Home » Modeling » UML2 » UML Profile for extended metadata
Re: UML Profile for extended metadata [message #470157 is a reply to message #470151] |
Thu, 08 February 2007 02:40 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Yves,
If you select your .uml file then, right click and select New > Eclipse
Modeling Framework > EMF Model > Next..> Next..>UML model. Click "load"
.... then Finish.
The result should be a .genmodel and .ecore file.
- James.
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:eqdueg$kba$1@utils.eclipse.org...
> Hi Kenn,
> Thanks for the quick reply. Could you tell me how to create corresponding
> ecore model for an extended metadata ? Same as what you did with UML2, you
> have UML.metadata.uml and also the corresponding UML.ecore. For me, I have
> my metamodel which is an extension of UML2, how I create the corresponding
> ecore file? Is the "UML to Ecore" conversion enough?
> Regards
> Yves YANG
> "Kenn Hussey" <khussey@ca.ibm.com> wrote in message
> news:eqcub8$30j$1@utils.eclipse.org...
>> Yves,
>> I believe this has already been addressed in response to
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=159855.
>> Kenn
>> news:eqcpc6$mqf$1@utils.eclipse.org...
>>> Hi all,
>>> I read a thread in eclipse.tools.uml2 (dated Oct 2006) the UML Profile
>>> for extended metadata was not supported. What is the current status ? I
>>> think it is very important feature. If it isn't supported now, is there
>>> a workaround solution?
>>> Best regards
>>> Yves YANG
Re: UML Profile for extended metadata [message #470222 is a reply to message #470157] |
Thu, 08 February 2007 22:39 |
Yves YANG Messages: 688 Registered: July 2009 |
Hi James,
Thanks for your anwser, which confirms what I'm think.
Best regards
yves
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:eqe2eb$ul0$1@utils.eclipse.org...
> Hi Yves,
> ... then Finish.
> Cheers,
> - James.
>> Hi Kenn,
>> you have UML.metadata.uml and also the corresponding UML.ecore. For me, I
>> have my metamodel which is an extension of UML2, how I create the
>> corresponding ecore file? Is the "UML to Ecore" conversion enough?
>> Regards
>> Yves YANG
>>> Yves,
>>> Kenn
>>>> Hi all,
>>>> Best regards
>>>> Yves YANG
Re: UML Profile for extended metadata [message #471350 is a reply to message #470222] |
Sun, 04 March 2007 20:16 |
I spent some time to make solution work. I wrote a draft tutorial, which may
be helpful for others:
http://www.soyatec.org/wiki/doku.php?id=technology:uml2:umlp rofileextendedmetamodel
All comments are welcome.
yves
news:eqg8qd$2r8$1@utils.eclipse.org...
> Hi James,
> Best regards
> yves
>> Hi Yves,
>> "load" ... then Finish.
>> Cheers,
>> - James.
>>> Hi Kenn,
>>> corresponding ecore model for an extended metadata ? Same as what you
>>> did with UML2, you have UML.metadata.uml and also the corresponding
>>> UML.ecore. For me, I have my metamodel which is an extension of UML2,
>>> how I create the corresponding ecore file? Is the "UML to Ecore"
>>> conversion enough?
>>> Regards
>>> Yves YANG
>>>> Yves,
>>>> Kenn
>>>>> Hi all,
>>>>> I think it is very important feature. If it isn't supported now, is
>>>>> there a workaround solution?
>>>>> Best regards
>>>>> Yves YANG
Re: UML Profile for extended metadata [message #583184 is a reply to message #470151] |
Hi Yves,
.... then Finish.
- James.
> Hi Kenn,
> Regards
> Yves YANG
>> Yves,
>> Kenn
>>> Hi all,
>>> Best regards
>>> Yves YANG
Re: UML Profile for extended metadata [message #586685 is a reply to message #470157] |
Hi James,
Best regards
yves
> Hi Yves,
> ... then Finish.
> Cheers,
> - James.
>> Hi Kenn,
>> Regards
>> Yves YANG
>>> Yves,
>>> Kenn
>>>> Hi all,
>>>> Best regards
>>>> Yves YANG
Re: UML Profile for extended metadata [message #598252 is a reply to message #470222] |
yves
> Hi James,
> Best regards
> yves
>> Hi Yves,
>> Cheers,
>> - James.
>>> Hi Kenn,
>>> conversion enough?
>>> Regards
>>> Yves YANG
>>>> Yves,
>>>> Kenn
>>>>> Hi all,
>>>>> Best regards
>>>>> Yves YANG
Current Time: Thu Apr 25 08:41:39 GMT 2024
Powered by FUDForum. Page generated in 0.04256 seconds
