Home » Eclipse Projects » Rich Client Platform (RCP) » Re: Contribute command to existing menu?
Re: Contribute command to existing menu? [message #468382] Wed, 05 August 2009 06:40 Go to next message
Originally posted by: formatzeh.gmx.de
Can't anynone give me a hint? Is the following the right approach for
adding a command to an existing menu? Especially I want to add the
command as a menu entry in the "Generator" menu in the main menu.
Gilbert Mirenque wrote:
> <extension
> point="org.eclipse.ui.menus">
> <menuContribution
> locationURI=" menu:org.eclipse.emf.codegen.ecore.genmodelMenuID?after=addi tions ">
> <command
> commandId="my.plugin.emf.extended.commands.sampleCommand"
> id="my.plugin.emf.extended.menus.sampleCommand"
> mnemonic="S">
> </command>
> </menuContribution>
> </extension>
Re: Contribute command to existing menu? [message #468391 is a reply to message #468382] Wed, 05 August 2009 07:38 Go to previous message
Hi Gilbert,
i think that should work, I did the same way, maybe you forgot to
specify a Handler for your command. Have a look at the command extension
point where you specified the command, it should look like this:
<extension
point="org.eclipse.ui.commands">
<command
defaultHandler=
"handlerClass"
description="a Command"
id="some.command.id"
name="CommandName">
</command>
</extension>
You should at least have a defaultHanlder specified in your command. The
class has to extend org.eclipse.core.commands.AbstractHandler.
HTH
Tom
>> <extension
>> <menuContribution
>> <command
>> mnemonic="S">
>> </command>
>> </menuContribution>
>> </extension>
Previous Topic:Different CellEditor per Row
Next Topic:Re: Plugin not activated/View not shown
Current Time: Wed Nov 05 19:34:25 EST 2025
Powered by FUDForum. Page generated in 0.03722 seconds
