Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563347 is a reply to message #469119] |
Fri, 31 October 2008 07:48 |
Originally posted by: remy.suen.gmail.com
Hi Yves,
Yves Yang wrote:
> The soruce is updated in sourceforge.
I am having compilation problems.
o.s.microsoft.msbuild.edit will not build properly. There appears to be
no MANIFEST.MF file and the plugin.xml has errors (as the plug-in is not
even defined properly in the old Eclipse 2.x format). This problem
indirectly affects the compilation of o.s.microsoft.msbuild.editor.
o.s.csm.tests will not compile because o.s.csm.tools are nowhere to be
found.
Closing the erroneous projects is okay since I can still run SLDT
through PDE, I guess I will just miss some MSBuild features.
Remy
Re: org.soyatec.eclipse4sl.vex.silverlight does not compile [message #563369 is a reply to message #469120] |
Sat, 01 November 2008 07:14 |
o.s.microsoft.msbuild.edit is okay now as I see that the MANIFEST.MF
file was committed in r78.
Thanks.
FUDForum. Page generated in 0.06244 seconds
