Schema standard types [message #47351] |
Tue, 08 June 2004 06:04 |
Originally posted by: invalid.soft-gems.net
Hi Ed,
I tried to get all types in a schema using schema.eAllContents() but found
that default types (e.g. xs:integer) are not included in this collection.
I thought eAllContents would return anything in a schema, but it seems I
need something different for this. Can you help please?
Mike
www.soft-gems.net
Re: Schema standard types [message #47381 is a reply to message #47351] |
Tue, 08 June 2004 10:39 |
Mike,
The eAllContents method walks the containment tree of an object, so it will
return everything physically contained under the object. The
XSDSchema.getTypeDefinitions() returns all the types defined by a schema and
all those imported or included into the schema. It will not contain the
built-in schema types either, because they are not imported nor included, they
are simply ubiquitous and available everywhere without import. Using
xsdSchema.getSchemaForSchema().getTypeDefinitions will get the type
definitions defined by the schema for schemas. The method
xsdSchema.getSimpleTypeIdMap() applied to the schema for schema will give
precisely the built-in simple types.
Mike Lischke wrote:
> Hi Ed,
> Mike
> www.soft-gems.net
Re: Schema standard types [message #47415 is a reply to message #47381] |
Tue, 08 June 2004 10:52 |
Excellent Ed, thank you. Works like a charm.
Btw: I expected to get an enumeration facet for xs:boolean but there is
none. Isn't this type defined as the list of values "true", "false", "0"
and "1"?
Mike
www.soft-gems.net
Re: Schema standard types [message #47475 is a reply to message #47415] |
Tue, 08 June 2004 11:20 |
--------------6EB3CED71C7AC3C390907CC6
Content-Type: text/plain; charset=us-ascii
Mike,
No, it's defined like this:
<xs:simpleType name="boolean" id="boolean">
<xs:annotation>
<xs:appinfo>
<hfp:hasFacet name="pattern"/>
<hfp:hasFacet name="whiteSpace"/>
<hfp:hasProperty name="ordered" value="false"/>
<hfp:hasProperty name="bounded" value="false"/>
<hfp:hasProperty name="cardinality" value="finite"/>
<hfp:hasProperty name="numeric" value="false"/>
</xs:appinfo>
<xs:documentation
source="http://www.w3.org/TR/xmlschema-2/#boolean"/>
</xs:annotation>
<xs:restriction base="xs:anySimpleType">
<xs:whiteSpace value="collapse" fixed="true"
id="boolean.whiteSpace"/>
</xs:restriction>
</xs:simpleType>
An enumeration would have to be a restriction of some type that already
included the values...
> and "1"?
> Mike
> www.soft-gems.net
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Mike,
<p>No, it's defined like this:
<blockquote><xs:simpleType name="boolean" id="boolean">
<br> <xs:annotation>
<br> <xs:appinfo>
<br> <hfp:hasFacet name="pattern"/>
<br> <hfp:hasFacet name="whiteSpace"/>
<br> <hfp:hasProperty name="ordered" value="false"/>
<br> <hfp:hasProperty name="bounded" value="false"/>
<br> <hfp:hasProperty name="cardinality"
value="finite"/>
<br> <hfp:hasProperty name="numeric" value="false"/>
<br> </xs:appinfo>
<br> <xs:documentation
<br> source="<A HREF="http://www.w3.org/TR/xmlschema-2/#boolean"/">http://www.w3.org/TR/xmlschema-2/#boolean"/</A>>
<br> </xs:annotation>
<br> <xs:restriction base="xs:anySimpleType">
<br> <xs:whiteSpace value="collapse" fixed="true"
<br> id="boolean.whiteSpace"/>
<br> </xs:restriction>
<br></xs:simpleType></blockquote>
<br>
<p>Mike Lischke wrote:
<blockquote TYPE=CITE>Ed Merks wrote:
<p>> xsdSchema.getSchemaForSchema().getTypeDefinitions will get the type
<br>> definitions defined by the schema for schemas. The method
<br>> xsdSchema.getSimpleTypeIdMap() applied to the schema for schema will
give
<br>> precisely the built-in simple types.
<p>Excellent Ed, thank you. Works like a charm.
<p>Btw: I expected to get an enumeration facet for xs:boolean but there
is
<br>none. Isn't this type defined as the list of values "true", "false",
"0"
<br>and "1"?
<p>Mike
<br>--
<br>www.soft-gems.net</blockquote>
</html>
--------------6EB3CED71C7AC3C390907CC6--
Re: Schema standard types [message #588232 is a reply to message #47351] |
Ed Merks Messages: 33141 Registered: July 2009 |
Mike,
Mike Lischke wrote:
> Hi Ed,
> Mike
> www.soft-gems.net
Ed Merks
Re: Schema standard types [message #588261 is a reply to message #47415] |
Mike,
<xs:annotation>
<xs:appinfo>
</xs:appinfo>
<xs:documentation
</xs:annotation>
</xs:restriction>
</xs:simpleType>
> and "1"?
> Mike
> www.soft-gems.net
<html>
Mike,
<br> <xs:appinfo>
value="finite"/>
<br> </xs:appinfo>
<br>
give
is
"0"
<br>and "1"?
<p>Mike
<br>--
</html>
Ed Merks
FUDForum. Page generated in 0.03393 seconds
