Home » Modeling » UML2 » Creating EMF project from xmi file
Creating EMF project from xmi file [message #469720] |
Tue, 30 January 2007 21:12 |
Michael Giroux Messages: 287 Registered: July 2009 |
Configuration,
Eclipse 3.2.1 Release
UML 2.0.2 Release
I am trying to create a new EMF project based on an xmi file that was
exported by the Enterprise Architect UML modeling tool.
I created the model with EA, then exported an xmi file. I guess (but not
sure) the xmi is a UML2 model. Beginning of xmi contains:
<?xml version="1.0" encoding="windows-1252"?>
<!DOCTYPE XMI SYSTEM "UML_EA.dtd">
<XMI xmi.version="1.1" xmlns:UML="omg.org/UML1.3" timestamp="2007-01-29
12:35:07">
Using the File/New/Project wizard, I select EMF project, then select the UML
importer. The UML importer dialog opens, lets me select the xmi file and
press the load button. At this point, there are no obvious errors or
warnings.
However, the NEXT and FINISH buttons are disabled, so I am not able to
continue with the import process.
I tried pressing F1 and/or clicking the ? in the dialog, but the help topics
do not include anything about UML import.
Am I doing something wrong?
Michael
Re: Creating EMF project from xmi file [message #469813 is a reply to message #469720] |
Wed, 31 January 2007 15:12 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Michael,
Open up the "Error Log" view... go to Window > Show View > PDE Runtime >
Error Log.
Can you see any errors or warnings in there. The importer might have
thrown some exception internally ...
If you can't see anything in the log, please post the file that is causing
you grief and I'll have a look.
- James.
"Michael Giroux" <michael.giroux@bull.com> wrote in message
news:epocck$cmc$1@utils.eclipse.org...
> Configuration,
> UML 2.0.2 Release
> 12:35:07">
UML
> warnings.
topics
> Michael
Re: Creating EMF project from xmi file [message #469814 is a reply to message #469813] |
Wed, 31 January 2007 15:24 |
James,
There are no entries in Error Log, so here is the xmi. Thanks for offering
to look.
Michael
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:epqblh$7is$2@utils.eclipse.org...
> Hi Michael,
> Error Log.
> Regards,
> - James.
>> Configuration,
>> UML 2.0.2 Release
>> 12:35:07">
> UML
>> warnings.
> topics
>> Michael
Re: Creating EMF project from xmi file [message #469817 is a reply to message #469720] |
Wed, 31 January 2007 16:00 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
Michael,
UML2 only supports import of UML 2.1 models serialized in XMI 2.1. It would
be better if wizard notified you when an invalid input like this is
provided, so please open a Bugzilla report and we'll make the necessary
changes.
Kenn
> Configuration,
> UML 2.0.2 Release
> 12:35:07">
> UML importer. The UML importer dialog opens, lets me select the xmi file
> and press the load button. At this point, there are no obvious errors or
> warnings.
> topics do not include anything about UML import.
> Michael
Re: Creating EMF project from xmi file [message #469818 is a reply to message #469817] |
Wed, 31 January 2007 16:11 |
BUG 172330.
Michael
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:epqeek$msk$1@utils.eclipse.org...
> Michael,
> would be better if wizard notified you when an invalid input like this is
> changes.
> Kenn
>> Configuration,
>> UML 2.0.2 Release
>> 12:35:07">
>> warnings.
>> Michael
Re: Creating EMF project from xmi file [message #469819 is a reply to message #469818] |
Wed, 31 January 2007 17:44 |
Thanks!
Kenn
news:epqf2k$thq$1@utils.eclipse.org...
> BUG 172330.
> Michael
>> Michael,
>> changes.
>> Kenn
>>> Configuration,
>>> UML 2.0.2 Release
>>> not sure) the xmi is a UML2 model. Beginning of xmi contains:
>>> 12:35:07">
>>> file and press the load button. At this point, there are no obvious
>>> errors or warnings.
>>> Michael
Re: Creating EMF project from xmi file [message #469820 is a reply to message #469817] |
Wed, 31 January 2007 18:38 |
Kenn,
I exported the xmi file using UML 2.1 format. This resulted in an error
being generated when the UML importer tried to load the file:
The dialog has "Load Problem" in the title with a message of "The class
'Type' is not a valid classifier".
This may reflect an error in the model I'm trying to import.
If you can comment I will appreciate.
Michael
> Michael,
> changes.
> Kenn
>> Configuration,
>> UML 2.0.2 Release
>> 12:35:07">
>> warnings.
>> Michael
Re: Creating EMF project from xmi file [message #469821 is a reply to message #469820] |
Wed, 31 January 2007 20:36 |
Michael,
Are you talking about a different model this time? The one you showed a
snippet from appeared to be UML 1.3, XMI 1.1.
If you can post a sample XMI file that demonstrates the problem, we'll look
into it.
Kenn
news:epqnn5$up8$1@utils.eclipse.org...
> Kenn,
> Thanks
> Michael
>> Michael,
>> changes.
>> Kenn
>>> Configuration,
>>> UML 2.0.2 Release
>>> 12:35:07">
>>> errors or warnings.
>>> Michael
Re: Creating EMF project from xmi file [message #578794 is a reply to message #469720] |
Hi Michael,
Error Log.
- James.
> Configuration,
> UML 2.0.2 Release
> 12:35:07">
UML
> warnings.
topics
> Michael
Re: Creating EMF project from xmi file [message #578812 is a reply to message #469813] |
James,
to look.
Michael
> Hi Michael,
> Error Log.
> Regards,
> - James.
>> Configuration,
>> UML 2.0.2 Release
>> 12:35:07">
> UML
>> warnings.
> topics
>> Michael
Re: Creating EMF project from xmi file [message #578913 is a reply to message #469720] |
Michael,
changes.
Kenn
> Configuration,
> UML 2.0.2 Release
> 12:35:07">
> warnings.
> Michael
Re: Creating EMF project from xmi file [message #578932 is a reply to message #469817] |
BUG 172330.
Michael
> Michael,
> changes.
> Kenn
>> Configuration,
>> UML 2.0.2 Release
>> 12:35:07">
>> warnings.
>> Michael
Re: Creating EMF project from xmi file [message #578968 is a reply to message #469818] |
Thanks!
Kenn
> BUG 172330.
> Michael
>> Michael,
>> changes.
>> Kenn
>>> Configuration,
>>> UML 2.0.2 Release
>>> 12:35:07">
>>> errors or warnings.
>>> Michael
Re: Creating EMF project from xmi file [message #578992 is a reply to message #469817] |
Kenn,
Michael
> Michael,
> changes.
> Kenn
>> Configuration,
>> UML 2.0.2 Release
>> 12:35:07">
>> warnings.
>> Michael
Re: Creating EMF project from xmi file [message #579029 is a reply to message #469820] |
Michael,
into it.
Kenn
> Kenn,
> Thanks
> Michael
>> Michael,
>> changes.
>> Kenn
>>> Configuration,
>>> UML 2.0.2 Release
>>> 12:35:07">
>>> errors or warnings.
>>> Michael
Current Time: Sat Sep 21 05:59:55 GMT 2024
Powered by FUDForum. Page generated in 0.04794 seconds
