Value validation [message #47445] |
Tue, 08 June 2004 10:59 |
Originally posted by: invalid.soft-gems.net
Ed,
Is there a built-in facility to check whether a given value is valid
compared to the effective facets of its type? I can write this myself, but
I would suspect that this is an often needed feature when working with
schemas, so it would be cool if there is already an implementation.
Mike
www.soft-gems.net
Re: Value validation [message #47505 is a reply to message #47445] |
Tue, 08 June 2004 11:24 |
Mike,
To determine if a literal is valid with respect to a simple type, you can use
either XSDSimpleTypeDefinition.isValidLiteral or
XSDSimpleTypeDefinition.assess.
Mike Lischke wrote:
> Ed,
> Mike
> www.soft-gems.net
Re: Value validation [message #47535 is a reply to message #47505] |
Tue, 08 June 2004 14:19 |
Works exactly as I wanted it (except for localisation of the error
message, but this is subordinated, currently). Thanks a bunch Ed.
Mike
www.soft-gems.net
Re: Value validation [message #47569 is a reply to message #47535] |
Tue, 08 June 2004 14:55 |
Mike,
The translation is done at the end of the development cycle. IBM pays for it (and
it's not cheap!) and then donates it to Eclipse. For standalone support, we create
the xsd.resources.jar based on the donation from IBM, so that currently contains
the translation from the 1.1.1.1 release. Unzipping that file and copying the
*.properties file to where the English plugin.properties file is should get you
translation for what was translated before...
> Mike
> www.soft-gems.net
Re: Value validation [message #47593 is a reply to message #47569] |
Tue, 08 June 2004 14:56 |
Ed Merks wrote:
> Mike,
it (and
create
contains
the
you
This is excellent news Ed. We were thinking of doing this (at least
partially) ourselves but this way is much better :-)
A last question for today: How would I go to get an assigned default value
for an attribute if there is one? I could not find anything related to
"default" in XSDSimpleTypeDefinition interface.
Mike
www.soft-gems.net
Re: Value validation [message #47622 is a reply to message #47593] |
Tue, 08 June 2004 15:09 |
Mike,
XSDFeature.getValue will return the default value of an XSDElementDeclaration or
an XSDAttributeDeclaration. This is an XML Schema infoset property. It is
computed from XSDFeature.getLexicalValue, which is the string literal default as
it appears in the schema.
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> it (and
> create
> contains
> the
> you
> Mike
> www.soft-gems.net
Re: Value validation [message #47651 is a reply to message #47622] |
Wed, 09 June 2004 08:33 |
Ed,
default as
Thank you.
Mike
www.soft-gems.net
Re: Value validation [message #588272 is a reply to message #47445] |
Ed Merks Messages: 33216 Registered: July 2009 |
Mike,
Mike Lischke wrote:
> Ed,
> Mike
> www.soft-gems.net
Ed Merks
Re: Value validation [message #589128 is a reply to message #47535] |
Mike,
> Mike
> www.soft-gems.net
Ed Merks
Re: Value validation [message #589147 is a reply to message #47593] |
Mike,
Mike Lischke wrote:
> Ed Merks wrote:
> > Mike,
> it (and
> create
> contains
> the
> you
> Mike
> www.soft-gems.net
Ed Merks
FUDForum. Page generated in 0.04877 seconds
