message #470294 is a reply to message #470197] Thu, 25 June 2009 01:19 Go to previous messageGo to next message
Hello Marcos,
Now i got the asm file.In this port example the atl file look like this
module TypeA2TypeB;
create inB : TypeB from inA : TypeA;
rule BlkA2BlkB {
from
blkA : TypeA!BlockA
to
blkB : TypeB!BlockB (
inputPorts <- blkA.inputPorts,
outputPorts <- blkA.outputPorts
rule PortA2InPortB {
from
s : TypeA!PortA (s.refImmediateComposite().inputPorts->includes(s))
to
t : TypeB!InPortB (
name <- s.name
rule PortA2OutPortB {
from
s : TypeA!PortA (s.refImmediateComposite().outputPorts->includes(s))
to
t : TypeB!OutPortB (
name <- s.name
but whatever i'm creating using weaving model is looking like this
module T_In2Out;
from
to
from
to
name <- v_left.name
so i'm not able to transform .I know somewhere in amw file i am doing
mistake.
can u please provide me an amw file for this port example to transform
TypeA2TypeB so that i'll get a clear picture of it.
Thanks in Advance
venkatesh
Re: New user [message #470295 is a reply to message #470294] Thu, 25 June 2009 04:39 Go to previous messageGo to next message
You need to create links between the elements that you want to transform.
For instance, to transform "PortA" into "OutPortB", it is necessary to
create an "ElementLink" between these elements.
Once the links are created, the HOT that is executed always produce an ATL
model that follows the same format:
from
v_left : inelement
to
v_right : outelement
Then, you have two options:
1) manually complete the transformation that has been generated with the
desired code, for instance, the conditions.
2) create an extension to AMW that handles these more complex cases. In
this case, the extension is worthwhile only if it is going to be reused
systematically.
Marcos.
Re: New user [message #470296 is a reply to message #470295] Thu, 25 June 2009 05:46 Go to previous messageGo to next message
Hello Marcos,
Still i'm not clear since i'm new to ATL & AMW.i don't have any idea
about ATL syntax so what i thought is this tool will help me to do it
automatically through GUI.
u mean to say (s.refImmediateComposite().inputPorts->includes(s)) this
condition i have to write manually
can u just tell me in this following amw file what i have to add
</child>
<left xsi:type="Element" xmi:id="Element4" name="outputPorts"
<right xsi:type="Element" xmi:id="Element5" name="outputPorts"
</child>
<left xsi:type="Element" xmi:id="Element3" name="BlockA"
</ownedElement>
</child>
</ownedElement>
ref="/PortTest/Metamodel/TypeA.ecore">
</leftM>
ref="/PortTest/Metamodel/TypeB.ecore">
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef11"
name="ref_InPortB" ref="EClass10"/>
<ownedElementRef xsi:type="_1:ElementRef" xmi:id="ElementRef12"
name="ref_OutPortB" ref="EClass12"/>
</rightM>
</MatchModel>
Thanks in Advance
venaktesh
Re: New user [message #470298 is a reply to message #470296] Thu, 25 June 2009 12:36 Go to previous message
ATL is a model transformation language that is very rich, with the
possibility to write from simple to very complex transformations
expressions. These expressions are used for evaluating/querying the model
elements that are going to be transformed.
AMW has a different goal with respect to model transformations. One of its
objectives is to help on the development of transformations, but not to
develop a whole transformation from scratch.
The typical setting for users of AMW and ATL is to initially define simple
links between models elements using the AMW GUI, than to generate the ATL
"skeleton", and than to complete it manually.
Thus, you should add the "refImmediateComposite()" expressions on the
generated model.
Marcos
Previous Topic:Problem in Mantis2Bug.ecore
Next Topic:Any Build for Galileo?
Current Time: Sun Nov 09 11:21:40 EST 2025
Powered by FUDForum. Page generated in 0.05526 seconds
