Home » Eclipse Projects » Eclipse Platform » Unable to connect to the network for update
Unable to connect to the network for update [message #467835] Mon, 03 August 2009 01:38 Go to next message
Originally posted by: bojana.simova.gmail.com
Installed Eclipse Platform 3.5.0.v20090611a
on Linux Red Hat.
My company is using firewall.
When I tried to check for updates or install new plug-ins, I realized
that Eclipse is not connecting to the network.
Went to Windows-> Preferences -> Network connections and configured
the proxies, using the same proxy server as in my browser, which works
perfectly. Even after this configuration, I'm still unable to connect.
Test Connection hangs for a while and then I get error message :
Unable to read repository at
http://download.eclipse.org/releases/galileo/site.xml.
No route to host
Checked .log file in workspace directory :
!MESSAGE Connection to
http://download.eclipse.org/releases/galileo/site.xml failed on No route
to host. Retry attempt 0 started
!STACK 0
java.net.NoRouteToHostException: No route to host
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.ja va:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:519)
And also a bunch of these :
!ENTRY org.eclipse.core.net 1 0 2009-08-02 22:27:29.286
!MESSAGE System property http.proxyHost is not set but should be
my-proxy.com.
!MESSAGE System property http.proxyPort is not set but should be 80.
!MESSAGE System property https.proxyHost is not set but should be
my-proxy.com.
!MESSAGE System property https.proxyPort is not set but should be 80.
!ENTRY org.eclipse.core.net 1 0 2009-08-02 22:27:29.287
!MESSAGE System property socksProxyHost is not set but should be
my-proxy.com.
!MESSAGE System property socksProxyPort is not set but should be 80.
!ENTRY org.eclipse.core.net 1 0 2009-08-02 22:27:40.056
my-proxy.com.
my-proxy.com.
!ENTRY org.eclipse.core.net 1 0 2009-08-02 22:27:40.057
my-proxy.com.
I don't know how am I supposed to set these system properties.
Installed the same version on Windows machine using the same proxy server
and
it works fine. Some proxies even have been added automatically at
installation time and I did not need to configure anything afterwords to
get it working.
Thanks and Regards
Re: Unable to connect to the network for update [message #482053 is a reply to message #467835] Tue, 25 August 2009 05:42 Go to previous messageGo to next message
Eclipse use SOCKS proxy before HTTP. So, if your companie does set a SOCKS
proxy, you should clear it in proxy preference (then eclipse use HTTP
proxy first).
Re: Unable to connect to the network for update [message #482056 is a reply to message #482053] Tue, 25 August 2009 05:44 Go to previous messageGo to next message
Eclipse use SOCKS proxy before HTTP. So, if your company doesn't provide a
SOCKS proxy, you should clear it in proxy preference (then eclipse use
HTTP proxy first).
Re: Unable to connect to the network for update [message #525455 is a reply to message #482056] Tue, 06 April 2010 11:52 Go to previous messageGo to next message
I'm getting this same error (System property http.proxyPort is not set but should be 8080, the analogous error for the host too) trying to deploy a new GWT app to the app engine.
Where do I need to set these system properties so that the deploy will work? I have the settings successfully set in both firefox and eclipse, I guess it needs to be set elsewhere as well? Could someone point out where?
Thanks!
-=j=-
Re: Unable to connect to the network for update [message #649965 is a reply to message #525455] Fri, 21 January 2011 04:03 Go to previous messageGo to next message
Just in case someone still has this problem (Coporate Proxy doesn't provide SOCKS):
Try unchecking SOCKS in Control Panel - Internet Options under Windows. If you then select native proxy settings under eclipse, a GOPHER entry should be added instead of the SOCKS entry and the update manager (install new software) should work fine..
That solved the issue for me..
Re: Unable to connect to the network for update [message #693786 is a reply to message #467835] Thu, 07 July 2011 04:15 Go to previous messageGo to next message
I've had the same problem and this worked out well for me:
At \eclipse\configuration\.settings\org.eclipse.core.net.prefs set the property systemProxiesEnabled to true manually and restart.
So long Very Happy
[Updated on: Thu, 07 July 2011 04:15] by Moderator
Re: Unable to connect to the network for update [message #1697406 is a reply to message #693786] Wed, 03 June 2015 12:53 Go to previous messageGo to next message
This worked for me! Thank you!
icon14.gif  Re: Unable to connect to the network for update [message #1743893 is a reply to message #693786] Tue, 20 September 2016 08:46 Go to previous messageGo to next message
BIG THANX!!! I have this trouble for 4 YEARS!!! Laughing
Re: Unable to connect to the network for update [message #1766428 is a reply to message #693786] Wed, 21 June 2017 06:51 Go to previous messageGo to next message
Where should I add this systemProxiesEnabled=true?
Re: Unable to connect to the network for update [message #1784555 is a reply to message #1766428] Thu, 29 March 2018 06:09 Go to previous messageGo to next message
hey,
How can I go to the confugation tab!! I can't find it :(
Thank u
Re: Unable to connect to the network for update [message #1799067 is a reply to message #693786] Thu, 29 November 2018 08:37 Go to previous messageGo to next message
Thank you.. It worked for me..
Re: Unable to connect to the network for update [message #1832988 is a reply to message #1799067] Wed, 30 September 2020 08:15 Go to previous messageGo to next message
Everything worked great. This solved the problem for me and everything is fine now.
Also, I now do not receive error messages.
Thanks for this
Re: Unable to connect to the network for update [message #1839946 is a reply to message #1832988] Thu, 01 April 2021 13:17 Go to previous message
Sometimes the router configuration has a firewall rule that blocks an IP address for 8080 or any other port/IP.
Previous Topic:Support for p2 update sites from maven in target platforms editor
Next Topic:-Declipse.pluginCustomization not working for RCP application
Current Time: Wed Aug 20 22:43:15 EDT 2025
Powered by FUDForum. Page generated in 0.04427 seconds
