Home » Eclipse Projects » Rich Client Platform (RCP) » Re: Platform doesn't load adapters in inactive bundles
Re: Platform doesn't load adapters in inactive bundles [message #468351] Wed, 05 August 2009 04:13
Robert Wilson wrote:
> Thanks - that seems to work.
> Less neat than adaptable.getAdapter(), but I suppose we have to make do..
As I understood, you have a custom IAdaptable implementation, so you
have to implement the adaptable.getAdapter(Class) method yourself, right?
This is what I did:
public Object getAdapter(Class adapterClass) {
if (adapterClass == null) {
return null;
IAdapterManager adapterManager = Platform.getAdapterManager();
if (adapterManager == null) {
return null;
// first try to get it the 'default way'
Object adapter = adapterManager.getAdapter(this, adapterClass);
if (adapter != null) {
return adapter;
// otherwise try by loading with bundle activation
return adapterManager.loadAdapter(this, adapterClass.getName());
This works fine and I always use adaptable.getAdapter()...
Previous Topic:Re: Problem with SAXBuilder
Next Topic:Different CellEditor per Row
Current Time: Wed Jul 02 17:08:45 EDT 2025
Powered by FUDForum. Page generated in 0.03271 seconds
